    Problems with pfsense 1.2.2 wan works but not lan
    3 Posts 2 Posters 2.1k Views
      tdksweden
      Hello everybody!
      Im having a little problem with my pfsense-installation.
      I use 2 NICs one onboard the motherboard of the computer (a dell gx50, small form factor) i think its a 3com NIC and i use a d-link dfe-530tx in the pci-slot.
      But i cant get the 530tx-card to work.
      i guess pfsense see the nic because it givs it a interface name
      plip0 (0) but i dont see the MAC on the card in the console.
      Its like this in the console
      WAN: xl0 <mac for="" the="" onboard="" nic=""><ip from="" my="" isp=""><dhcp>LAN plip0 (0) NONE
      I have tried diffrent nics a newer dfe-530tx (DL10030C) (rev C2) and a realtek (RTL8139)
      Still the same problem even if i set up the DHCP on the LAN-NIC it still says
      LAN plip0 (0) NONE
      So the question is, is it some hardware problem or pfsense-related?
      Hope you guys and gals can help me out!
      thanks in advance and i apologize for my bad english!</dhcp></ip></mac>
      • E Offline
        Eugene
        It should be supported by pfSense-1.2.2
        http://www.freebsd.org/releases/7.0R/hardware.html#PROC-I386
        Are you sure your PCI slot works?
        http://ru.doc.pfsense.org
          tdksweden
          damn i feel stupid right now  ;D i forgot to check the BIOS-settings. PCI-Slots where OFF … i changed it to ON and it works like a charm infact im typeing this through my pfsense-firewall
          thanks all! :)
