    Unbound not responding on all chosen interfaces after reboot
    25 Posts 6 Posters 5.0k Views 7 Watching
      Gertjan @DBMandrake
      @DBMandrake
      Consider also using Unbound ACL rules.
        DBMandrake @Gertjan
        @Gertjan Much less secure, because unbound still receives and processes the packets and then decides whether they should be ignored or responded to based on its own configuration file.
        If there was ever a problem like a buffer overflow found in unbound it would be vulnerable to attack from clients that are "blocked" by the ACL list but allowed by firewall rules.
        Firewall rules on the other hand are absolute, and do not allow any packets to reach unbound for processing and would prevent such exploitation. So if you're going to bind to all interfaces (as in this workaround) why not just set access to unbound using firewall rules. I would not rely on unbounds own ACL's except to allow remote subnets which are normally denied by default. I would not rely on it as a means of blocking.
        GertjanG 1 Reply Last reply Reply Quote 1
          Gertjan @DBMandrake
          @DBMandrake
          Now that's what I call 'considering' 👍
            robotox
            Thank you for bringing the thread back to life!
            But in my case, the problem being with Outgoing Interfaces, rules won't apply to the firewall.
              robotox
              Now testing the SG-2100 with 23.05.1 for the similar setup but with multiple Wireguards instead of multiple OpenVPNs.
              Unbound starts correctly.
              I am guessing that Wireguard is faster than OpenVPN starting at boot.
              Thanks again.
