Problem with DNS over TLS
The dns settings in the “general setup” are ok.
I have tested several times with and without the custom settings. Only “with” allows me to browsing on the internet.
As far i can see all the rest seems working correcty : lookup, 1.1.1.1/ help, ect.
I don’t understand that your settings doesn’t working on my firewall. ??? -
@pietsnot56 the gui settings do what your doing in custom..
So I again set this back with simple click.. And then look in my unbound.conf
cat /var/unbound/unbound.conf
And you will see this
# Forwarding forward-zone: name: "." forward-tls-upstream: yes forward-addr: 1.1.1.1@853#cloudflare-dns.com forward-addr: 1.0.0.1@853#cloudflare-dns.comthen I undo the check marks and it is gone.
while what your doing is doing the same thing really - it makes no sense that you would have to use the custom options to get those settings into your unbound.conf file
You really should be setting the name, or your not actually going to verify your talking to clouldflare.. Are you not doing that with custom?
Version 2.6.0-RELEASE (amd64)
built on Mon Jan 31 19:57:53 UTC 2022
FreeBSD 12.3-STABLEThe system is on the latest version.
Version information updated at Sat Jan 21 14:35:40 -01 2023DNS Server Settings in General setup
DNS Servers
1.1.1.1
cloudfare-dns.com
1.0.0.1
cloudfare-dns.com
DNS Resolution BehaviorUse local DNS (127.0.0.1), ignore remote DNS Servers
A) Config file
1 ) this is what i have with the "custom settings on" in the config file.
Domain overrides
include: /var/unbound/domainoverrides.conf
Forwarding
forward-zone:
forward-addr: 1.1.1.1@853#cloudfare-dns.com
forward-addr: 1.0.0.1@853#cloudfare-dns.comUnbound custom options
server:
private-domain:"plex.direct"
forward-zone:
forward-ssl-upstream: yes
server:include: /var/unbound/pfb_dnsbl.*conf- by erasing the custom settings:
Domain overrides
Forwarding
forward-zone:
server:
server:include: /var/unbound/pfb_dnsbl.*conf3 ) by unchecking "use SSL/TLS for outgoing..."
Domain overrides
Forwarding
forward-zone:
forward-addr: 1.0.0.1B) error file with Use SSL/TLS for outgoing DNS Queries to Forwarding Servers checked on and without custm settings.
IP6 ????Can this help you to expain?
Unbound Configuration
Server configuration
server:
chroot: /var/unbound
username: "unbound"
directory: "/var/unbound"
pidfile: "/var/run/unbound.pid"
use-syslog: yes
port: 53
verbosity: 1
hide-identity: yes
hide-version: yes
harden-glue: yes
do-ip4: yes
do-ip6: yes
do-udp: yes
do-tcp: yes
do-daemonize: yes
module-config: "iterator"
unwanted-reply-threshold: 0
num-queries-per-thread: 4096
jostle-timeout: 200
infra-host-ttl: 900
infra-cache-numhosts: 10000
outgoing-num-tcp: 10
incoming-num-tcp: 10
edns-buffer-size: 512
cache-max-ttl: 86400
cache-min-ttl: 0
harden-dnssec-stripped: yes
msg-cache-size: 4m
rrset-cache-size: 8mnum-threads: 4
msg-cache-slabs: 4
rrset-cache-slabs: 4
infra-cache-slabs: 4
key-cache-slabs: 4
outgoing-range: 4096
#so-rcvbuf: 4mprefetch: no
prefetch-key: no
use-caps-for-id: no
serve-expired: no
aggressive-nsec: noStatistics
Unbound Statistics
statistics-interval: 0
extended-statistics: yes
statistics-cumulative: yesTLS Configuration
tls-cert-bundle: "/etc/ssl/cert.pem"
tls-port: 853
tls-service-pem: "/var/unbound/sslcert.crt"
tls-service-key: "/var/unbound/sslcert.key"Interface IP(s) to bind to
interface-automatic: no
interface: 0.0.0.0
interface: 0.0.0.0@853
interface: ::0
interface: ::0@853Outgoing interfaces to be used
outgoing-interface: 178.116.127.35
DNS Rebinding
For DNS Rebinding prevention
private-address: 127.0.0.0/8
private-address: 10.0.0.0/8
private-address: ::ffff:a00:0/104
private-address: 172.16.0.0/12
private-address: ::ffff:ac10:0/108
private-address: 169.254.0.0/16
private-address: ::ffff:a9fe:0/112
private-address: 192.168.0.0/16
private-address: ::ffff:c0a8:0/112
private-address: fd00::/8
private-address: fe80::/10Set private domains in case authoritative name server returns a Private IP address
Access lists
include: /var/unbound/access_lists.conf
Static host entries
include: /var/unbound/host_entries.conf
dhcp lease entries
include: /var/unbound/dhcpleases_entries.conf
Domain overrides
Forwarding
forward-zone:
forward-addr: 2606:4700:4700::1111@853#cloudflare-dns.com
forward-addr: 2606:4700:4700::1001@853#cloudflare-dns.comUnbound custom options
server:
private-domain: "plex.direct"Remote Control Config
include: /var/unbound/remotecontrol.conf
@pietsnot56 said in Problem with DNS over TLS:
IP6 ????
Where are you putting in IPv6? I do see it in your output you posted.
And looks like you have stuff in there twice
forward-zone: name: "." forward-tls-upstream: yes forward-addr: 1.1.1.1@853#cloudfare-dns.com forward-addr: 1.0.0.1@853#cloudfare-dns.com Unbound custom options server: private-domain:"plex.direct" server:include: /var/unbound/pfb_dnsbl.*conf 3 ) by unchecking "use SSL/TLS for outgoing..." Domain overrides include: /var/unbound/domainoverrides.conf Forwarding forward-zone: name: "." forward-addr: 1.1.1.1 forward-addr: 1.0.0.1One would be with tls the other would not be.. You got something messed up that is for sure..
Your info might be easier to read if you used the code option for text so it in specific box vs just long running text..
@johnpoz said in Problem with DNS over TLS:
"code option for text"
how or where can you chose this option? -
that's with custom settings on config file########################## # Unbound Configuration ########################## ## # Server configuration ## server: chroot: /var/unbound username: "unbound" directory: "/var/unbound" pidfile: "/var/run/unbound.pid" use-syslog: yes port: 53 verbosity: 1 hide-identity: yes hide-version: yes harden-glue: yes do-ip4: yes do-ip6: yes do-udp: yes do-tcp: yes do-daemonize: yes module-config: "iterator" unwanted-reply-threshold: 0 num-queries-per-thread: 4096 jostle-timeout: 200 infra-host-ttl: 900 infra-cache-numhosts: 10000 outgoing-num-tcp: 10 incoming-num-tcp: 10 edns-buffer-size: 512 cache-max-ttl: 86400 cache-min-ttl: 0 harden-dnssec-stripped: yes msg-cache-size: 4m rrset-cache-size: 8m num-threads: 4 msg-cache-slabs: 4 rrset-cache-slabs: 4 infra-cache-slabs: 4 key-cache-slabs: 4 outgoing-range: 4096 #so-rcvbuf: 4m prefetch: no prefetch-key: no use-caps-for-id: no serve-expired: no aggressive-nsec: no # Statistics # Unbound Statistics statistics-interval: 0 extended-statistics: yes statistics-cumulative: yes # TLS Configuration tls-cert-bundle: "/etc/ssl/cert.pem" # Interface IP(s) to bind to interface-automatic: yes interface: 0.0.0.0 interface: ::0 # Outgoing interfaces to be used outgoing-interface: 178.116.127.35 # DNS Rebinding # For DNS Rebinding prevention private-address: 127.0.0.0/8 private-address: 10.0.0.0/8 private-address: ::ffff:a00:0/104 private-address: 172.16.0.0/12 private-address: ::ffff:ac10:0/108 private-address: 169.254.0.0/16 private-address: ::ffff:a9fe:0/112 private-address: 192.168.0.0/16 private-address: ::ffff:c0a8:0/112 private-address: fd00::/8 private-address: fe80::/10 # Set private domains in case authoritative name server returns a Private IP address # Access lists include: /var/unbound/access_lists.conf # Static host entries include: /var/unbound/host_entries.conf # dhcp lease entries include: /var/unbound/dhcpleases_entries.conf # Domain overrides include: /var/unbound/domainoverrides.conf # Forwarding forward-zone: name: "." forward-tls-upstream: yes forward-addr: 1.1.1.1@853#cloudfare-dns.com forward-addr: 1.0.0.1@853#cloudfare-dns.com # Unbound custom options server: private-domain:"plex.direct" forward-zone: name:"." forward-ssl-upstream: yes forward-addr: 1.1.1.1@853 forward-addr: 1.0.0.1@853 server:include: /var/unbound/pfb_dnsbl.*conf ### # Remote Control Config ### include: /var/unbound/remotecontrol.confidem error file``
########################## # Unbound Configuration ########################## ## # Server configuration ## server: chroot: /var/unbound username: "unbound" directory: "/var/unbound" pidfile: "/var/run/unbound.pid" use-syslog: yes port: 53 verbosity: 1 hide-identity: yes hide-version: yes harden-glue: yes do-ip4: yes do-ip6: yes do-udp: yes do-tcp: yes do-daemonize: yes module-config: "iterator" unwanted-reply-threshold: 0 num-queries-per-thread: 4096 jostle-timeout: 200 infra-host-ttl: 900 infra-cache-numhosts: 10000 outgoing-num-tcp: 10 incoming-num-tcp: 10 edns-buffer-size: 512 cache-max-ttl: 86400 cache-min-ttl: 0 harden-dnssec-stripped: yes msg-cache-size: 4m rrset-cache-size: 8m num-threads: 4 msg-cache-slabs: 4 rrset-cache-slabs: 4 infra-cache-slabs: 4 key-cache-slabs: 4 outgoing-range: 4096 #so-rcvbuf: 4m prefetch: no prefetch-key: no use-caps-for-id: no serve-expired: no aggressive-nsec: no # Statistics # Unbound Statistics statistics-interval: 0 extended-statistics: yes statistics-cumulative: yes # TLS Configuration tls-cert-bundle: "/etc/ssl/cert.pem" tls-port: 853 tls-service-pem: "/var/unbound/sslcert.crt" tls-service-key: "/var/unbound/sslcert.key" # Interface IP(s) to bind to interface-automatic: no interface: 0.0.0.0 interface: 0.0.0.0@853 interface: ::0 interface: ::0@853 # Outgoing interfaces to be used outgoing-interface: 178.116.127.35 # DNS Rebinding # For DNS Rebinding prevention private-address: 127.0.0.0/8 private-address: 10.0.0.0/8 private-address: ::ffff:a00:0/104 private-address: 172.16.0.0/12 private-address: ::ffff:ac10:0/108 private-address: 169.254.0.0/16 private-address: ::ffff:a9fe:0/112 private-address: 192.168.0.0/16 private-address: ::ffff:c0a8:0/112 private-address: fd00::/8 private-address: fe80::/10 # Set private domains in case authoritative name server returns a Private IP address # Access lists include: /var/unbound/access_lists.conf # Static host entries include: /var/unbound/host_entries.conf # dhcp lease entries include: /var/unbound/dhcpleases_entries.conf # Domain overrides include: /var/unbound/domainoverrides.conf # Forwarding forward-zone: name: "." forward-tls-upstream: yes forward-addr: 1.1.1.1@853#cloudflare-dns.com forward-addr: 1.0.0.1@853#cloudflare-dns.com forward-addr: 2606:4700:4700::1111@853#cloudflare-dns.com forward-addr: 2606:4700:4700::1001@853#cloudflare-dns.com # Unbound custom options server:include: /var/unbound/pfb_dnsbl.*conf server: private-domain: "plex.direct" ### # Remote Control Config ### include: /var/unbound/remotecontrol.conf ```sometimes forward-addr: 1.1.1.1@853#cloudfare-dns.com with #cloudfare-dns.com at the end and in the custom settings : forward-addr: 1.1.1.1@853`` without #cloudfare-dns.com. can this help us to find the reason? -
Thanks everybody,
I founded my error : a typo in the Dnsname!
This case can be closed.
