    questions about Automatic Configuration Backup system running for Netgate/pfSense firewalls acb.netgate
    3 Posts 2 Posters 598 Views 2 Watching
    • JonathanLeeJ Offline
      JonathanLee
      (Image: acb.netgate.com, NON local ip address)
      Hello fellow Netgate community, is acb.netgate an approved backup for development mode? How can I turn off full cloud backups of my firewall?
      (Image: Cloud backup AWS)
      (System Logs showing system is backing up my configuration)
      How can I access my cloud based backups with a URL? Or only in pfSense?
      Make sure to upvote
        JonathanLee @JonathanLee
        @jonathanlee
        I found the restore.
        However how can I view from https over URL outside of the Netgate system?
        Make sure to upvote
          You cannot yet view backups except via the pfSense webgui.
          However you can use ACB on another pfSense instance to fetch a backup as long as you have the acb key and encryption pass phrase.
