    Unable to ping a specific public ip when using pfsense not when bypass.
    39 Posts 5 Posters 4.0k Views
    • stephenw10S
      stephenw10 Netgate Administrator @okjello
      @okjello said in Unable to ping a specific public ip when using pfsense not when bypass.:
      Normally I would think my public ip is being blocked etc but i can unplug the uplink from cable modem to pfsense and plug my computer directly into cable modem and i can ping that ip all day long.
      Are you sure the public IP is the same in both situations?
      • johnpozJ
        @stephenw10 said in Unable to ping a specific public ip when using pfsense not when bypass.:
        Tell you right now they are not.. Why would a dhcp server give a different mac the same IP?
        He shows pfsense having a public IP in his wan state.. In what scenario would different macs from a dhcp server get the same IP?
        What makes more sense - IP X blocked by this server, or pfsense just deciding to not work on some random IP, but creates the outbound traffic, as you can see via the state..
        • stephenw10S
          Yup that seems most likely. Though you would think the laptop running pfSense would also get a different IP and be able to connect. Just unlucky maybe....
          • johnpozJ
            @stephenw10 where did he say he used a different laptop then previous? He just telling you what he is running pfsense on, and that he reinstalled it.
            He didn't say he changed the nic being plugged into the cable modem..
            • stephenw10S
              Ah, yes, I may have misread that.
              • johnpozJ
                @stephenw10 If I was handicapping this - just a blocked IP would be the super-duper AAA 5 Star lock of the decade.. While odds of it being pfsense would be the long shot of the century.. Like betting your Shetland pony is going to win the Kentucky derby ;) Make that not just the derby but the whole triple crown ;)
                • O
                  okjello @johnpoz
                  @johnpoz
                  I agree the whole thing is strange, I see the ping go I do not see reply, but would pfsense not have to pass the reply back? You can ping that ip on pfsense right? If i put my cisco rv042 back in place i can ping and get replies when i put pfsense in i can't. That is what i find strange.
                  • stephenw10S
                    Do you see the same public IP in use when using the Cisco though?
                    O 2 Replies Last reply Reply Quote 0
                    • johnpozJ
                      johnpoz LAYER 8 Global Moderator @okjello
                      Pfsense can not pass back what it doesn't get.. Now if you saw the ping go out, and saw the reply in your sniff but your client didn't get it - then that would be super odd.. But sniffing and see sent, and no reply just means you didn't get a reply, and nothing pfsense can do about that.
                      • O
                        okjello @stephenw10
                        I think so but will have to double check. I will get back to you
                        • O
                          okjello @johnpoz
                          @johnpoz
                          Very good point, I did check again and results same packet out not not in.
                          • O
                            okjello @stephenw10
                            Correct not the same public ip, similar but different ending or host ip.
                            • stephenw10S
                              Ah, OK. Try spoofing the WAN MAC of the Cisco in the pfSense WAN interface setup. It should then get the same IP and not be blocked.
                              • johnpozJ
                                @stephenw10 another option would be to just flip the interfaces so use the LAN interface as the wan and the wan interface as lan - this will give you different mac and different IP from your isp then the one that is not working.
                                But just spoofing the mac prob simpler solution to test.
                                • O
                                  okjello @johnpoz
                                  @johnpoz
                                  It has been a long day so hoping this makes sense, so please bare with me.
                                  I plugged laptop directly into modem and i got public ip different then pfsense was getting, similar but different laptop got 64.x.x.200 pf sense was 64.x.x.35
                                  This kinda makes sense i guess, I would have thought my public was assigned based on the cable modem mac ??
                                  So when i plugged into cable modem with laptop this time I didn't get a reply to the 138 problem ip. I know I did last time I tested as I have pic of a tracert completing.
                                  So I did power cycle the cable modem this time, and I'm honestly not sure if I did that before i tested with laptop or after.
                                  So this proves to me that pfsense is not the issue as you said all along.
                                  Now thinking maybe an isp / modem thing I pushed the reset on cable modem, now my wan public ip is 192.248.195.5 so i need to go plug into modem again and see if there is now a local configurable web page or something.
                                  The best part is pfsense must have noticed this private ip as it unchecked the "Block private networks" on the wan interface.
                                  I thought I would reconfigure my pfsenses interfaces so the usb nic was now lan and onboard nic now wan, so opposite. Why well just for the sake of change and to see if wan change based on wan nic mac.
                                  so after all of this with pfsense using a 192 as public i can ping the problem 138 and get reply.
                                  packet capture shows the modem replying, so no longer in transparent nat mode i guess.
                                  20:26:23.789157 IP 192.248.195.5 > 192.248.195.1: ICMP echo request, id 53692, seq 14128, length 9
                                  20:26:23.809728 IP 192.248.195.1 > 192.248.195.5: ICMP echo reply, id 53692, seq 14128, length 9
                                  I never configured the modem it came in nat mode, it has 1 lan port. This company Citywide resells the local bigger company {eastlink} cable service.
                                  So why my ciscorv042 router never had the issue and pfsense did im not sure i assume something wonkey with the nat on the cable modem? Unless im missing something and that in entirely possible!
                                  Hopefully me next reply will be i reconfigured the cable modem and all is well?...
                                  Thanks again for all the help and pointers.
                                  • stephenw10S
                                    192.248.x.x is not a private IP. It looks like you got a new public IP and it's not blocked.
                                    Probably the game server is running some blacklist blocking and the previous IP pfSense was getting was on one of them.
                                    O 1 Reply Last reply Reply Quote 0
                                    • O
                                      okjello @stephenw10
                                      ahh right its 192.248... sounds about right then.
                                      thanks everyone for help, I didn't check but was thinking i was double routered there for a min.
                                      • johnpozJ
                                        192.248
                                        The first half of that network atleast shows in LK, are you in Sri Lanka?
                                        • O
                                          okjello @johnpoz
                                          @johnpoz
                                          Interesting, I’m in Nova Scotia, Canada
