    Help configuring Split Routing of subnets with OpenVPN
    23 Posts 3 Posters 1.7k Views 3 Watching
      Jarhead @Malicair
      @malicair
      Just to add, you need to be more specific with these subnets and where they are.
      As in the pic:
      I highly doubt you LAN has two subnets so there's no way they can both be the source on the LAN interface.
      You only have a WAN and 3 other interfaces yet you list 5 subnets. Where are they?
        Malicair @viragomann
        @viragomann
        I have reached out to the VPN provider to assist with ensuring the server is responding... not sure how long that will take.
        • V Offline
          viragomann @Malicair
          @malicair
          9.9.9.9 is not responding to ping requests. So you cannot use this IP for monitoring. Use another one.
          For instance 1.1.1.1.
          Try to if you get a response on your PC.
          ping 1.1.1.1
          If it's okay use it for monitoring in the VPN gateway settings.
