    changing NIC card for LAN side
    17 Posts 5 Posters 2.6k Views 4 Watching
      sstatjm
      If I change my spf+ nic card from 2port to 4 port for the LAN side of pfsense. Do I have to rebuild pfsense so it sees all 4 ports?
      I am connecting to a 8 port sfp+ aggregation switch to a 24 port POE switch all unifi switches
        SteveITS Rebel Alliance @sstatjm
        @sstatjm As long as it has a driver you should be fine. If it is a different driver hence interface names it will ask you to assign interfaces on boot at the console. Otherwise it will assume __0 = __0 and keep booting.
        Upvote 👍 helpful posts!
          sstatjm
          I saw that after a few reboots but haven't seen it again since. But only see 2 active ports of 4 . At one port I saw the old card information in it. Not any more thou.
          Also if the bracket is missing for the card. Would that be a problem?
            Without the bracket the card may move in the PCIe slot and become disconnected. Which is bad!
            What NIC is it?
            Do all 4 ports appear under pciconf -lv ?
              mvikman
              What's the bandwidth of the PCI-E bus?
              2-port SFP+ works with x4, but I think 4-port would require x8
              pfSense Plus 25.07.1-RELEASE (amd64)
              Dell Optiplex 7040 SFF
              Core i5-6500, 24GB RAM, 2x 240GB SSD (ZFS Mirror)
              HPE 561T (X540-AT2), 2-port 10Gb RJ45
              HPE 562SFP+ (X710-DA2), 2-port 10Gb SFP+
                sstatjm
                The motherboard is a ASRock H370M-ITX - PCI-Express 3.0 x16 Slot
                The nic is a Silicom PE310G4SPI9L-XR-CX3 Quad Port 10Gb SFP+ Ethernet Network Adapter Card
                how do I check for pciconf -lv in pfsense?
                  Run that command at the CLI. Or that particular command can be run via Diag > Command Prompt.
                    sstatjm
                    I only see these 2 for that card and the other 2 onboard nics
                    ix0@pci0:5:0:0: class=0x020000 rev=0x01 hdr=0x00 vendor=0x8086 device=0x10fb subvendor=0x1374 subdevice=0x1a08
                    vendor = 'Intel Corporation'
                    device = '82599ES 10-Gigabit SFI/SFP+ Network Connection'
                    class = network
                    subclass = ethernet
                    ix1@pci0:5:0:1: class=0x020000 rev=0x01 hdr=0x00 vendor=0x8086 device=0x10fb subvendor=0x1374 subdevice=0x1a08
                    class = network
                    subclass = ethernet
                      sstatjm
                      Do you think I have to rebuild pfsense for the other 2 ports to become active?
                        Hmm, I wouldn't expect a rebuild to make any difference there. If the NICs don't appear on the bus that's some low level incompatibility.
                        Can you test the card in something else?
                          sstatjm
                          yes I can do that. Will update shortly. Just to see if all 4 ports are active and not just 2?
                            sstatjm
                            tried it on my truenas scale box and only 2 ports show up - only 2 ports light on.
                            check the network settings in truenas only 2 ports show up there also
                              Yes, I'd expect to see 4 PCI devices shown even if they are not attached to a driver.
                                sstatjm
                                So does that mean I have got a bad card?
                                  It could just be a compatibility issue with that board. Or maybe you didn't look for 'none' devices in the pciconf output? That's how unattached devices are shown.
                                    Oh, missed your TrueNAS comment. That doesn't look good then. Especially since I believe TrueNAS is Linux based now so it's not a FreeBSD driver issue.
                                      sofmeright @sstatjm
                                      @sstatjm Curious... Did you ever get this sorted out? I am building out the 3rd node for a ceph cluster and planned to use it in Debian (Proxmox VE) and pass it thru to my VM of pfsense kinda like ive been doing on two other machines in a cluster + CARP setup :-\
