SG-4100 and SG-6100 same power consumption?
Hello,
If I’d get the 4100 it would be close to idle most of the time and I expect around 12W power draw.But I’m considering the 6100 as well, a bit torn actually. As these appliances share the form factor, would it be safe to assume identical power draw if both configured alike?
Thanks!
At close to idle it will be very close. But I still expect the 6100 to draw slightly more.
At higher loads though the 6100 will be higher.
Thank you. @stephenw10 . Another question: if I were to aim for a Max version, which has SSD storage instead of eMMC, am I correct to expect around 3-4W extra for the SSD power? I assume the SSD is on all the time, for writing to the system logs.
It's not something I've measured but, yes, I would expect a few Watts in the SSD.
