    DHCPv6 Static Leases and Multiple NICs (Ethernet + Wireless) - How to set uniquely per interface (DUID + IAID)
    3 Posts 2 Posters 537 Views 2 Watching
      rolfl
      Re: DHCPv6 Static Leases and Multiple NICs (Ethernet + Wireless) - How to set uniquely per interface (DUID + IAID)
      Can anyone respond to above?
      Currently if DHCPv6 static lease is specified and a computer has two interfaces both interfaces gets the same IPv6 address assigned.
      @trunet Did you find a resolution to this issue?
      • GertjanG Online
        Gertjan @rolfl
        @rolfl
        Aren't those not set maintained on the DHCPv6 (LAN) client device ?
        These are the ones on my Microsoft box :
        So, I tend to think : change them means : Microsoft support ?
        Or do you talk about the pfSense WAN side ?
          rolfl
          I can see the IAID shown on the LAN DHCPv6 lease status page, but when assigning static lease in the DHCPv6 server there is only DUID no IAID so both interfaces on the PC gets the same IPv6 assigned.
          See this post for full description
