    surfshark guide for pfsense wireguard
    Scheduled Pinned Locked Moved WireGuard
    32 Posts 9 Posters 9.5k Views 10 Watching
    • Bob.DigB Offline
      Bob.Dig LAYER 8 @rtorres
      @rtorres said in surfshark guide for pfsense wireguard:
      I did not include ANY kill switches like IVPN suggests (not too sure if the Surfshark had that on their guide).
      So there is one option in pfSense you really should tick: Skip rules when gateway is down (SystemAdvancedMiscellaneous)
      For my setup, it looks like BERLIN has continuous problems but also I have not seen the same flakiness now having a "Killswitch" for OpenWRT. So for me it could still be a problem in pfSense.
      • I Offline
        Irontalon @yucca1960
        @yucca1960
        Yes, I have a very good tutorial in PDF format specifically created for surfshark wireguard on Pfsense.
        Apparently you can't attach files here so I put it on my Google drive.
        [Bad link removed]
        • stephenw10S Online
          Your link is restricted, I can't open it.
            savostian333 @Irontalon
            @Irontalon said in surfshark guide for pfsense wireguard:
            @yucca1960
            snipped link
            It says "You need access"
            Can u please modify the settings to allow the access for all?
            • johnpozJ Online
              johnpoz LAYER 8 Global Moderator @savostian333
              @savostian333 you have a 1 post wonder give some random link to a pdf, Not sure why anyone would follow that link
              Bob.DigB S 2 Replies Last reply Reply Quote 1
              • Bob.DigB Offline
                Bob.Dig LAYER 8 @johnpoz
                @johnpoz But he also is. I would delete both users/posts if I would be in charge, better save than sorry.
                  Mmm, killed it for now. Let's see...
                    savostian333 @johnpoz
                    @johnpoz said in surfshark guide for pfsense wireguard:
                    I was interested. Is that an issue? 😕
                      It could be legit. Link was broken and we wait for an update from the poster....
                      • F Offline
                        flat4
                        danger will robinson, danger
                          The Party of Hell No
                          https://www.wundertech.net/how-to-set-up-wireguard-on-pfsense/
                          https://www.reddit.com/r/PFSENSE/comments/lmv1cp/how_to_setup_wireguard_on_pfsense_252102_with/
                          https://www.youtube.com/watch?v=CXFbEbzFEXw
                          https://www.paolotagliaferri.com/create-wireguard-vpn-tunnel-with-pfsense-2-5-0/
                          https://coygeek.com/docs/pfsense-wireguard/ - 404
                          These are the links I found most helpful.
                          T 1 Reply Last reply Reply Quote 2
                            The Party of Hell No @The Party of Hell No
                            @The-Party-of-Hell-No
                            Conversation I had with technician at Surf Shark about two WireGuard tunnels simultaneously:
                            another question can I use the same tunnel and have multiple gateways(Peers) going to different surfshark servers through the same tunnel?
                            Saul Buchanan
                            's avatar
                            Not at the same time, but you can use the same tunnel with different peers, yes.
                            Okay, can I create individual tunnels for each peer (Surfshark server) I wish to use as a gateways.
                            I have done this using the openvpn protocol
                            Saul Buchanan
                            's avatar
                            Essentially yes.
                            Isn't the problem generating keys for each tunnel?
                            Saul Buchanan
                            's avatar
                            Not really, as you can use the same private keys with multiple tunnels. I would just like to emphasize that multiple connections at a time from the same device will most likely encounter issues.
                            The challenge I ran into was thinking the endpoint port (51820) had to match the tunnel port.. It cannot be changed - obviously it is set by SurfShark, but it means both tunnels share the same endpoint port.
                            It seems to work:
                            • T The Party of Hell No referenced this topic on
