    Creating interface for IP range that isn't a CIDR range and Gateway not in IP Range
    5 Posts 2 Posters 698 Views 2 Watching
      klubar
      We recently installed FIOS with a 13 static addresses. We were given the following info about our IP addresses and gateway.
      IP range: 108.7.226.42-108.7.226.54 (13 addresses, but not a legitimate CIDR range
      Gateway: 108.7.226.1 (which is not in the IP range we were given above)
      I've done the following but it doesn't seem to work:
      1: Created a Gateway (Routing/Gateway/Edit) with the gateway address 108.7.226.1 and checked "Use non-local gateway through interface specific route"
      2: Created an interface with IPv4 address of 108.7.226.42/27 -- which includes my addresses and more; selected the Gateway 108.7.226.1
      Is this the right way to do this?
      When I try to route traffic thru this interface (by assigning it as priority 1 in the gateway groups it works for a few seconds and then seems to stop. I've verified the FIOS device is working by directly connecting a PC to ir.
        Are they actually routing those addresses to you or just providing them directly on your WAN?
        If it's the latter you need to add VIPs on your existing WAN with the static IPs and use them that way. That's relatively easy to test.
        https://docs.netgate.com/pfsense/en/latest/firewall/additional-ip-addresses.html#additional-static-ip-addresses
        I would also ask them to double check the address. That sure looks like it should be a /28 somewhere.
          klubar
          Thanks!!!!
          I believe the answer to "Are actually routing those addresses to you or just providing them directly on your WAN" is that they are actually routing those addresses.
          Here what I've done and it still works for a few seconds and then stops.
          • Confirmed that the IP range is really 108.7.226.42 - 54 (not a /28)!
          • Created the interface as IP address 108.7.226.42/32
          • Gateway 108.7.226.1 (not in range checked)
          • Created a VIP (IP Alias) on the interface, address 108.7.226.43/32
          • In Gate Groups set this interface to Tier 1 and the others to Tier 2 & Tier 3
          • Cleared APR table
          Diagnostics I've tried:
          • On status screen interface shows up
          • For the few seconds (maybe 20) that it's working, what's my ip shows 108.7.226.43
          • Unable to ping from external address either 108.7.226.42 or .43
          • No firewall rules
          • Interface shows Media 1000baseT <full-duplex,rxpause>; should I be concerned about the rxpause
          Any pointers or help would be super appreciated as I'm at the end of my rope!
            I assume from the way that you refer to the gateways that you have a different WAN interface and that is working correctly? Is that in a completely different subnet? Is it dynamic?
            If they really were routing those IPs to you wouldn't need to use a separate gateway. So I suspect they are in fact just providing the IPs on your WAN link directly. In which case you need to add VIPs on the WAN, you cannot create a new interface to use the IPs on.
            Try this:
            Remove the new interface you added.
            Add 108.7.226.42/24 as an IPAlias VIP on WAN.
            Try to ping out from it. Try to ping in to it whilst running a pcap on WAN for 108.7.226.42 and see if any traffic arrives.
            Add 108.7.226.1 as a gateway. Try to ping 108.7.226.1
            Did they give you any instructions on how to use these IPs?
              klubar
              It's always DNS
              After much experimenting (thanks @stephenw10) I figured out the problem. We use DNS Filter as our upstream DNS resolver. DNS Filter is tied to specific IP addresses and refuses to resolve if the request is coming from an "unknown" address.
              New network connection was unknown so some addresses that could be resolved locally or were cached worked. Thus why it worked for a few seconds. I finally figured it out when I tried entering IP addresses and that worked. (Hint, 1.1.1.1 is a good webpage to try if you are ever in this situation.)
              Sigh. My fault.
