    System Shuts Down when UPS does a Self Test
    25 Posts 8 Posters 5.8k Views 9 Watching
      NeVaR @dennypage
      @dennypage said in System Shuts Down when UPS does a Self Test:
      @NeVaR There is an issue in NUT in the current version of nut-devel in pfSense's copy of the FreeBSD repo. It is fixed upstream, and hopefully will be fixed in the pfSense copy soon.
      As an aside, I would recommend that you move the primary to pfSense rather than the Synology. As noted above, running the Synology as primary is not best practice.
      Unfortunately, synology dsm 6.2 has limited support as nut client. I will try with another UPS
      • dennypageD Offline
        dennypage @NeVaR
        @NeVaR said in System Shuts Down when UPS does a Self Test:
        It's been a while, but DSM 6 had support for remote NUT. They don't document anything but connecting to another Synology ("Synology UPS server"), but as long as you use the required values for ups name, user name and user password, it works fine.
        • S SteveITS referenced this topic on
          pfguy2018
          I think I am experiencing the same issue, as I outlined here https://forum.netgate.com/topic/185262/sg5100-shutting-down-unexpectedly
          I get the following system log entries
          I am running pfSense as the primary, with two Synology-s as secondary units (slaves?)
          I guess I just have to wait for the package to be updated on pfSense?
            dennypage @pfguy2018
            @pfguy2018 If you look in the NUT support thread, you will find executables you can use in the interim.
              pfguy2018 @dennypage
              @dennypage Thanks!
