    Upgraded from 2.5.2 to 2.6 and WAN speed dropped from 600 to less than 200
    6 Posts 2 Posters 968 Views 3 Watching
      Heimire
      Hey,
      As stated in the subject, I upgraded to 2.6.
      No errors or issues during upgrade.
      Just before the upgrade I tested internet speed and it was around 600 but after upgrade the most Im getting is less than 200.
      Both modem and firewall rebooted but same issue.
      Any suggestion on where to start looking for issues?
        What hardware are you running on?
        • stephenw10S stephenw10 moved this topic from Problems Installing or Upgrading pfSense Software on
          Heimire @stephenw10
          Intel(R) Atom(TM) CPU E3845 @ 1.91GHz
          4 CPUs: 1 package(s) x 4 core(s)
          AES-NI CPU Crypto: Yes (active)
          QAT Crypto: No
          Intel NICs.
            Hmm, that should be easily capable of that unless you have numerous packages running?
            How are you testing?
            Do you see errors in Status > Interfaces?
              Heimire @stephenw10
              I apricate you responding. Perhaps I just need to blow out the current version and do a clean install.
              Testing from a computer using a speed test.
              When I plug into the modem and bypass the firewall I get full speed, pretty much the same as before the upgrade.
              Only package is the OpenVPN client export.
              No errors.
              IPv6 Link Local
              fe80::2e0:67ff:fe16:cda8%em0
              MTU
              1500
              Media
              1000baseT <full-duplex>
              In/out packets
              1902463/970673 (1.93 GiB/423.55 MiB)
              In/out packets (pass)
              In/out packets (block)
              4356/0 (583 KiB/0 B)
              In/out errors
              0/0
              Collisions
                Hmm, do you have any traffic shaping enabled?
                I assume those are igb NICs?
