SQUID and Load Balancing doesn't work!!!! I tried for a week but nothing :'(
You need direction out and source any.
You can even try with direction out and source WAN ip to try to tighten it. -
@ermal:
You can even try with direction out and source WAN ip to try to tighten it.I've tried the above suggestions without any luck.
On my testbed, I have 2 wans, currently wan2 is set as default gw, the interface is hooked up to a hub so that the interface shows as up as active, although the hub is not connected to anything. (I needed its modem for a production box)
wan1 is connected to a modem and not set for default gw.
I have tried almost everything, from unticking "Block private/bogon networks" to setting static IP and DNS on my client machine.
I hope the following can helps you track down the problem, if you need anymore information Ill be happy to help.
Routing tables
Internet:
Destination Gateway Flags Refs Use Netif Expire
default 78.xx.xx.xx UGS 2 70 fxp1 <–-wan2 gw set as default
10.0.0.0/24 link#10 U 0 0 re1_vl
10.0.0.1 link#10 UHS 0 0 lo0
10.0.1.0/24 link#11 U 0 0 re1_vl
10.0.1.1 link#11 UHS 0 0 lo0
10.0.2.0/24 link#12 U 0 0 re1_vl
10.0.2.1 link#12 UHS 0 0 lo0
10.0.20.0/24 link#13 U 0 0 re1_vl
10.0.20.1 link#13 UHS 0 0 lo0
78.xx.xx.xx/20 link#2 U 2 463 fxp1 <–-wan2 gw
78.xx.xx.xx link#2 UHS 0 0 lo0 <–-wan2 IP
94.xx.xx.xx/20 link#1 U 2 1051 fxp0 <–-wan1 gw
94.xx.xx.xx link#1 UHS 0 0 lo0 <–-wan1 IP
127.0.0.1 link#6 UH 0 19 lo0
127.0.0.2 127.0.0.1 UHS 0 0 lo0
192.168.5.0/24 link#3 U 1 25807 re0
192.168.5.1 link#3 UHS 0 0 lo0
192.168.50.0/24 link#9 U 0 0 re1_vl
192.168.50.1 link#9 UHS 0 0 lo0
208.67.220.220 94.xx.xx.xx UGHS 1 25 fxp0 <–-94.xx.xx.xx wan1 gw
208.67.222.222 78.xx.xx.xx UGHS 0 29 fxp1 <–-78.xx.xx.xx wan2 gwconfig.xml rule
<rule><id><type>pass</type>
<tag><tagged><direction>out</direction>
<quick>yes</quick>
<floating>yes</floating>
<max><max-src-nodes><max-src-conn><max-src-states><statetimeout><statetype>keep state</statetype>
<os><nosync><protocol>tcp</protocol>
<source>
<any><destination><any><port>80</port></any></destination>
<descr>Load Balance Squid</descr>
<gateway>multiwan</gateway></any></nosync></os></statetimeout></max-src-states></max-src-conn></max-src-nodes></max></tagged></tag></id></rule>pfctl -sr
NOTE: 94.xx.xx.xx is wan1 gwpass out quick route-to (fxp0 94.xx.xx.xx) inet proto tcp from any to any port = http flags S/SA keep state label "USER_RULE: Load Balance Squid"
pfctl -sa Filter rules:
Counters:
USER_RULE: Load Balance Squid 6 96 5040 0 0 96 5040
pfctl -s rules -vv
NOTE: 94.xx.xx.xx is wan1 gw@119 pass out quick route-to (fxp0 94.xx.xx.xx) inet proto tcp from any to any port = http flags S/SA keep state label "USER_RULE: Load Balance Squid"
[ Evaluations: 0 Packets: 0 Bytes: 0 States: 0 ]
[ Inserted: uid 0 pid 28028 ]rules.debug
pass out quick $multiwan proto tcp from any to any port 80 keep state label "USER_RULE: Load Balance Squid"
I dont know how much of the above is relevant, but I thought I'd post anyway ;D
Thanks in advance
Slam
Are you using Manual Outbound NAT?
pfctl -vvsr is the output i want to see actually.Do you have issues on traffic with this rule?
Please show me even a pfctl -vvsnWhile there can you try enable manual outbound NAT and add a rule with source any and external your wan1(94…../20) gw?
See if it works. -
Ive included output for the those commands
pfctl -vvsr - command1.txt
pfctl -vvsn - command2.txtI dont use outbound nat and dont even know how to use it, I got stuck when I tried to follow your comments, I've sent you a pm with details if you like access to the box yourself.
Slam
Check out now it should be ok from what i see!?
If you want to tighten you can change the any in the outbound nat rules at the end to the respective interfaces subnet.
Ive just gave it another go, my browser just sits there trying to access the internet without any luck
is it ok to leave those other rules in outbound nat? will they interfere with the rules I have for the interfaces? shall i reboot and try?
Slam
Just try out with static port ticked on those rules.
rebooted and still nothing
I tried connecting to redmine.pfsense.org with no luck and noticed this in https://pfsense/diag_dump_states.php
tcp 127.0.0.1:80 <- 69.64.6.27:80 <- 192.168.5.150:51417 ESTABLISHED:ESTABLISHED
Maybe Im just stupid, but isnt the flow meant to be like this?
tcp 69.64.6.27:80 <- 127.0.0.1:80 <- 192.168.5.150:51417 ESTABLISHED:ESTABLISHED
I appreciate the help you have given me, if it doesnt work with my setup then I guess nothing can be done about it, the box is still open if you want to poke around.
Thanks a lot
Slam
It wont work for https because its https and afaik squid package does not redirect https.
Sorry, I completely overlooked that, Ill test again later with a different setup.
Slam
What's the outcome of this?
Is it working as it's an important reference to get other stuff within pfSense (looking at you, DNS) doing the load balancing mambo.
For me, squid and load balancing works from what I can tell, but I didnt test in depth, however if the default wan interface goes down, then clients lose all internet connectivity, this was tested with squid set as transparent.
It could be something to do with my setup, but Ill test more properly at another time.
maybe you shoulf be try use tcp_ougoing_adress with the beta no need load balance and no loose conection the users just the webs you put in tcp outgoing rules
tcp_outgoing_address want detect the state of the link
Slam,
Can you fix this issue? I had the same problem today and I can´t fix anyway.
Is there any solution for this issue'?
I am also having this problem when the default gateway is down. all the clients could not able to access to internet.Thanks in advance
I am also having the same issue when one of my WANs went down. the clients could not able to access the internet.
Is there any solution for this issue?Thanks
I have found the problem:
The network:
ISP1|-192.168.0.1–--192.168.0.2-| |
|pfSense|-192.168.3.1----192.168.3.2-|Computer
ISP2|-192.168.1.1----192.168.1.2-| |Squid package is installed on pfSense.
On system gateway groups i setup a gateway "ALLISP" with Tier1 Tier1 for ISP1 & ISP2
I create a floating rule like this:
Interface: (None selected)
Direction: Out
Protocol: TCP
Source: ISP1 adresse (=192.168.0.2)
Destination Port: HTTP
Gateway: ISP2 (for the test, normally it's ALLISP)The client use the pfsense proxy.
I launch Google and... that don't work... page don't load
the packet is well redirected on ISP2 interface:
I run tcpdump on ISP2 interface and see this:
tcp port 80 from 192.168.0.2 to www.google.frThe problem is here, the source must be rewrite, the ISP2 Modem can't relay a packet with a 192.168.0 source... that must be 192.168.1...
What can we do?
I think your issue is related to mine: http://forum.pfsense.org/index.php/topic,28410.0.html
I begin to think there is something to do without outbound nat, but I don't know what. I'm still searching.
For those of you who still want to try this.
I added a fix which should be presented on latest snapshot to help with this.
