    loss of speed with pfsense 2.5.1 using Intel(R) PRO/1000 PCI-Express Network Driver
    25 Posts 5 Posters 2.7k Views 5 Watching
      gstlouis @jsmiddleton4
      @jsmiddleton4
      thanks
      I appreciated your input too!
      • stephenw10S Online
        Ah, good test!
        So what's different about LAN1 then? You have packages running? Maybe Snort or ntop-ng on LAN1 only?
          gstlouis @stephenw10
          no idea
          I do recall installing darkstat, but I did disable it. any other packages can slow down bandwidth ?
            stephenw10 Netgate Administrator @gstlouis
            Things that actually examine traffic can slow it, so; Snort, Suricata, Squid, Ntop-NG are the prime suspects.
              well I disable darkstat, even removed it. It did nothing. I can't see anything else packages wise that would cause this problem as I think I only really install darkstat, and cron...
              I found the problem. I had a freaking traffic shaper! A while nack I was fiddling with trying to get a level balance of all primary devices. Once I disabled this I could get my speeds. All that for this!!
              well it was a good deep dive I guess, and I sure know what I sohuld be looking for in the future.
              Thanks to all
              Guy
