    PfSense CE 2.7 --- Power Savings Setting 'Minimum' does not seem to work like before
    ce 2.7power savingsx86 hardware
    9 Posts 2 Posters 3.2k Views 2 Watching
    • E Offline
      emefff
      Dear developers and users!
      I just upgraded from CE 2.6 to 2.7 yesterday, as recommended, I uninstalled all packages and did a reboot before upgrading. Everything went flawlessly, thanks for that.
      Today I noticed the following: In 'Power Savings' I chose 'Minimum' for all entries, also in 2.5-2.6. My HP Prodesk SFF with Intel(R) Core(TM) i3-7100 CPU @ 3.90GHz used to run at 800MHz with these settings. Never once it increased the frequency, it was 'planted' at 800MHz.
      Now with 2.7 it acts more like an adaptive setting. Power consumption is 50% higher. It goes up to 3900MHz and CPU is @60°C occasionally (before: max. 40°C). Strangely enough, my traffic somewhat decreased over the last weeks.
      Is this a known issue, do you have any suggestions how I can resolve this? Sorry if posted in the wrong category,
      Thanks,
      Mario.
      • bingo600B Offline
        bingo600 @emefff
        @emefff
        FreeBSD 14+ , uses some other powersettings if you have a "Newer CPU" ...
        Have a look in the thread here.
        https://forum.netgate.com/post/1108902
        /Bingo
        If you find my answer useful - Please give the post a 👍 - "thumbs up"
        pfSense+ 23.05.1 (ZFS)
        QOTOM-Q355G4 Quad Lan.
        CPU  : Core i5 5250U, Ram : 8GB Kingston DDR3LV 1600
        LAN  : 4 x Intel 211, Disk  : 240G SAMSUNG MZ7L3240HCHQ SSD
        E 1 Reply Last reply Reply Quote 2
        • E Offline
          emefff @bingo600
          @bingo600 said in PfSense CE 2.7 --- Power Savings Setting 'Minimum' does not seem to work like before:
          Thanks a lot for your quick answer. I will try this and report back.
          Mario.
          • E Offline
            emefff
            Well, that was a quick solution. Thanks a lot. Here's what I did:
            In System Tunable I created the following entries, one for each CUP (=core):
            I did a reboot, but applying the changes seems to work without it. It does not run as low a freq as before, but for now that's ok for me.
            Thanks @bingo600 ,
            Mario.
            • E Offline
              emefff @emefff
              For completeness: the maximum value for power saving in dev.hwpstate_intel is 100 (https://man.freebsd.org/cgi/man.cgi?hwpstate_intel). This setting does not keep the freq at 800MHz as the 'Minimum' setting in 2.6 did. It's more like 1100-1440MHz-ish, playing a YT-video to generate some traffic. So my guess is, there is still room for improvement,
              Mario.
              • bingo600B Offline
                bingo600 @emefff
                @emefff
                The i3-7100 has 4 "cores" as HT counts.
                I made entries for cpu0 to cpu3
                To show that nice Temp Graph
                Goto Status -> Monitoring
                Press the Wrench to see/change settings (if not already shown)
                Press Display Advanced
                Fill the settings (System + Thermal)
                Press "+Add View" , and give the View a "meaningfull" name.
                It will take some time for the graph to show , especially if "1 Day" is selected.
                /Bingo
                E 1 Reply Last reply Reply Quote 1
                • E Offline
                  emefff @bingo600
                  @bingo600 thanks, I know. Mine has HT turned off, power consumption is even lower that way:
                  Thanks for the graphing stuff, I did not know that,
                  Mario.
                  • E Offline
                    emefff @emefff
                    Here's the graph from the last 24hours, sort of a proof of what happened. Even the downtimes are visible (upgrade yesterday and reboot today):
                    • bingo600B Offline
                      bingo600 @emefff
                      @emefff
                      That's kind'a as expected , based on my experience when upgrading to Plus 23.01
                      That's also based on FreeBSD v14
                      My home boxes uses i5-5250U , that CPU is to old to use the new "Speed/Power stuff" so those behaved as usual, using the "Old Power settings"
                      But my i3 test box was "hit" , and was what i described in the thread i pointed to.
                      /Bingo
                      • E emefff referenced this topic on
