    Poor wifi performance after upgrade of mesh system
    46 Posts 7 Posters 10.4k Views 7 Watching
    • E Offline
      Elmojo @rcoleman-netgate
      @rcoleman-netgate OK. I haven't been able to get the upload directly option to work. I recall previously that I was told I had to upload images to a service and post the links, which is really annoying. I'd love to be able to just post them. I'll try again.
      What would you like me to do next, to get this sorted out?
      At the moment, I have the mesh plugged into my switch (served by the LAN interface), and it's working perfectly, but I would eventually like to have it served from OPT1 as described above, if possible. I do definitely need it to be on the same subnet as the rest of my network, though. If it will have to have a separate IP range from the LAN interface, that would be a deal breaker.
      J R 2 Replies Last reply Reply Quote 0
        Jarhead @Elmojo
        @elmojo Why use OPT1 at all??
        Just plug it into your switch and be done.
          rcoleman-netgate Netgate @Elmojo
          @elmojo said in Poor wifi performance after upgrade of mesh system:
          Are you planning on doing specific filtering/PBR or other routing on the MESH users? If not then keep it on the switch.
          You won't get this on OPT. You will need to make a bridge interface and that's not a good idea. pfSense is a router, not a switch.
          Ryan
          Wireless: Aruba, Ubiquiti
          E 1 Reply Last reply Reply Quote 1
          • E Offline
            @rcoleman-netgate Ok, I'll just leave it as-is and disable OPT1 again.
            It's been a while, so I can't recall the specifics, but when I first set this thing up, someone recommended that I have my wired clients on LAN through the switch, and my wireless clients (via mesh) on OPT1. I was under the impression that it was running that way all this time, but it seems that wasn't the case.
            What is OPT1 typically used for?
              @elmojo It would be an additional network... you can have them that way but they're on different broadcast domains -- so things that require broadcast calls (like streaming devices, or backup solutions) don't work and require other tools to work like avahi.
              I use VLANs and single interfaces and APs that support VLANs.
              Ryan
              • Dobby_D Offline
                Dobby_
                I was stumbling over that thread here and want to give my "two cents" on top of that.
                A real WiFi MESH network is using the HWMP (protocol)
                to guaranty a good working together between the devices
                with out no problems. "Some" vendors, as an example MikroTik, are setting up there own HWMP such HWMPplus
                from MikroTik, so it is not compatible to any other or normal HWMP protocol and only there own hardware,
                will work "nice" together. So if other vendors now also
                do something like that, configuring out there own version
                of the HWMP (protocol) it can be that then devices there
                are not only from one vendor, getting problems out here.
                #~. @Dobby
                Turris Omnia - 4 Ports - 2 GB RAM / TurrisOS 7 Release (Btrfs)
                PC Engines APU4D4 - 4 Ports - 4 GB RAM / pfSense CE 2.7.2 Release (ZFS)
                PC Engines APU6B4 - 4 Ports - 4 GB RAM / pfSense+ (Plus) 24.03_1 Release (ZFS)
