• BOARD RETIRED
    Pinned Locked
    82k Views
  • HEADS UP: Branch changed to RELENG_2_0 - You *must* fix your update URL!
    Pinned Locked
    27k Views
    jimpJ
    @onhel: It should also be noted if you are using gitsync in your updater settings to change branch name from master to RELENG_2_0 Unless you are using that to track IPv6, in which case you really do want master. :-) I wasn't aware anyone was tracking 2.0 on top of 2.0 with gitsync, not much of a point to that. Might hurt more than it helps in some cases, but that's debatable.
  • HEADS UP: Textdumps coming in next snapshots to aid debugging
    Pinned Locked
    15
    18k Views
    W
    The system crashed again with a kernel page fault at the same PC. Despite having set debug.ddb.textdump.pending=1 it didn't reboot automatically so Ityped in the commands in kdb.enter.panic one per line and then on reboot savecore reported it was writing textdump.tar. This system has a VIA C3 CPU and is running dmesg Copyright 1992-2010 The FreeBSD Project. Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 The Regents of the University of California. All rights reserved. FreeBSD is a registered trademark of The FreeBSD Foundation. FreeBSD 8.1-RELEASE-p2 #1: Mon Apr 18 23:21:20 EDT 2011     sullrich@FreeBSD_8.0_pfSense_2.0-snaps.pfsense.org:/usr/obj.pfSense/usr/pfSensesrc/src/sys/pfSense.8 i386 Timecounter "i8254" frequency 1193182 Hz quality 0 CPU: VIA Samuel 2 (797.74-MHz 686-class CPU)   Origin = "CentaurHauls"  Id = 0x673  Family = 6  Model = 7  Stepping = 3   Features=0x803035 <fpu,de,tsc,msr,mtrr,pge,mmx>real memory  = 268435456 (256 MB)</fpu,de,tsc,msr,mtrr,pge,mmx> I'll switch to a debug kernel as suggested.
  • Please give ARCH (i386/amd64) when reporting issues
    Pinned Locked
    6k Views
  • OpenVPN clients disabled after an update? Read this
    Pinned Locked
    8k Views
  • How to create an OpenVPN client to a public OpenVPN provider
    Pinned Locked
    56k Views
    Since you can traceroute correctly from the shell it's not the routing table or the default gateway… this is more likely an issue with your firewall rules, including the floating rules used by the traffic shaper. Be sure no rule specifies a gateway directly and uses the 'default' gateway which uses the routing table. Beyond that it might be your NAT setup (especially manual outbound NAT).
  • Package status
    Pinned Locked
    20k Views
  • OpenVPN for Remote User : A How to
    Pinned Locked
    61k Views
    @arriflex: Much of what is mentioned here is not necessary as the OpenVPN:Wizard gets much of it accomplished. Yeah this was written before that wizard existed.
  • 2.0 Known Issues
    Pinned Locked
    35k Views
  • HOW TO - EASY (wireless) bridge configuration in 2.0
    Pinned Locked
    33
    124k Views
    jimpJ
    @fastcon68: I used the blog steps and it worked.  But it was not quite what I was trying to do.  In version 1.2.3, I could bridge ports to a existing port.  Version 2 is quite different it takes a little more planning before you just jump in. The other version made it just a little bit easier to set up and be able to add and subtract ports. RC You can still bridge ports together by just adding them to the bridge, you don't have to assign the bridge interface. It's just better in the long run to do it that way. The main problem with failing to assign the bridge interface is that if the interface holding the IP goes down, the whole bridge goes down. When you have the bridge assigned and the IP on the bridge interface, any interface can go down without problems.
  • 2.0 configurations CANNOT BE DOWNGRADED
    Pinned Locked
    14k Views
  • Outbound Load Balancing is replaced.
    Pinned Locked
    32k Views
    You should now be able to build gateway groups easy with dynamic interfaces. The status gateways page, and status gateways groups page should list your dynamic interfaces. A gateways widget is also available. Feedback is sought here.
  • PfSense 2.0 doesn't hold USB wifi dongle configurations - fails at reboot
    Locked
    8k Views
    I see. Thank you. I think this would be a really good feature to add to the UI or maybe enable it by default.
  • Manual logout page
    Locked
    7k Views
  • Same gateway for two WAN interfaces (same isp) problem in pfsense 2.0
    Locked
    10k Views
    @cmb: Definitely won't be in 2.0, that's coming out next week. Greatly OT, but still. Really good news to hear
  • PfSense 2.0 RC3 (x64) blocking legitimate DNS traffic?
    Locked
    7k Views
    m0n0wall has an older version of dnsmasq and it's probably related to that if it's the DNS forwarder. I don't think ipfilter has any intelligence with DNS response sizes either. You'd have to see if the state is indeed still there, and check the response to see if it's sane and should match that state.
  • IPAD IPSec VPN
    Locked
    32k Views
    Even if vpn server says tunnel everything through vpn connection? so the route would be 0.0.0.0 0.0.0.0 vpn-gateway on the machine itself
  • Dhcpd: send_packet: No buffer space available
    Locked
    12k Views
    W
    What is the output of pfSense shell command netstat -m Perhaps you have had a temporary exhaustion of mbufs.
  • Observed differences between openvpn on RC1 and RC3
    Locked
    5k Views
    jimpJ
    That could only happen if you had an improper setup, like a site-to-site setup using a /30 which doesn't use the server directive, so it can't push routes. Use a larger tunnel network and it will work as you expect.
  • No Weblogin possible with "Cookies Disabled" …
    Locked
    jimpJ
    Should show an error now if cookie support is not detected. https://github.com/bsdperimeter/pfsense/commit/a2e90569ab481bc85f5b3be7a01cc1608b3d065a
