    Problem with snapshot 3/31 16:19:49
    Scheduled Pinned Locked Moved CE 2.7.0 Development Snapshots (Retired)
    46 Posts 6 Posters 14.5k Views 7 Watching
    • JonathanLeeJ Offline
      JonathanLee @iTestAndroid
      @itestandroid if your using NAT rules they must be inverted
      Make sure to upvote
        slim2016 @JonathanLee
        Has this issue been fixed?
          JonathanLee @slim2016
          @slim2016 This issue was fixed long ago. This was under development issues, this is fully resolved for me.
          Make sure to upvote
            @jonathanlee
            I just had the same problem, I disabled all the firewall rules, but it still didn't fix the problem. I eventually restarted the firewall, and now it's working back to normal.
              @slim2016 Mine was related to develop mode testing. I had to reinstall the software that was installed when my Netgate firewall was shipped to me to resolve this. After that it no longer had this issue when I restored my configuration I had backed up. Came right up no problems. I did have to have negated rules added however.
              Make sure to upvote
              • B bullet2392 referenced this topic on
                Radiam
                I did an upgrade from 22.01 to 22.05. I had a number of problems (had to use command line to complete upgrade). This was one of the problems to emerge after that fix. Specifcally, I couldn't get OpenVPN to work properly.
                Once I turned off NAT reflection and rebooted, I stopped getting the pfctl error and OpenVPN started working again (presumably rules weren't getting loaded correctly).
                Big kudos from me for the fix!!
                • P pwt-safonso referenced this topic on
                • S SteveITS referenced this topic on
