    Does not connect to switch after switch reset
    35 Posts 3 Posters 2.1k Views
    • rikinn55R
      rikinn55 @stephenw10
      Yes it stays up every time. Seems a reboot of the Qotom is what is required. I tried reboot the TP Link but that failed getting it to relink.
      • rikinn55R
        Didn't answer the first question. Keep in mind PfS isn't doing anything with ports 2-4. So if I pulg and unplug from them I always get a link right away. I have not set PfS to use any of those ports as LAN yet.
        • stephenw10S
          Ok, well first try re-assigning LAN as a different NIC and make sure that behaves the same.
          The only time I've anything like this was when setting igc to 'autoselect' rather than 'default' in the config after having linked at 1G.
          I note I do have hardware checksum off-loading disabled on test devices here. I wouldn't expect that to make any difference to linking but wort trying.
          You can check the sysctls for igc1 like:
          23.01-RELEASE][root@4100.stevew.lan]/root: sysctl hw.igc
          hw.igc.max_interrupt_rate: 8000
          hw.igc.eee_setting: 1
          hw.igc.rx_process_limit: 100
          hw.igc.sbp: 1
          hw.igc.smart_pwr_down: 0
          hw.igc.rx_abs_int_delay: 66
          hw.igc.tx_abs_int_delay: 66
          hw.igc.rx_int_delay: 0
          hw.igc.tx_int_delay: 66
          hw.igc.disable_crc_stripping: 0
          [23.01-RELEASE][root@4100.stevew.lan]/root: sysctl dev.igc.0
          dev.igc.0.wake: 0
          dev.igc.0.interrupts.rx_desc_min_thresh: 0
          dev.igc.0.interrupts.asserts: 4030
          dev.igc.0.mac_stats.tso_txd: 0
          dev.igc.0.mac_stats.tx_frames_1024_1522: 0
          dev.igc.0.mac_stats.tx_frames_512_1023: 0
          dev.igc.0.mac_stats.tx_frames_256_511: 3163
          dev.igc.0.mac_stats.tx_frames_128_255: 0
          dev.igc.0.mac_stats.tx_frames_65_127: 0
          dev.igc.0.mac_stats.tx_frames_64: 22
          dev.igc.0.mac_stats.mcast_pkts_txd: 22
          dev.igc.0.mac_stats.bcast_pkts_txd: 3163
          dev.igc.0.mac_stats.good_pkts_txd: 3185
          dev.igc.0.mac_stats.total_pkts_txd: 3185
          dev.igc.0.mac_stats.good_octets_txd: 1108458
          dev.igc.0.mac_stats.good_octets_recvd: 0
          dev.igc.0.mac_stats.rx_frames_1024_1522: 0
          dev.igc.0.mac_stats.rx_frames_512_1023: 0
          dev.igc.0.mac_stats.rx_frames_256_511: 0
          dev.igc.0.mac_stats.rx_frames_128_255: 0
          dev.igc.0.mac_stats.rx_frames_65_127: 0
          dev.igc.0.mac_stats.rx_frames_64: 0
          dev.igc.0.mac_stats.mcast_pkts_recvd: 0
          dev.igc.0.mac_stats.bcast_pkts_recvd: 0
          dev.igc.0.mac_stats.good_pkts_recvd: 0
          dev.igc.0.mac_stats.total_pkts_recvd: 0
          dev.igc.0.mac_stats.xoff_txd: 0
          dev.igc.0.mac_stats.xoff_recvd: 0
          dev.igc.0.mac_stats.xon_txd: 0
          dev.igc.0.mac_stats.xon_recvd: 0
          dev.igc.0.mac_stats.alignment_errs: 0
          dev.igc.0.mac_stats.crc_errs: 0
          dev.igc.0.mac_stats.recv_errs: 0
          dev.igc.0.mac_stats.recv_jabber: 0
          dev.igc.0.mac_stats.recv_oversize: 0
          dev.igc.0.mac_stats.recv_fragmented: 0
          dev.igc.0.mac_stats.recv_undersize: 0
          dev.igc.0.mac_stats.recv_no_buff: 0
          dev.igc.0.mac_stats.missed_packets: 0
          dev.igc.0.mac_stats.defer_count: 0
          dev.igc.0.mac_stats.sequence_errors: 0
          dev.igc.0.mac_stats.symbol_errors: 0
          dev.igc.0.mac_stats.collision_count: 0
          dev.igc.0.mac_stats.late_coll: 0
          dev.igc.0.mac_stats.multiple_coll: 0
          dev.igc.0.mac_stats.single_coll: 0
          dev.igc.0.mac_stats.excess_coll: 0
          dev.igc.0.queue_rx_1.rx_irq: 0
          dev.igc.0.queue_rx_1.rxd_tail: 128
          dev.igc.0.queue_rx_1.rxd_head: 0
          dev.igc.0.queue_rx_0.rx_irq: 0
          dev.igc.0.queue_rx_0.rxd_tail: 128
          dev.igc.0.queue_rx_0.rxd_head: 0
          dev.igc.0.queue_tx_1.tx_irq: 0
          dev.igc.0.queue_tx_1.txd_tail: 0
          dev.igc.0.queue_tx_1.txd_head: 0
          dev.igc.0.queue_tx_0.tx_irq: 0
          dev.igc.0.queue_tx_0.txd_tail: 222
          dev.igc.0.queue_tx_0.txd_head: 222
          dev.igc.0.fc_low_water: 32752
          dev.igc.0.fc_high_water: 32768
          dev.igc.0.rx_control: 71335966
          dev.igc.0.device_control: 1478231617
          dev.igc.0.watchdog_timeouts: 0
          dev.igc.0.rx_overruns: 0
          dev.igc.0.link_irq: 66
          dev.igc.0.dropped: 0
          dev.igc.0.eee_control: 1
          dev.igc.0.itr: 488
          dev.igc.0.tx_abs_int_delay: 66
          dev.igc.0.rx_abs_int_delay: 66
          dev.igc.0.tx_int_delay: 66
          dev.igc.0.rx_int_delay: 0
          dev.igc.0.rs_dump: 0
          dev.igc.0.reg_dump: General Registers
          	CTRL	 581c0641
          	STATUS	 40780683
          	CTRL_EXIT	 10000040
          Interrupt Registers
          	ICR	 00000000
          RX Registers
          	RCTL	 0440801e
          	RDLEN	 00004000
          	RDH	 00000000
          	RDT	 00000080
          	RXDCTL	 02040808
          	RDBAL	 02392000
          	RDBAH	 00000000
          TX Registers
          	TCTL	 a503f0fa
          	TDBAL	 02376000
          	TDBAH	 00000000
          	TDLEN	 00004000
          	TDH	 000000de
          	TDT	 000000de
          	TXDCTL	 0201011f
          	TDFH	 00000000
          	TDFT	 00000000
          	TDFHS	 00000000
          	TDFPC	 00000000
          dev.igc.0.fc: 3
          dev.igc.0.debug: -1
          dev.igc.0.nvm: -1
          dev.igc.0.iflib.rxq1.rxq_fl0.buf_size: 2048
          dev.igc.0.iflib.rxq1.rxq_fl0.credits: 128
          dev.igc.0.iflib.rxq1.rxq_fl0.cidx: 0
          dev.igc.0.iflib.rxq1.rxq_fl0.pidx: 128
          dev.igc.0.iflib.rxq1.cpu: 1
          dev.igc.0.iflib.rxq0.rxq_fl0.buf_size: 2048
          dev.igc.0.iflib.rxq0.rxq_fl0.credits: 128
          dev.igc.0.iflib.rxq0.rxq_fl0.cidx: 0
          dev.igc.0.iflib.rxq0.rxq_fl0.pidx: 128
          dev.igc.0.iflib.rxq0.cpu: 0
          dev.igc.0.iflib.txq1.r_abdications: 0
          dev.igc.0.iflib.txq1.r_restarts: 0
          dev.igc.0.iflib.txq1.r_stalls: 0
          dev.igc.0.iflib.txq1.r_starts: 0
          dev.igc.0.iflib.txq1.r_drops: 0
          dev.igc.0.iflib.txq1.r_enqueues: 0
          dev.igc.0.iflib.txq1.ring_state: pidx_head: 0000 pidx_tail: 0000 cidx: 0000 state: IDLE
          dev.igc.0.iflib.txq1.txq_cleaned: 0
          dev.igc.0.iflib.txq1.txq_processed: 0
          dev.igc.0.iflib.txq1.txq_in_use: 0
          dev.igc.0.iflib.txq1.txq_cidx_processed: 0
          dev.igc.0.iflib.txq1.txq_cidx: 0
          dev.igc.0.iflib.txq1.txq_pidx: 0
          dev.igc.0.iflib.txq1.no_tx_dma_setup: 0
          dev.igc.0.iflib.txq1.txd_encap_efbig: 0
          dev.igc.0.iflib.txq1.tx_map_failed: 0
          dev.igc.0.iflib.txq1.no_desc_avail: 0
          dev.igc.0.iflib.txq1.mbuf_defrag_failed: 0
          dev.igc.0.iflib.txq1.m_pullups: 0
          dev.igc.0.iflib.txq1.mbuf_defrag: 0
          dev.igc.0.iflib.txq1.cpu: 1
          dev.igc.0.iflib.txq0.r_abdications: 0
          dev.igc.0.iflib.txq0.r_restarts: 0
          dev.igc.0.iflib.txq0.r_stalls: 0
          dev.igc.0.iflib.txq0.r_starts: 3185
          dev.igc.0.iflib.txq0.r_drops: 0
          dev.igc.0.iflib.txq0.r_enqueues: 3185
          dev.igc.0.iflib.txq0.ring_state: pidx_head: 1137 pidx_tail: 1137 cidx: 1137 state: IDLE
          dev.igc.0.iflib.txq0.txq_cleaned: 6322
          dev.igc.0.iflib.txq0.txq_processed: 6362
          dev.igc.0.iflib.txq0.txq_in_use: 44
          dev.igc.0.iflib.txq0.txq_cidx_processed: 218
          dev.igc.0.iflib.txq0.txq_cidx: 178
          dev.igc.0.iflib.txq0.txq_pidx: 222
          dev.igc.0.iflib.txq0.no_tx_dma_setup: 0
          dev.igc.0.iflib.txq0.txd_encap_efbig: 0
          dev.igc.0.iflib.txq0.tx_map_failed: 0
          dev.igc.0.iflib.txq0.no_desc_avail: 0
          dev.igc.0.iflib.txq0.mbuf_defrag_failed: 0
          dev.igc.0.iflib.txq0.m_pullups: 7
          dev.igc.0.iflib.txq0.mbuf_defrag: 0
          dev.igc.0.iflib.txq0.cpu: 0
          dev.igc.0.iflib.override_nrxds: 0
          dev.igc.0.iflib.override_ntxds: 0
          dev.igc.0.iflib.use_logical_cores: 0
          dev.igc.0.iflib.separate_txrx: 0
          dev.igc.0.iflib.core_offset: 0
          dev.igc.0.iflib.tx_abdicate: 0
          dev.igc.0.iflib.rx_budget: 0
          dev.igc.0.iflib.disable_msix: 0
          dev.igc.0.iflib.override_qs_enable: 0
          dev.igc.0.iflib.override_nrxqs: 0
          dev.igc.0.iflib.override_ntxqs: 0
          dev.igc.0.iflib.driver_version: 1
          dev.igc.0.%parent: pci4
          dev.igc.0.%pnpinfo: vendor=0x8086 device=0x15f3 subvendor=0x8086 subdevice=0x0000 class=0x020000
          dev.igc.0.%location: slot=0 function=0 dbsf=pci0:4:0:0 handle=\_SB_.PCI0.PEX3.PXSX
          dev.igc.0.%driver: igc
          dev.igc.0.%desc: Intel(R) Ethernet Controller I225-V
          rikinn55R 1 Reply Last reply Reply Quote 0
          • rikinn55R
            Here are the sysctls:
            sysctl hw.igc.txt
            Now I did a test by changing PfS to use igc.2 in place of igc.1 attached are resulting files.
            After reboot.txt
            After unplug igc.2 and plug back in.txt
            As you will notice I experienced the same issue.
            Thanks for all your help.
            • stephenw10S
              Hmm, looks near identical to any igc port I have here.
              It does that when connected to anything? A host directly for example?
              rikinn55R 2 Replies Last reply Reply Quote 0
              • rikinn55R
                I will check that in the morning.
                • rikinn55R
                  Ran the test with my laptop (intel nic) same result. See attached
                  Log 12APR23-a.txt
                  • bingo600B
                    bingo600
                    I'm no FreeBSD/pfSense boot-log guru.
                    But wasn't it an 8-port Qotom ?
                    I only see it detect igc0..igc4 ... where are the last 3 net IF's ?
                    Could it be bad hw ?
                    /Bingo
                    pfSense+ 23.05.1 (ZFS)
                    QOTOM-Q355G4 Quad Lan.
                    • rikinn55R
                      rikinn55 @bingo600
                      @bingo600
                      I think that's what I said early on but it is a 5 port.
                      • stephenw10S
                        Can you get the log covering it start to fail after it has been stable?
                        So showing what is logged when you first disconnect and reconnect the cable.
                        • rikinn55R
                          The file show a fresh boot through disconnect and reconnect then another fresh boot to bring everything back up.
                          Log 12APR23-b.txt
                          • stephenw10S
                            Hmm, the only thing of any significance I see there is that when the interface comes up after boot it does so before check_reload_status runs. Later the order is reversed and the link bounces. However that's no different to the igc NICs in the 6100 or 4100.
                            Are you able to try a 2.7 snapshot there? It has slightly more recent code. I'm not aware of any updates that would affect igc but there may be something.
                            I can only imagine it has a different PHY and that is somehow seeing the link change.
                            • rikinn55R
                              I haven't given up. I got really busy and haven't had time to get back to fixing the problem. What I have decided to do is to format the drive and start over completely fresh. I didn't have anything setup that was beyond just getting on the internet so I have nothing to lose. If I remember right the problem started when I did a reset of the system and had it load factory defaults. But those defaults didn't include a few firewall settings which I entered myself. I can only imagine when I put in the firewall settings I messed something up. I believe we have more than proven the hardware is not the problem.
                              I hope I can get that done this week. I'm still swamped but just maybe I can get an hour and get this done.
                              • rikinn55R
                                rikinn55 @rikinn55
                                Sorry it took so long to get back to this. I did a complete reinstall of pfsense and now everything works as it should. No more port not reconnecting after a physical disconnect and reconnect. So, as I believed previously there was something not right in the settings when I tried to have pfsense go back to factory settings which wiped out all the firewall rules. My attempt to recreate those rules I believe is what broke things.
                                Thank you so much stephenw10 for your help. I learned alot working with you.
                                • stephenw10S
                                  Ah, good result.
