    295 Posts 25 Posters 141.0k Views 25 Watching
    • bmeeksB Offline
      bmeeks @tim_co
      @tim_co said in Suricata process dying due to hyperscan problem:
      And I removed the service_watchdog
      That step is good!
      Those other errors are unrelated to Suricata, but they point to something getting quite messed up on your system. Restoring a config will not necessarily restore the previous package binary versions. In fact, that can make things worse because new binary versions need certain changes made in the configuration. Suricata and Snort are like this.
      1. First thing I would do is uninstall Suricata using the option under SYSTEM > PACKAGE MANAGER.
      2. Next, reboot the firewall so everything has a fresh clean start.
      3. If you have errors upon the restart, then those need to get fixed before messing around any further with Suricata.
      4. Once the firewall boots cleanly with no errors, then return to SYSTEM > PACKAGE MANAGER and reinstall Suricata.
      But to be perfectly frank with you, if you are using Suricata on a home network, there is really no valued added at all. Close to 100% of network traffic these days is encrypted, and unless you have a full proxy configured for MITM, Suricata is not examining the vast majority of data flowing through your firewall. It is just seeing random encrypted bytes that it has no way to decipher and scan. All it can do is examine the source and destination IP addresses and ports, and maybe catch just a glimpse of SNI data for some traffic. It can't see a single thing in SSL web traffic nor email as that is also encrypted with TLS.
        tim_co @bmeeks
        @bmeeks
        To be clear, all the errors I posted are from the suricata.log file, not from the system. Does that change things?
        I've tried uninstalling, rebooting, and then installing again. I'm still having the problem.
        • bmeeksB Offline
          bmeeks @tim_co
          [16-Nov-2023 12:49:03 America/Denver] PHP Fatal error: Uncaught TypeError: fwrite(): Argument #1 ($stream) must be of type resource, bool given in /etc/inc/config.lib.inc:172
          Stack trace:
          #0 /etc/inc/config.lib.inc(172): fwrite(false, 'a:42:{s:7:"vers...')
          #1 /etc/inc/config.lib.inc(147): generate_config_cache(Array)
          #2 /etc/inc/config.inc(141): parse_config()
          #3 /etc/inc/gwlb.inc(25): require_once('/etc/inc/config...')
          #4 /etc/inc/functions.inc(35): require_once('/etc/inc/gwlb.i...')
          #5 /etc/inc/notices.inc(26): require_once('/etc/inc/functi...')
          #6 /usr/local/pkg/nut/nut_email.php(24): require_once('/etc/inc/notice...')
          #7 {main}
          thrown in /etc/inc/config.lib.inc on line 172
          [16-Nov-2023 12:49:03 America/Denver] PHP Fatal error: Uncaught ValueError: Path cannot be empty in /etc/inc/notices.inc:101
          Stack trace:
          #0 /etc/inc/notices.inc(101): fopen('', 'w')
          #1 /etc/inc/config.lib.inc(1148): file_notice('phperror', 'PHP ERROR: Type...', 'PHP errors')
          #2 [internal function]: pfSense_clear_globals()
          #3 {main}
          thrown in /etc/inc/notices.inc on line 101
          These are the errors I am talking about. No way on Earth those came from Suricata. Those came from pfSense itself, and to me point to a problem with your configuration restore job.
          T 2 Replies Last reply Reply Quote 0
            tim_co @bmeeks
            @bmeeks
            For the record, my problems with Suricata started as soon as I upgraded to 7.0.2. I only ran the restore after i was unable to get Suricata to start and work properly.
            I went through and deleted an old backup gateway I had configured or LTE backup and removed the nut package. These seemed to be contributing to the system errors.
            I uninstalled Suricata, rebooted, and there was no longer a kernel error. I reinstalled Suricata, ran an update, and now it stays running but it's not detecting anything. Typically there's an alert/block at least every few minutes.
            The only errors I see now in the system log are related to Suricata not being able to parse thing files and something about [100107] <Error> -- ja3(s) support is not enabled
            Any more ideas?
            Thanks - Tim
            bmeeksB 1 Reply Last reply Reply Quote 1
              tim_co @bmeeks
              @bmeeks
              If I remove all Suricata rules, the only error I get is the "[100404 - Suricata-Main] 2023-11-16 17:17:22 Notice: threads: Threads created -> RX: 1 W: 4 FM: 1 FR: 1 Engine started.
              [100759 - W#04] 2023-11-16 17:17:27 Error: spm-hs: Hyperscan returned fatal error -1."
              Tim
              • bmeeksB Offline
                bmeeks @tim_co
                That error is harmless for now. It simply means that particular protocol parser is not enabled. It can be ignored.
                You have absolutely zero rule categories enabled and you are getting that Hyperscan error? That does not seem to be the same bug because rules with regex patterns to be compiled are required to trigger the Hyperscan bug discussed in this thread. The error occurs when the library is actively compiling regex expressions pulled from enabled rules.
                  tim_co @bmeeks
                  Suricata has been rock solid for years. Its a remarkable tool. It worked great until I upgraded to 7.0.2 today.
                  I'm just trying to get Suricats running again by providing data that seems like it might be helpful with troubleshooting the bug and/or my environment. I clearly don't know what I'm doing.
                  Tim
                  BismarckB 1 Reply Last reply Reply Quote 1
                  • BismarckB Offline
                    Bismarck @tim_co
                    @bmeeks
                    Same issue here, Suricata was fine until update to 7.0.2 (HS 5.4.0), after update it was not starting. Changed Pattern Matcher Algorithm from Auto to AC and its working again. However have 2 other boxes with the 1:1 same Suricata configuration, but they start just fine, only the hardware is different there.
                    bmeeksB T 2 Replies Last reply Reply Quote 1
                    • bmeeksB Offline
                      bmeeks @Bismarck
                      @Bismarck said in Suricata process dying due to hyperscan problem:
                      @bmeeks
                      Can you elaborate on the hardware or other platform differences? It would be helpful to me to know that.
                      1. What processor types are in the other "working" machines?
                      2. Are they bare metal or virtual ?
                      3. What pfSense versions are on the other "working" machines?
                      4. I assume "yes", but are all of the machines ("working" and "not working") running the same Suricata package version?
                      BismarckB 1 Reply Last reply Reply Quote 0
                      • BismarckB Offline
                        Bismarck @bmeeks
                        @bmeeks
                        1. Intel(R) Xeon(R) CPU E5-2667 and Intel(R) Core(TM) i5-4460 working, Intel(R) Celeron(R) N5105 is not.
                        2. Yes, all bare metal
                        3. All at 2.7.0-RELEASE (amd64)
                        4. Yes all the same version, same config/settings/rules/sid etc.
                        bmeeksB T V 3 Replies Last reply Reply Quote 1
                        • bmeeksB Offline
                          bmeeks @Bismarck
                          @bmeeks
                          Thanks for the details. Curious the Celeron is not working. I do know that Hyperscan uses some specific Intel CPU instructions, that's why it does not work on ARM or other hardware platforms. But I would think Celeron would be okay.
                          At any rate, I am going to try and bundle an update to the Hyperscan 5.4.2 library in my next Suricata update.
                          • BismarckB Offline
                            Bismarck @bmeeks
                            I would be grateful to test the new version.
                              tim_co @Bismarck
                              @Bismarck
                              Changed mine to AC-KS and it immediately started working again, but it's putting the hurt on the CPU, temp, & memory. Time to zip-tie the fan to the fan-less system once again. Thanks for the tip!
                              Tim
                              • bmeeksB Offline
                                bmeeks @Bismarck
                                Unfortunately, I don't have a way to distribute it.
                                  tim_co @Bismarck
                                  @Bismarck
                                  Nevermind. AC-KS also puked. AC has been running fine for a few minutes now.
                                    tim_co @bmeeks
                                    After my device runs for half an hour or so, all of the descriptions for alerts say "SURICATA QUIC error on data". Google doesn't find anything for the string. Would somebody please explain to me what this means?
                                    Edit - All the traffic is from the same IP address which is coming from "Zscaler, Inc." and is UDP Generic Protocol Command Decode 165.225.10.58 443 X,X,X,X 34476 1:2231001 SURICATA QUIC error on data
                                    Thanks - Tim
                                    • bmeeksB Offline
                                      bmeeks @tim_co
                                      Thanks - Tim
                                      Tim:
                                      QUIC is a new web transport protocol based on UDP instead of TCP. Some basic info can be found here: https://en.wikipedia.org/wiki/QUIC.
                                      You are seeing those messages because the Suricata built-in Events Rules are enabled. Those are meant to be "informational" rules. They just tell you some particular traffic type is present. That does not mean the traffic is harmful. There is a lot of QUIC out there now, and Suricata is just saying "I see it!". The QUIC rules and detection logic were added to the 7.x branch of Suricata by its upstream developers.
                                      I recommend you go to the CATEGORIES tab and turn off nearly all of the Suricata built-in events rules. Or switch to Block on DROPs Only mode and use SID MGMT tab features to selectively set only some rules or rule categories to DROP (block) traffic and leave the others at their default of ALERT. That will prevent any nuiscan blocks from the information Events Rules. Search the forum here and you will find several posts, including some Sticky Posts at the top of this sub-forum, describing how to do this.
                                        tim_co @bmeeks
                                        @bmeeks
                                        Cool. Thanks for the information. It is greatly appreciated.
                                        • T tim_co referenced this topic on
                                        • V Offline
                                          Vollans @Bismarck
                                          @bmeeks
                                          I’m running a N5105, and it’s running on mine with no problem. It was yesterday on 2.7.0 and overnight on 2.7.1
                                          • BismarckB Offline
                                            Bismarck @Vollans
                                            @Vollans said in Suricata process dying due to hyperscan problem:
                                            The only difference is the machine with the Intel N5105 CPU also has Intel NICs (igc), the othere 2 have broadcoms (bge). I guess thats why they behave different.
                                            Do we see a pattern here?
