    Wan failover doesn’t work and bigger problems
    25 Posts 5 Posters 3.5k Views 5 Watching
      Hmm, well I would use a gateway directly rather than a group with one gateway in it.
      21.05-REL on the 3100 has known issues that will cause you problems so I would update if at all possible.
      Can you limit SSH to know IPs or to dyndns addresses perhaps?
      I 1 Reply Last reply Reply Quote 1
      • I Offline
        idiotzoo @stephenw10
        @stephenw10 Hi Steve, it looks like issue 12004 is possibly what was causing the pain on boot issues. The significance of a PHP crash wasn't something I'd fully appreciated.
        With 21.05.2 the system appears to start up happily.
        It would be super helpful if a fix that affected platforms referenced the models in the release notes.
        Thanks for your help. Just the WAN failover to do some more testing with.
        S S 2 Replies Last reply Reply Quote 0
          SteveITS Galactic Empire @idiotzoo
          @idiotzoo said in Wan failover doesn’t work and bigger problems:
          Although the 3100 isn't directly mentioned in https://docs.netgate.com/pfsense/en/latest/releases/21-05-1.html it is one of the few 32 bit ARM models. (also the 1000).
          Upvote 👍 helpful posts!
            Mmm, I agree it would have been useful there. It also didn't affect the SG-1000 directly because it only affected multicore devices. Really only the 3100.
            But you should always be on the latest version really unless you have a very good reason not to be.
              serbus @idiotzoo
              Hello!
              All of my multi wan failover configs running on 21.05.2 cratered due to this:
              https://redmine.pfsense.org/issues/11570
              I manually reverted this code change from this issue to get it working again.
              John
              Lex parsimoniae
