    System General Logs flooded
    24 Posts 6 Posters 2.8k Views 5 Watching
      Traveler @Ramosel
      @Ramosel It definitely was still needed. The line made the logs quiet.
        Ramosel @Traveler
        @Traveler said in System General Logs flooded:
        Thanks for the info. I guess I need to edit the file when I build my new install stick.
        Stephen, since this affects Netgate hardware, is there any effort being put into testing for the affected hardware and fixing the issue on the fly? Or will this just always be a problem from now on?
        Not complaining, just trying to figure out what I need to put into my recovery docs or not.
        Rick
          Yes, it's fixed 'correctly' upstream now. it just wasn't accepted soon enough to be included in 23.05.1.
          https://reviews.freebsd.org/D39966
          It will be fixed in 23.09.
            Ramosel @stephenw10
            @stephenw10 said in System General Logs flooded:
            You guys are the BEST.
            Thanks,
            Rick
