    Need help to configure pfsense + Cisco switch + vlans
    24 Posts 3 Posters 2.0k Views 4 Watching
      mvikman @dvb
      @dvb said in Need help to configure pfsense + Cisco switch + vlans:
      I was just tring to ping "vlan10 gateway" -> 192.168.10.254 but it fails. For this, no rule is needed beause we stay on OSI layer 2 (correct me if I am wrong).
      Yes, the gateway is in the same address space, but it is a pfsense interface and the firewall rules apply to traffic incoming to that interface.
      The default action is "deny all", so the interface ip will not respond to ping unless you create rule to allow it.
      pfSense Plus 25.07.1-RELEASE (amd64)
      Dell Optiplex 7040 SFF
      Core i5-6500, 24GB RAM, 2x 240GB SSD (ZFS Mirror)
      HPE 561T (X540-AT2), 2-port 10Gb RJ45
      HPE 562SFP+ (X710-DA2), 2-port 10Gb SFP+
        dvb @mvikman
        @mvikman said in Need help to configure pfsense + Cisco switch + vlans:
        OK I understood !
        I just created these two rules (to ping from host and from laptop). No succes, ping still fails. Any idea ?
        text alternatif
        text alternatif
        • johnpozJ Online
          johnpoz LAYER 8 Global Moderator @dvb
          @dvb for one you have the pvid on port 8 as 1, that should be 10.. Or no nothing is ever going to work.. laptop sends traffic and port puts it on vlan 1..
          Also your firewall rules - you don't need that rule from address to net.. Rules are only evaluated as traffic enters the internet from the network..
            dvb @johnpoz
            @johnpoz said in Need help to configure pfsense + Cisco switch + vlans:
            I tried one untagged vlan per port, all is working perfect :
            text alternatif
            Thank you very much for your support and advice !
