Problem Captive Portal pfSense 2.7 with allowed ip addresses
@TbW yes, the arrows are showing up and the bypass of the allowed ips also works
@wtasin OK thank you. I will try.
realmente funcionou fazendo da forma que você explicou, mas o controle de banda não funciona.
@TbW said in Problem Captive Portal pfSense 2.7 with allowed ip addresses:
Seems limited to 100 Mbit/s per user.
Do I need to show an example like this :
or like this :
Btw : I'm using 23.09, and I presume that 2.7.1 and 23.09 share the same kernel, kernel modules and and GUI.
S susobaco referenced this topic on
@Gertjan If you allow navigation by entering the mac address, the device is set up to 100 Mbit/s DW/UP.
