    pfSense 2.6 problem with zombie processes
    43 Posts 3 Posters 13.0k Views 3 Watching
    • gofaizenG Offline
      gofaizen @stephenw10
      With this parameters -d -v -l /var/log/qemu-ga.log -b "guest-get-fsinfo" qemu-ga does not generate zombies.
      -b "guest-get-fsinfo" - means - blacklist guest-get-fsinfo command
      • stephenw10S Online
        Mmm, OK. And does that still provide the info you need?
        gofaizenG 1 Reply Last reply Reply Quote 0
        • gofaizenG Offline
          qemu-ga provides information about interfaces, logged in users and fqdn. I cant see information about guest agent version, OS, timezone, architecture and file systems (i have disabled file system info by myself).
            And that's sufficient?
            • gofaizenG Offline
              I would like to get all info from qemu-ga. Like from Linux VM.
              FreeBSD qemu-ga has strange behavior - in default config (when -m is not present) I see method - isa-serial. But in VM config - virtio-serial. And when I set virtio-serial in qemu-ga config, qemu-ga can't get any request from oVirt.
              qemu-ga -d -v -l /var/log/qemu-ga.log -m virtio-serial - does not work
              qemu-ga -d -v -l /var/log/qemu-ga.log - works with some restrictions in info
                Ok, the next thing I would test here is whether it works as expected in FreeBSD 12.3.
                Is this an upstream regression or something we are doing in pfSense specifically.
                gofaizenG 2 Replies Last reply Reply Quote 0
                • gofaizenG Offline
                  Today I will try FreeBSD 12 on ovirt.
                  There is qcow image on download.freebsd.org
                  I will try clear iso and qcow image.
                  • gofaizenG Offline
                    I tried qemu-ga in FreeBSD 12.3 - working as expected.
                      Hmm, so something different about our filesystem perhaps?
                      Permissions issue?
                      Same qemu-agent version?
                      There can't be much different there.
                      gofaizenG 4 Replies Last reply Reply Quote 0
                      • gofaizenG Offline
                        On FreeBSD 12.3 - qemu-ga -V
                        QEMU Guest Agent 5.0.1
                        On pfSense - qemu-ga -V
                        Command line on FreeBSD - qemu-ga -m virtio-serial -d -v -l /var/log/qemu-ga.log
                        Command line on pfSense - /usr/local/bin/qemu-ga -d -v -l /var/log/qemu-ga.log -b guest-get-fsinfo
                        • gofaizenG Offline
                          In FreeBSD I have run /usr/local/bin/qemu-ga -d -v -l /var/log/qemu-ga.log -b guest-get-fsinfo.
                          And everything works fine.
                          • gofaizenG Offline
                            Everything is similar in FreeBSD and pfSense
                            pfSense :
                            qemu_guest_agent_enable="YES"
                            qemu_guest_agent_flags="-d -v -l /var/log/qemu-ga.log -b "guest-get-fsinfo""
                            /usr/local/bin/qemu-ga -d -v -l /var/log/qemu-ga.log -b guest-get-fsinfo -D
                            [general]
                            daemon=true
                            method=isa-serial
                            path=/dev/vtcon/org.qemu.guest_agent.0
                            logfile=/var/log/qemu-ga.log
                            pidfile=/var/run/qemu-ga.pid
                            statedir=/var/run
                            verbose=true
                            retry-path=false
                            blacklist=guest-get-fsinfo
                            ls -l /dev/vtcon
                            total 0
                            lrwxr-xr-x 1 root wheel 10 Apr 25 15:24 com.redhat.spice.0 -> ../ttyV0.3
                            lrwxr-xr-x 1 root wheel 10 Apr 25 15:24 org.qemu.guest_agent.0 -> ../ttyV0.2
                            lrwxr-xr-x 1 root wheel 10 Apr 25 15:24 ovirt-guest-agent.0 -> ../ttyV0.1
                            ls -l /dev/ttyV*
                            crw------- 1 root wheel 0x34 Apr 25 15:24 /dev/ttyV0.1
                            crw------- 1 root wheel 0x35 Apr 28 14:34 /dev/ttyV0.2
                            crw------- 1 root wheel 0x36 Apr 25 15:24 /dev/ttyV0.3
                            FreeBSD :
                            qemu_guest_agent_flags="-d -v -l /var/log/qemu-ga.log -b guest-get-fsinfo"
                            [general]
                            daemon=true
                            method=isa-serial
                            statedir=/var/run
                            verbose=true
                            retry-path=false
                            ls -l /dev/vtcon
                            total 0
                            lrwxr-xr-x 1 root wheel 10 Apr 28 14:07 com.redhat.spice.0 -> ../ttyV0.3
                            lrwxr-xr-x 1 root wheel 10 Apr 28 14:07 org.qemu.guest_agent.0 -> ../ttyV0.2
                            lrwxr-xr-x 1 root wheel 10 Apr 28 14:07 ovirt-guest-agent.0 -> ../ttyV0.1
                            ls -l /dev/ttyV*
                            crw------- 1 root wheel 0x33 Apr 28 14:07 /dev/ttyV0.1
                            crw------- 1 root wheel 0x34 Apr 28 14:30 /dev/ttyV0.2
                            crw------- 1 root wheel 0x35 Apr 28 14:07 /dev/ttyV0.3
                              Ok, lets get a bug report open to track this.
                              What steps are required to replicate this?
                              • gofaizenG Offline
                                I have installed pfSense 2.5 from ISO on virtual machine in oVirt 4.4.5, then I have upgraded it to 2.6 from WEB interface. Then I added qemu-guest agent using this instruction - https://forum.netgate.com/topic/162083/pfsense-vm-on-proxmox-qemu-agent-installation
                                And got the problem, described above.
                                • gofaizenG Offline
                                  I want to try fresh installation pfSense 2.6 and test qemu-guest-agent.
                                  • gofaizenG Offline
                                    In fresh installation of pfSense 2.6 same result
                                      Hmm, struggling to replicate this in Proxmox.
                                      Using the linked instructions the guest-agent starts and gives me IP information only.
                                      Using the additional flags -b guest-get-fsinfo -D it fails to start at all.
                                      I will say this is unsupported/untested. It's unlikely to see any developer time.
                                        It returns correctly when run manually though:
                                        root@pve:~# qm agent 110 get-fsinfo
                                              "disk" : [],
                                              "mountpoint" : "/var/run",
                                              "name" : "tmpfs",
                                              "total-bytes" : 4194304,
                                              "type" : "tmpfs",
                                              "used-bytes" : 118784
                                              "disk" : [],
                                              "mountpoint" : "/",
                                              "name" : "/dev/mirror/pfSenseMirrors1a",
                                              "total-bytes" : 7259652096,
                                              "type" : "ufs",
                                              "used-bytes" : 1825689600
                                        Do you not see that?
                                          ....but that does seem to create zombie processes each time each run. OK.
                                            Ok, this actually looks like a known issue that is still open for some reason:
                                            https://github.com/aborche/qemu-guest-agent/issues/17
                                            https://bugs.freebsd.org/bugzilla/show_bug.cgi?id=260023
                                            Waiting to be fixed upstream.
