    Problem with Routing from OPT1 Interface
    4 Posts 2 Posters 2.7k Views
      santana
      Hi all,
      I have attached a setup which I am having trouble with.
      I have open all ports on LAN, WAN, and OPT1 (WAN2) interface so that they can talk to eachother.
      I even created a Virtual IP so that it can redirect from the outside into the Local LAN IP.
      On the WAN interface, I have a Virtual IP: 10.1.20.129
      On the OPT1 (WAN2) interface, the virtual IP: 10.1.10.127
      Both Virtual IP has port forwarded and redirected to the LAN IP: 192.168.1.129
      As I said before, all ports on all interface are open.
      Here is the problem:
      All my PCs is Windows XP and with Remote Desktop turned on.
      I am using Remote Desktop Connection to remote into any PCs
      From WAN interface side, I can remote from PC IP: 10.1.20.254 to the Virtual IP 10.1.20.129, which redirect to the LAN PC IP 192.168.1.129, and was able to remote in.
      From LAN interface side, I can remote from the PC on LAN interface to both WAN and OPT1 (WAN2), and was able to remote in.
      From OPT1 (WAN2) interface side, I could not remote from PC IP: 10.1.10.254 to the Virtual IP 10.1.10.127, which redirect to the LAN PC 192.168.1.129, and was unable to remote in.
      Anyone got any ideas on how to get PC on OPT1 interface to work???
      Bill
      pfSense-Setup.GIF_thumb
        hoba
        What kind of VIPs are you using?
          santana
          The one I use is in Firewall > Virtual IPs
          With Proxy ARP.
          Anyone else got a better idea???
          Bill
            hoba
            Have you tried VIP type carp already?
