    Help with setting up static IP for WAN
    3 Posts 2 Posters 841 Views 2 Watching
      Joe_Papa
      I have purchased a static IP address from my ISP and I'm trying to set it up. They have me the following information.
      IP address: xxx.xxx.xxx.xx
      Gateway/router IP:xxx.xxx.xxx.xx
      Subnet: xxx.xxx.xxx.xxx
      DNS1: xxx.xxx.xxx.xx
      DNS1: xxx.xxx.xxx.xxx
      So I went into the interface settings on my pfsense VM and tried to update the settings.
      Problem is when I change the interface configuration type to static instead of DHCP i only get the option to input an IP address, an upstream gateway, and a subnet mask (1-32) not the subnet IP. And when I try to save the settings it says that the IP address is not available in the subnet associated with the WAN interface.
      Where do I put in the subnet? Or is there some step I'm missing?
        johnpoz LAYER 8 Global Moderator @Joe_Papa
        @joe_papa said in Help with setting up static IP for WAN:
        The subnet would be some 255.255.255.0 sort of address depending on the mask which is like /30 or /24 etc..
        Convert what subnet mask they gave you to the cidr format..
        https://docs.netgate.com/pfsense/en/latest/network/cidr.html
        SG-4860 26.03 | Lab VMs 2.8.1, 26.03
          Joe_Papa @johnpoz
          @johnpoz Ahh. Thank you so much. It's amazing how little some service techs actually understand. That perfectly solved my problem.
