Thanks. I don't remember exactly what happened back then but the newer version of Suricata was available in the package list, but no new PF-update was listed. I then believed that it belonged to my current PF version. I reverted back to a snapshot, and all was good after then.
The problem I have now, is not related to above, since this time PF was updated to 2.7.2, and Suricata was updated automatically along with it.
@safe yeah there’s a separate bug/issue that hides the upgrade, what fun.
https://docs.netgate.com/pfsense/en/latest/releases/2-7-1.html#troubleshooting -
@kiokoman, @masons , and any others wishing to try a debug Suricata version:
Guys, I was finally able to get my pfSense 2.7.2 CE package builder repaired and updated so that I can resume building test packages.
If you would like to try and help isolate and indentify this Hyperscan bug, read on to see how you can assist --
I have produced a debug-enabled version of Suricata 7.0.2. It was compiled for pfSense CE 2.7.2, because that's all I have a builder for. But I suspect it will also load and run okay on pfSense Plus 23.09.1.
You will need to install the debug-enabled package manually using the CLI at a shell prompt on the firewall. You can obtain the shell prompt either directly on the console locally or via a remote SSH connection. Obviously this should be done on a firewall where you are currently experiencing the Hyperscan crash.
This test involves replacing only the binary portion of the Suricata package. The GUI component (
pfSense-pkg-suricata-7.0.2_2) will not be altered.WARNING: you should only try this on a test machine or one that you can quickly recover should something cause a major crash!!
Install the Debug-Enabled Suricata Binary Package
The debug-enabled Suricata binary package file is hosted on my Google Drive account here: https://drive.google.com/file/d/10lD0R907A1yQpn-aIewH8_GfPJiuVcIm/view?usp=sharing.
To begin, download the
suricata-7.0.2_6.pkgfile and transfer it to your firewall placing it in the/rootdirectory. IMPORTANT: make sure you transfer the file in binary (unaltered) form! So, if usingWinSCPfor the transfer from a Windows PC, choose "Binary" for the transfer type. -
Stop all running Suricata instances by executing this command from a shell prompt on the firewall:
/usr/local/etc/rc.d/suricata.sh stop- Install the update debug version of the Suricata binary using the command below at a shell prompt on the firewall:
pkg-static install -f /root/suricata-7.0.2_6.pkg4, If successful, restart Suricata by returning to the GUI and using the icons on the INTERFACES tab, or you can run the following command from the shell prompt:
/usr/local/etc/rc.d/suricata.sh startIf you experience a crash while running this debug build of Suricata, you can quickly grab some useful data by running this command on the core file from a shell prompt:
gdb /usr/local/bin/suricata /root/suricata.coreAfter it loads, type
btand ENTER to see a back trace. Post the displayed results back here. You can also runbt fullto produce a more detailed back trace. When finished, typeexitto quit the debugger.To Restore Your Original Setup
From the GUI, remove the Suricata package. This will remove the GUI package but may not remove the updated debug-enabled binary. The next step insures the debug binary is also removed.
When the package deletion from the GUI completes, exit to a shell prompt and delete the debug version of the binary using this command:
pkg-static delete suricata-7.0.2_6- Now return to the GUI and reinstall Suricata from the SYSTEM > PACKAGE MANAGER menu. This will reinstall the origina Suricata GUI and binary versions from the official pfSense repository.
@bmeeks
there is already a debug txt a couple of post before thisI can still try your version and let you know
[101255 - Suricata-Main] 2023-12-17 23:41:11 Notice: threads: Threads created -> RX: 1 W: 8 FM: 1 FR: 1 Engine started.
[368779 - RX#01-vmx2] 2023-12-17 23:41:11 Info: checksum: No packets with invalid checksum, assuming checksum offloading is NOT used
[368805 - W#04] 2023-12-17 23:41:37 Error: spm-hs: Hyperscan returned fatal error -1.
[368782 - W#01] 2023-12-17 23:41:37 Error: spm-hs: Hyperscan returned fatal error -1.crashed without generating /root/suricata.core
@kiokoman said in Suricata process dying due to hyperscan problem:
@bmeeks
Sorry, I missed that earlier. It is helpful as it points to a problem somewhere in Hyperscan itself and not so much in the custom blocking module. Curious how things work when the custom blocking module is disabled, though
.Nothing in your back trace results seems to have any relationship to the Legacy Blocking Module.
I was sort of afraid that might happen -- no core dump.
Refresh my memory on your NIC types (real or virtual) and which rule categories you are using. I want to try once more to duplicate the crash. I really should be able to since users are reporting it with a variety of NIC types (real and virtual), so I'm thinking the NIC is not important to the crash.
If you could post your
suricata.yamlfile for one of the crashing interfaces, that might help as well. I can import it directly into a virtual machine to see if I get the crash then. The file will be in/usr/local/etc/suricata/suricata_xxxx_yyyy/suricata.yamlwhere the "xxxx" and "yyyy" parts are the physical NIC name and a random UUID. And even better would be also posting the actual active rules file. It will be in/usr/local/etc/suricata/suricata_xxxx_yyyy/rules/suricata.rules.One other test you can try is changing the Run Mode for Suricata. The default is AutoFP. Try Workers and see if there is any change. Or if already using Workers, swap to AutoFP and test. This parameter is on the INTERFACE SETTINGS tab in the Performance section. Any change made requires Suricata to be restarted so it will see the change.
@bmeeks
i was thinking the same, i see no relationship to the Legacy Blocking Module, the only reference on gdb about alert-pf is on thread 2Thread 2 (LWP 179039 of process 2511 "IM#01"):
#0 0x00000008029807ea in _read () from /lib/libc.so.7
#1 0x00000008021f4a13 in ?? () from /lib/libthr.so.3
#2 0x0000000000d0198d in AlertPfMonitorIfaceChanges (args=0x803394ef0) at alert-pf.c:1058but the one throwing the error is Thread 8
Thread 8 (LWP 187487 of process 2511 "W#05"):
#0 0x00000008029a4454 in exit () from /lib/libc.so.7
#1 0x0000000000e9bbb9 in HSScan (ctx=<optimized out>, thread_ctx=<optimized out>, haystack=0x8338f7800 "CONNECT wfbssvc65.icrc.trendmicro.com:443 HTTP/1.1\r\nHost: wfbssvc65.icrc.trendmicro.com:443\r\n\r\n", haystack_len=<optimized out>) at util-spm-hs.c:156
#2 0x0000000000c8319e in AppLayerProtoDetectPMMatchSignature (s=0x80322d4e0, tctx=0x832d22080, f=0x806648a80, buf=0x8338f7800 "CONNECT wfbssvc65.icrc.trendmicro.com:443 HTTP/1.1\r\nHost: wfbssvc65.icrc.trendmicro.com:443\r\n\r\n", buflen=95, flags=<optimized out>, searchlen=<optimized out>, rflow=<optimized out>) at app-layer-detect-proto.c:215
#3 PMGetProtoInspect (tctx=0x832d22080, pm_ctx=0x1f12c80 <alpd_ctx>, mpm_tctx=<optimized out>, f=0x806648a80, buf=0x8338f7800 "CONNECT wfbssvc65.icrc.trendmicro.com:443 HTTP/1.1\r\nHost: wfbssvc65.icrc.trendmicro.com:443\r\n\r\n", buflen=buflen@entry=95, flags=5 '\005', pm_results=0x7fffdf3f7a00, rflow=0x7fffdf3f7b0f) at app-layer-detect-proto.c:296
#4 0x0000000000c795c8 in AppLayerProtoDetectPMGetProto (tctx=<optimized out>, f=f@entry=0x806648a80, buf=<optimized out>, buflen=buflen@entry=95, flags=flags@entry=5 '\005', pm_results=pm_results@entry=0x7fffdf3f7a00, rflow=0x7fffdf3f7b0f) at app-layer-detect-proto.c:344
#5 0x0000000000c78731 in AppLayerProtoDetectGetProto (tctx=<optimized out>, f=f@entry=0x806648a80, buf=0x8338f7800 "CONNECT wfbssvc65.icrc.trendmicro.com:443 HTTP/1.1\r\nHost: wfbssvc65.ic--Type <RET> for more, q to quit, c to continue without paging--
rc.trendmicro.com:443\r\n\r\n", buflen=95, ipproto=ipproto@entry=6 '\006', flags=flags@entry=5 '\005', reverse_flow=0x7fffdf3f7b0f) at app-layer-detect-proto.c:1433
#6 0x0000000000c69296 in TCPProtoDetect (tv=tv@entry=0x80d8e0600, ra_ctx=ra_ctx@entry=0x832a00020, app_tctx=app_tctx@entry=0x832d21100, p=p@entry=0x838c33200, f=f@entry=0x806648a80, ssn=ssn@entry=0x8338d5d80, stream=0x7fffdf3f7c68, data=0x8338f7800 "CONNECT wfbssvc65.icrc.trendmicro.com:443 HTTP/1.1\r\nHost: wfbssvc65.icrc.trendmicro.com:443\r\n\r\n", data_len=95, flags=5 '\005', dir=UPDATE_DIR_OPPOSING) at app-layer.c:371
#7 0x0000000000c68c6d in AppLayerHandleTCPData (tv=tv@entry=0x80d8e0600, ra_ctx=ra_ctx@entry=0x832a00020, p=p@entry=0x838c33200, f=0x806648a80, ssn=ssn@entry=0x8338d5d80, stream=stream@entry=0x7fffdf3f7c68, data=0x8338f7800 "CONNECT wfbssvc65.icrc.trendmicro.com:443 HTTP/1.1\r\nHost: wfbssvc65.icrc.trendmicro.com:443\r\n\r\n", data_len=95, flags=5 '\005', dir=UPDATE_DIR_OPPOSING) at app-layer.c:709
#8 0x0000000000b62905 in ReassembleUpdateAppLayer (tv=0x80d8e0600, ra_ctx=0x832a00020, ssn=0x8338d5d80, stream=0x7fffdf3f7c68, p=0x838c33200, dir=UPDATE_DIR_OPPOSING) at stream-tcp-reassemble.c:1328
#9 StreamTcpReassembleAppLayer (tv=tv@entry=0x80d8e0600, ra_ctx=ra_ctx@entry=0x832a00020, ssn=ssn@entry=0x8338d5d80, stream=stream@entry=0x8338d5e20, p=p@entry=0x838c33200, dir=dir@entry=UPDATE_DIR_OPPOSING) at stream-tcp-reassemble.c:1391
#10 0x0000000000b64879 in StreamTcpReassembleHandleSegmentUpdateACK (tv=0x80d8e0600, ra_ctx=0x832a00020, ssn=0x8338d5d80, stream=0x8338d5e20, p=0x838c33200) at stream-tcp-reassemble.c:1949
#11 StreamTcpReassembleHandleSegment (tv=0x80d8e0600, ra_ctx=0x832a00020, ssn=0x8338d5d80, stream=0x8338d5d90, p=0x838c33200) at stream-tcp-reassemble.c:1997
#12 0x0000000000b9c789 in HandleEstablishedPacketToClient (tv=0x82e14bc4, tv@entry=0x80d8e0600, ssn=0x0, ssn@entry=0x8338d5d80, p=0x0, p@entry=0x838c33200, stt=0xe50a5969d84bc43d, stt@entry=0x832d60000) at stream-tcp.c:2811
#13 0x0000000000b7aa4d in StreamTcpPacketStateEstablished (tv=0x80d8e0600, p=0x838c33200, stt=0x832d60000, ssn=0x8338d5d80) at stream-tcp.c:3223
#14 StreamTcpStateDispatch (tv=tv@entry=0x80d8e0600, p=p@entry=0x838c33200, stt=stt@entry=0x832d60000, ssn=ssn@entry=0x8338d5d80, state=<optimized out>) at stream-tcp.c:5236
#15 0x0000000000b766c0 in StreamTcpPacket (tv=tv@entry=0x80d8e0600, p=p@entry=0x838c33200, stt=stt@entry=0x832d60000, pq=<optimized out>) at stream-tcp.c:5433
#16 0x0000000000b82781 in StreamTcp (tv=tv@entry=0x80d8e0600, p=p@entry=0x838c33200, data=0x832d60000, pq=pq@entry=0x832d18030) at stream-tcp.c:5745
#17 0x0000000000d53774 in FlowWorkerStreamTCPUpdate (tv=0x1, tv@entry=0x80d8e0600, fw=fw@entry=0x832d18000, p=p@entry=0x838c33200, detect_thread=detect_thread@entry=0x8338d7000, timeout=false) at flow-worker.c:391
#18 0x0000000000d52f4a in FlowWorker (tv=0x80d8e0600, p=0x838c33200, data=0x832d18000) at flow-worker.c:607
#19 0x0000000000e33b07 in TmThreadsSlotVarRun (tv=0x80d8e0600, p=0x838c33200, slot=0x8066db440) at tm-threads.c:135
#20 TmThreadsSlotVar (td=0x80d8e0600) at tm-threads.c:471
#21 0x00000008021e8d25 in ?? () from /lib/libthr.so.3
#22 0x0000000000000000 in ?? ()anyway give me a sec i give you the content of the yaml
Thanks! If you can post the
suricata.rulesfile from the interface, that would be useful, too.I would really love to be able to reproduce the crash, but if not I can compile a 4.2.0 Hyperscan library that you can try just for giggles.
The error returned by Hyperscan is actually quite specific. Here are the associated comments:
hs_error_t err = hs_scan(sctx->db, (const char *)haystack, haystack_len, 0, scratch, MatchEvent, &match_offset); if (err != HS_SUCCESS && err != HS_SCAN_TERMINATED) { /* An error value (other than HS_SCAN_TERMINATED) from hs_scan() * indicates that it was passed an invalid database or scratch region, * which is not something we can recover from at scan time. */ SCLogError("Hyperscan returned fatal error %d.", err); exit(EXIT_FAILURE); }This indicates to me that Suricata is passing Hyperscan either an invalid database or an invalid scratch memory area. What is strange, though, is that no other users on Linux are reporting this kind of issue. At least I have not found such a report.
@bmeeks
https://drive.google.com/drive/folders/1-ag4lFYM0I15IlHX3kxHoNNPV5LPX6QR?usp=sharing -
@bmeeks
https://drive.google.com/drive/folders/1-ag4lFYM0I15IlHX3kxHoNNPV5LPX6QR?usp=sharingGot them! Thanks!
@kiokoman:
Imported yoursuricata.yamlconfiguration andsuricata.rulesfile into my virtual machine. Only edited the interface names to reflectem0which is what I use in my virtual machine at the moment.Suricata starts up and runs. No error yet. Will let it run for a while to see if a crash occurs. I suspect my little VM is not seeing the same amount of packets (traffic) as your machine, though.
@bmeeks
i tried to compile hyperscan 5.4.2 but it does not work with suricata, coredump with "ipprotos" not found or somethingwith 5.2.1 i have assertion failed ...
i must have done something wrong
if you can compile a different hs library version i can try it
changing from AutoFP to Worker make no difference
I loaded the Suricata package that you provided. I did not disable ASLR, so when I started Suricata with pattern matcher set to to "Auto", the PC interface Suricata instance immediately crashed. Below is the gdb output you asked for.
Core was generated by `/usr/local/bin/suricata -i vtnet0.700 -D -c /usr/local/etc/suricata/suricata_238'. Program terminated with signal SIGSEGV, Segmentation fault. Address not mapped to object. #0 0x0000000000bf531a in AppLayerProtoDetectPMGetIpprotos (alproto=22, ipprotos=0x76a19745bd6 "") at app-layer-detect-proto.c:1177 1177 app-layer-detect-proto.c: No such file or directory. [Current thread is 1 (LWP 100363)] warning: Missing auto-load script at offset 0 in section .debug_gdb_scripts of file /usr/local/bin/suricata. Use `info auto-load python-scripts [REGEXP]' to list them. (gdb) bt #0 0x0000000000bf531a in AppLayerProtoDetectPMGetIpprotos (alproto=22, ipprotos=0x76a19745bd6 "") at app-layer-detect-proto.c:1177 #1 0x0000000000bf5193 in AppLayerProtoDetectSupportedIpprotos (alproto=22, ipprotos=0x76a19745bd6 "") at app-layer-detect-proto.c:2054 #2 0x0000000000b2c299 in SigParseProto (s=0x76a19745bc0, protostr=0x822b0ce48 "dhcp") at detect-parse.c:1107 #3 0x0000000000b2af88 in SigParseBasics (de_ctx=0x76a17580000, s=0x76a19745bc0, sigstr=0x822b1af90 "alert dhcp any any -> any any (msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;)", parser=0x822b0ae48, addrs_direction=0 '\000') at detect-parse.c:1375 #4 0x0000000000b28997 in SigParse (de_ctx=0x76a17580000, s=0x76a19745bc0, sigstr=0x822b1af90 "alert dhcp any any -> any any (msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;)", addrs_direction=0 '\000', parser=0x822b0ae48) at detect-parse.c:1456 #5 0x0000000000b27024 in SigInitHelper (de_ctx=0x76a17580000, sigstr=0x822b1af90 "alert dhcp any any -> any any (msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;)", dir=0 '\000') at detect-parse.c:2147 #6 0x0000000000b26d86 in SigInit (de_ctx=0x76a17580000, sigstr=0x822b1af90 "alert dhcp any any -> any any (msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;)") at detect-parse.c:2304 #7 0x0000000000b2794d in DetectEngineAppendSig (de_ctx=0x76a17580000, sigstr=0x822b1af90 "alert dhcp any any -> any any (msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;)") at detect-parse.c:2602 #8 0x0000000000b5cd42 in DetectLoadSigFile (de_ctx=0x76a17580000, sig_file=0x76a1501c780 "/usr/local/etc/suricata/suricata_23822_vtnet0.700/rules/suricata.rules", goodsigs=0x822b1d0fc, badsigs=0x822b1d0f8) at detect-engine-loader.c:165 #9 0x0000000000b5bc0e in ProcessSigFiles (de_ctx=0x76a17580000, pattern=0x76a1501c6e0 "/usr/local/etc/suricata/suricata_23822_vtnet0.700/rules/suricata.rules", st=0x76a175813f0, good_sigs=0x822b1d0fc, bad_sigs=0x822b1d0f8) at detect-engine-loader.c:249 #10 0x0000000000b5b58c in SigLoadSignatures (de_ctx=0x76a17580000, sig_file=0x0, sig_file_exclusive=0) at detect-engine-loader.c:307 #11 0x0000000000ab9c1e in LoadSignatures (de_ctx=0x76a17580000, suri=0x1e27b90 <suricata>) at suricata.c:2415 #12 0x0000000000ab99da in PostConfLoadedDetectSetup (suri=0x1e27b90 <suricata>) at suricata.c:2562 #13 0x0000000000abb4ed in SuricataMain (argc=8, argv=0x822b1d2f0) at suricata.c:2971 #14 0x0000000000ab9222 in main (argc=8, argv=0x822b1d2f0) at main.c:22And the output from bt full.
(gdb) bt full #0 0x0000000000bf531a in AppLayerProtoDetectPMGetIpprotos (alproto=22, ipprotos=0x76a19745bd6 "") at app-layer-detect-proto.c:1177 s = 0x76a01000000 x = 0 pm_ctx = 0x1e48de0 <alpd_ctx+144> j = 0 ipproto = 17 '\021' i = 1 '\001' #1 0x0000000000bf5193 in AppLayerProtoDetectSupportedIpprotos (alproto=22, ipprotos=0x76a19745bd6 "") at app-layer-detect-proto.c:2054 No locals. #2 0x0000000000b2c299 in SigParseProto (s=0x76a19745bc0, protostr=0x822b0ce48 "dhcp") at detect-parse.c:1107 r = -1 #3 0x0000000000b2af88 in SigParseBasics (de_ctx=0x76a17580000, s=0x76a19745bc0, sigstr=0x822b1af90 "alert dhcp any any -> any any (msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;)", parser=0x822b0ae48, addrs_direction=0 '\000') at detect-parse.c:1375 index = 0x822b08d4f "msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;" dup = "alert\000dhcp\000any\000any\000->\000any\000any\000(msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;\000\000 rev:2;\000\000\000\0002;\000\00064; rev:2;\000\000\000comman"... #4 0x0000000000b28997 in SigParse (de_ctx=0x76a17580000, s=0x76a19745bc0, sigstr=0x822b1af90 "alert dhcp any any -> any any (msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;)", addrs_direction=0 '\000', parser=0x822b0ae48) at detect-parse.c:1456 ret = 8 #5 0x0000000000b27024 in SigInitHelper (de_ctx=0x76a17580000, sigstr=0x822b1af90 "alert dhcp any any -> any any (msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;)", dir=0 '\000') at detect-parse.c:2147 parser = {action = "alert", '\000' <repeats 8186 times>, protocol = "dhcp", '\000' <repeats 8187 times>, direction = "->", '\000' <repeats 8189 times>, src = "any", '\000' <repeats 8188 times>, dst = "any", '\000' <repeats 8188 times>, sp = "any", '\000' <repeats 8188 times>, dp = "any", '\000' <repeats 8188 times>, opts = "msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;", '\000' <repeats 8058 times>} sig = 0x76a19745bc0 ret = 0 #6 0x0000000000b26d86 in SigInit (de_ctx=0x76a17580000, sigstr=0x822b1af90 "alert dhcp any any -> any any (msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;)") at detect-parse.c:2304 oldsignum = 685 sig = 0x822b1af90 #7 0x0000000000b2794d in DetectEngineAppendSig (de_ctx=0x76a17580000, sigstr=0x822b1af90 "alert dhcp any any -> any any (msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;)") at detect-parse.c:2602 sig = 0x822b1aef0 dup_sig = 41 #8 0x0000000000b5cd42 in DetectLoadSigFile (de_ctx=0x76a17580000, sig_file=0x76a1501c780 "/usr/local/etc/suricata/suricata_23822_vtnet0.700/rules/suricata.rules", goodsigs=0x822b1d0fc, badsigs=0x822b1d0f8) at detect-engine-loader.c:165 len = 166 sig = 0x76a19745a80 good = 685 bad = 0 line = "alert dhcp any any -> any any (msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;)\000\000rev:2;)\000\000\000\000;)\000\0004; rev:2;)\000\000\000omman"... offset = 0 lineno = 694 multiline = 0 fp = 0x8334c85a0 #9 0x0000000000b5bc0e in ProcessSigFiles (de_ctx=0x76a17580000, pattern=0x76a1501c6e0 "/usr/local/etc/suricata/suricata_23822_vtnet0.700/rules/suricata.rules", st=0x76a175813f0, good_sigs=0x822b1d0fc, bad_sigs=0x822b1d0f8) at detect-engine-loader.c:249 fname = 0x76a1501c780 "/usr/local/etc/suricata/suricata_23822_vtnet0.700/rules/suricata.rules" i = 0 r = 0 files = {gl_pathc = 1, gl_matchc = 1, gl_offs = 0, gl_flags = 0, gl_pathv = 0x76a1509aba0, gl_errfunc = 0x0, gl_closedir = 0x1, gl_readdir = 0x76a15012000, gl_opendir = 0x822b1d080, gl_lstat = 0x82d8566f8, gl_stat = 0x76a15012000} #10 0x0000000000b5b58c in SigLoadSignatures (de_ctx=0x76a17580000, sig_file=0x0, sig_file_exclusive=0) at detect-engine-loader.c:307 rule_files = 0x76a150b1400 file = 0x76a150b1480 sig_stat = 0x76a175813f0 ret = 0 sfile = 0x76a1501c6e0 "/usr/local/etc/suricata/suricata_23822_vtnet0.700/rules/suricata.rules" varname = "rule-files", '\000' <repeats 117 times> good_sigs = 0 bad_sigs = 0 #11 0x0000000000ab9c1e in LoadSignatures (de_ctx=0x76a17580000, suri=0x1e27b90 <suricata>) at suricata.c:2415 No locals. #12 0x0000000000ab99da in PostConfLoadedDetectSetup (suri=0x1e27b90 <suricata>) at suricata.c:2562 mt_enabled = 0 default_tenant = 0 de_ctx = 0x76a17580000 #13 0x0000000000abb4ed in SuricataMain (argc=8, argv=0x822b1d2f0) at suricata.c:2971 tracking = 0 limit_nproc = 1 #14 0x0000000000ab9222 in main (argc=8, argv=0x822b1d2f0) at main.c:22 No locals. -
@masons said in Suricata process dying due to hyperscan problem:
(gdb) bt full #0 0x0000000000bf531a in AppLayerProtoDetectPMGetIpprotos (alproto=22, ipprotos=0x76a19745bd6 "") at app-layer-detect-proto.c:1177 s = 0x76a01000000 x = 0 pm_ctx = 0x1e48de0 <alpd_ctx+144> j = 0 ipproto = 17 '\021' i = 1 '\001' #1 0x0000000000bf5193 in AppLayerProtoDetectSupportedIpprotos (alproto=22, ipprotos=0x76a19745bd6 "") at app-layer-detect-proto.c:2054 No locals. #2 0x0000000000b2c299 in SigParseProto (s=0x76a19745bc0, protostr=0x822b0ce48 "dhcp") at detect-parse.c:1107 r = -1 #3 0x0000000000b2af88 in SigParseBasics (de_ctx=0x76a17580000, s=0x76a19745bc0, sigstr=0x822b1af90 "alert dhcp any any -> any any (msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;)", parser=0x822b0ae48, addrs_direction=0 '\000') at detect-parse.c:1375 index = 0x822b08d4f "msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;" dup = "alert\000dhcp\000any\000any\000->\000any\000any\000(msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;\000\000 rev:2;\000\000\000\0002;\000\00064; rev:2;\000\000\000comman"... #4 0x0000000000b28997 in SigParse (de_ctx=0x76a17580000, s=0x76a19745bc0, sigstr=0x822b1af90 "alert dhcp any any -> any any (msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;)", addrs_direction=0 '\000', parser=0x822b0ae48) at detect-parse.c:1456 ret = 8 #5 0x0000000000b27024 in SigInitHelper (de_ctx=0x76a17580000, sigstr=0x822b1af90 "alert dhcp any any -> any any (msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;)", dir=0 '\000') at detect-parse.c:2147 parser = {action = "alert", '\000' <repeats 8186 times>, protocol = "dhcp", '\000' <repeats 8187 times>, direction = "->", '\000' <repeats 8189 times>, src = "any", '\000' <repeats 8188 times>, dst = "any", '\000' <repeats 8188 times>, sp = "any", '\000' <repeats 8188 times>, dp = "any", '\000' <repeats 8188 times>, opts = "msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;", '\000' <repeats 8058 times>} sig = 0x76a19745bc0 ret = 0 #6 0x0000000000b26d86 in SigInit (de_ctx=0x76a17580000, sigstr=0x822b1af90 "alert dhcp any any -> any any (msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;)") at detect-parse.c:2304 oldsignum = 685 sig = 0x822b1af90 #7 0x0000000000b2794d in DetectEngineAppendSig (de_ctx=0x76a17580000, sigstr=0x822b1af90 "alert dhcp any any -> any any (msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;)") at detect-parse.c:2602 sig = 0x822b1aef0 dup_sig = 41 #8 0x0000000000b5cd42 in DetectLoadSigFile (de_ctx=0x76a17580000, sig_file=0x76a1501c780 "/usr/local/etc/suricata/suricata_23822_vtnet0.700/rules/suricata.rules", goodsigs=0x822b1d0fc, badsigs=0x822b1d0f8) at detect-engine-loader.c:165 len = 166 sig = 0x76a19745a80 good = 685 bad = 0 line = "alert dhcp any any -> any any (msg:\"SURICATA DHCP malformed options\"; app-layer-event:dhcp.malformed_options; classtype:protocol-command-decode; sid:2227000; rev:1;)\000\000rev:2;)\000\000\000\000;)\000\0004; rev:2;)\000\000\000omman"... offset = 0 lineno = 694 multiline = 0 fp = 0x8334c85a0 #9 0x0000000000b5bc0e in ProcessSigFiles (de_ctx=0x76a17580000, pattern=0x76a1501c6e0 "/usr/local/etc/suricata/suricata_23822_vtnet0.700/rules/suricata.rules", st=0x76a175813f0, good_sigs=0x822b1d0fc, bad_sigs=0x822b1d0f8) at detect-engine-loader.c:249 fname = 0x76a1501c780 "/usr/local/etc/suricata/suricata_23822_vtnet0.700/rules/suricata.rules" i = 0 r = 0 files = {gl_pathc = 1, gl_matchc = 1, gl_offs = 0, gl_flags = 0, gl_pathv = 0x76a1509aba0, gl_errfunc = 0x0, gl_closedir = 0x1, gl_readdir = 0x76a15012000, gl_opendir = 0x822b1d080, gl_lstat = 0x82d8566f8, gl_stat = 0x76a15012000} #10 0x0000000000b5b58c in SigLoadSignatures (de_ctx=0x76a17580000, sig_file=0x0, sig_file_exclusive=0) at detect-engine-loader.c:307 rule_files = 0x76a150b1400 file = 0x76a150b1480 sig_stat = 0x76a175813f0 ret = 0 sfile = 0x76a1501c6e0 "/usr/local/etc/suricata/suricata_23822_vtnet0.700/rules/suricata.rules" varname = "rule-files", '\000' <repeats 117 times> good_sigs = 0 bad_sigs = 0 #11 0x0000000000ab9c1e in LoadSignatures (de_ctx=0x76a17580000, suri=0x1e27b90 <suricata>) at suricata.c:2415 No locals. #12 0x0000000000ab99da in PostConfLoadedDetectSetup (suri=0x1e27b90 <suricata>) at suricata.c:2562 mt_enabled = 0 default_tenant = 0 de_ctx = 0x76a17580000 #13 0x0000000000abb4ed in SuricataMain (argc=8, argv=0x822b1d2f0) at suricata.c:2971 tracking = 0 limit_nproc = 1 #14 0x0000000000ab9222 in main (argc=8, argv=0x822b1d2f0) at main.c:22 No locals.Thank you. This crash is similar to @kiokoman's core dump. Suricata seems to be doing something improper within the App Layer protocols logic. In your case it is causing a Signal 11 segfault, but in his case it simply results in the Hyperscan library stopping on a passed-in parameter validation check which leads to Suricata shutting down with a Fatal Error. I may need to raise this again with upstream.
Still puzzled why I can't seem to reproduce it -- at least not yet.
could you tell me if the contents of this directory are the same as mine pls?
ls -la /usr/local/lib/libhs*
-rw-r--r-- 1 root wheel 12342598 Dec 8 18:06 /usr/local/lib/libhs.a lrwxr-xr-x 1 root wheel 10 Dec 8 18:07 /usr/local/lib/libhs.so -> libhs.so.5 lrwxr-xr-x 1 root wheel 14 Dec 8 18:07 /usr/local/lib/libhs.so.5 -> libhs.so.5.4.0 -rwxr-xr-x 1 root wheel 4521768 Dec 8 18:07 /usr/local/lib/libhs.so.5.4.0 -rw-r--r-- 1 root wheel 1423432 Dec 8 18:05 /usr/local/lib/libhs_runtime.a lrwxr-xr-x 1 root wheel 18 Dec 8 18:07 /usr/local/lib/libhs_runtime.so -> libhs_runtime.so.5 lrwxr-xr-x 1 root wheel 22 Dec 8 18:07 /usr/local/lib/libhs_runtime.so.5 -> libhs_runtime.so.5.4.0 -rwxr-xr-x 1 root wheel 1015368 Dec 8 18:07 /usr/local/lib/libhs_runtime.so.5.4.0 -
While not exactly the same, the failure locations I see in both of the
suricata.corefile back trace results look eerily like this old bug in that the failure is in the app-layer protocols section: https://redmine.openinfosecfoundation.org/issues/4273.I wonder if there still might be an issue lurking in the logic even though the originally reported bug was fixed ??
I've sent both back trace results and @kiokoman's
gdb.txtdump to the upstream developers asking for any insights they may have. -
@bmeeks Happy Holidays!!! I wanted to message you to say that.
It looks like file sizes differ. I'm running pfSense 2.7.2 CE in this VM.
-rw-r--r-- 1 root wheel 1421072 Jun 30 08:16 /usr/local/lib/libhs_runtime.a lrwxr-xr-x 1 root wheel 18 Jun 30 08:17 /usr/local/lib/libhs_runtime.so -> libhs_runtime.so.5 lrwxr-xr-x 1 root wheel 22 Jun 30 08:17 /usr/local/lib/libhs_runtime.so.5 -> libhs_runtime.so.5.4.0 -rwxr-xr-x 1 root wheel 1007944 Jun 30 08:17 /usr/local/lib/libhs_runtime.so.5.4.0 -rw-r--r-- 1 root wheel 12452892 Jun 30 08:17 /usr/local/lib/libhs.a lrwxr-xr-x 1 root wheel 10 Jun 30 08:17 /usr/local/lib/libhs.so -> libhs.so.5 lrwxr-xr-x 1 root wheel 14 Jun 30 08:17 /usr/local/lib/libhs.so.5 -> libhs.so.5.4.0 -rwxr-xr-x 1 root wheel 4518952 Jun 30 08:17 /usr/local/lib/libhs.so.5.4.0
