    Wireguard routing works fine site2site but issues with direct client connection
    1 Posts 1 Posters 213 Views 1 Watching
      soupdiver
      I have two pfSense boxes connected via a wireguard tunnel and everything works great.
      Now I want to add another connection. A third client should join the network. That client should then be able to connect to machines behind the pfSense boxes.
      On one of the boxes I have added another wireguard client.
      The client can connect successfully. However there is some issue when trying to access machines in networks behind the pfSense boxes.
      wg network: 10.250.0.0/16
      ip machine a: 192.168.200.1
      ip machine b: 10.240.0.2
      machine a connects through wireguard and can access 10.240.0.1, which is the pfSense box but can not acces 10.240.0.2. From pfSense itself I can reach the .2
      Interestingly a ping from 10.240.0.2 to 192.168.200.1 works just fine.
      Trying to access 10.240.0.2 without a direct wg connection but transparently behind a pfSense box just works as expected.
      Any ideas? Is there something different when it comes to routing and wireguard?
