    Unable to connect between lan1 and lan2
    80 Posts 5 Posters 12.2k Views 4 Watching
      johnpoz LAYER 8 Global Moderator @sutha
      @sutha said in Unable to connect between lan1 and lan2:
      I'll try to disable my tunnel tomorrow
      tunnel? No freaking wonder your not seeing anything.. Its going out your vpn.. uggghhhh - you have wasted everyones time not stating that in post 1..
        sutha @johnpoz
        @johnpoz Actually, that's not true. When I trace the ping, only the tunnel IP goes through the tunnel. Everything else showing the local system ip with the message unreachable.
          @sutha dude turn off your vpn client on this box and your issues will go away!!
          A vpn client will route traffic not set to the local network out the vpn.. So yeah trying to go to 192.168.60 vs 192.168.50 will go your vpn client tunnel... Pfsense can not route traffic its never seeing.. Ie your sniff on your lan not showing any traffic when trying to go to 192.168.60 because its being routed out your tunnel
            sutha @johnpoz
            @johnpoz Does this mean I'm unable to create another interface for my local system as I was planning now?
            My scenario:
            A tunnel exists: site-to-site VPN connection.
            I'd like to have another area for locally separated traffic. I don't want, as I mentioned earlier, Area 2 to communicate with Area 1, but I have users in Area 1 who need to access Area 2.
            Do you think this is possible?
              @sutha if you want a site to site tunnel - create that on pfsense..
              Yes you can filter traffic that pfsense routes.. If you want client X to be able to get to vlan Y, you can allow that, if you want client A not to go to vlan Y from vlan X you can block them..
                sutha @johnpoz
                @johnpoz Yes, that's what I'm looking for. Currently, I have disabled two of the rules, and after reboot, my system suddenly went offline. I need to go to my office to see what happened. Once I have my system back online, I can provide you with some more details.
                  sutha @sutha
                  @sutha So, now I have removed all the rules and disabled the tunnel as well. I've also removed the lan1 and lan2 rules. Currently, I have no internet access and no connectivity to any system. Since I have no internet, I enabled an 'any' rule on lan1, and now I can see there is internet access for lan1 PCs. However, I still have no internet access on lan2. Therefore, I repeated the same steps I took for lan1 on lan2, and now I have internet access on both interfaces.
                  I'm now able to ping from 192.168.50.100 to 192.168.50.1, and when I enter this IP:192.168.50.1 in my browser, it took me to the pfSense web configurator. However, when I attempted to ping a pc on lan2, it failed. I moved to over to lan2 pc and did the ping to an ip 192.168.60.1 and it was successful. Furthermore, I tried to access the pfSense web configurator from lan2 using the IP 192.168.60.1, and it successfully redirected me to the web configurator.
                  At this point, I don't have any rules other than these two. Anyone got any idea what is blocking here, I have disabled my windows own firewall tatally on both system.
                  S johnpozJ 2 Replies Last reply Reply Quote 0
                    SteveITS Galactic Empire @sutha
                    @sutha Realistically there’s only a handful of things it can be:
                    • Incorrect subnet mask on pfSense or PC
                    • Incorrect gateway on either PC
                    • firewall on either PC
                    • firewall rule on pfSense
                    If it was a VLAN, VLAN/switch config.
                    Upvote 👍 helpful posts!
                      It's almost certainly not a gateway problem since hosts on both LANs can reach the internet.
                      It could be a subnet mask problem if hosts are configured statically. If they use DHCP it probably isn't since you cannot configure conflicting subnets in pfSense.
                      If any hosts still have two NICs or additional IPs in both subnet they will be unable to connect to the other subnet.
                      Try to ping 192.168.60.1 (the pfSense interface address) from a host in the 192.168.50.X subnet. If that works then routing and firewall rules are fine and it's almost certainly the hosts themselves blocking the traffic.
                      S S 2 Replies Last reply Reply Quote 0
                        SteveITS Galactic Empire @stephenw10
                        @stephenw10 I was talking in general and wasn’t clear. Low on coffee. :)
                          Now do the sniff.. When you ping a 60.x IP from a 50.x device.. Do you see the traffic get to pfsense?
                          And like to see the output of ipconfig /all from a device.. This will validate your mask is no messed up. And for good measure output of route print..
                            sutha @SteveITS
                            @SteveITS This is my network and interface setting.
                            PC on Lan1:
                            PC on Lan2:
                            Interface Lan1:
                            Interface Lan2:
                              sutha @stephenw10
                              @stephenw10 I'm able to ping from lan1 IP:192.168.50.100 to lan2 ip: 192.168.60.1 and from lan2 ip: 192.168.60.50 to lan1 ip:192.168.50.1.
                              Works fine, but I'm unable to ping any other local pc. Example:
                              from 192.168.50.100 to 192.168.60.50, not working.
                              from 192.168.60.50 to 192.168.50.100, not working as well.
                                @sutha And you could have 14 other interfaces.. On this machine and 3 different vpn interfaces.. How about a simple ipconfig /all output and a route print..
                                $ ipconfig /all
                                Windows IP Configuration
                                   Host Name . . . . . . . . . . . . : i9-win
                                   Primary Dns Suffix  . . . . . . . : home.arpa
                                   Node Type . . . . . . . . . . . . : Broadcast
                                   IP Routing Enabled. . . . . . . . : No
                                   WINS Proxy Enabled. . . . . . . . : No
                                   DNS Suffix Search List. . . . . . : home.arpa
                                Ethernet adapter Local:
                                   Connection-specific DNS Suffix  . : home.arpa
                                   Description . . . . . . . . . . . : Killer E2600 Gigabit Ethernet Controller
                                   Physical Address. . . . . . . . . : B0-4F-13-0B-FD-16
                                   DHCP Enabled. . . . . . . . . . . : Yes
                                   Autoconfiguration Enabled . . . . : Yes
                                   IPv4 Address. . . . . . . . . . . : 192.168.9.100(Preferred)
                                   Subnet Mask . . . . . . . . . . . : 255.255.255.0
                                   Lease Obtained. . . . . . . . . . : Friday, March 15, 2024 11:21:05 PM
                                   Lease Expires . . . . . . . . . . : Thursday, March 21, 2024 11:21:05 PM
                                   Default Gateway . . . . . . . . . : 192.168.9.253
                                   DHCP Server . . . . . . . . . . . : 192.168.9.253
                                   DNS Servers . . . . . . . . . . . : 192.168.3.10
                                   NetBIOS over Tcpip. . . . . . . . : Enabled
                                Ethernet adapter Nas-San:
                                   Description . . . . . . . . . . . : Realtek USB 2.5GbE Family Controller
                                   Physical Address. . . . . . . . . : A0-CE-C8-CC-57-DE
                                   DHCP Enabled. . . . . . . . . . . : No
                                   IPv4 Address. . . . . . . . . . . : 192.168.10.9(Preferred)
                                   NetBIOS over Tcpip. . . . . . . . : Disabled
                                Ethernet adapter vEthernet (WSL):
                                   Description . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter
                                   Physical Address. . . . . . . . . : 00-15-5D-2F-73-DB
                                   Link-local IPv6 Address . . . . . : fe80::41b8:afee:a2a0:27e2%25(Preferred)
                                   IPv4 Address. . . . . . . . . . . : 172.29.64.1(Preferred)
                                   Subnet Mask . . . . . . . . . . . : 255.255.240.0
                                   DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
        fec0:0:0:ffff::2%1
        fec0:0:0:ffff::3%1
                                $ route print
                                Interface List
                                 15...b0 4f 13 0b fd 16 ......Killer E2600 Gigabit Ethernet Controller
                                  1...........................Software Loopback Interface 1
                                  7...a0 ce c8 cc 57 de ......Realtek USB 2.5GbE Family Controller
                                 25...00 15 5d 2f 73 db ......Hyper-V Virtual Ethernet Adapter
                                IPv4 Route Table
                                Active Routes:
                                Network Destination        Netmask          Gateway       Interface  Metric
                                          0.0.0.0          0.0.0.0    192.168.9.253    192.168.9.100     40
                                        127.0.0.0        255.0.0.0         On-link         127.0.0.1    331
                                        127.0.0.1  255.255.255.255         On-link         127.0.0.1    331
                                  127.255.255.255  255.255.255.255         On-link         127.0.0.1    331
                                      172.29.64.0    255.255.240.0         On-link       172.29.64.1   5256
                                      172.29.64.1  255.255.255.255         On-link       172.29.64.1   5256
                                    172.29.79.255  255.255.255.255         On-link       172.29.64.1   5256
                                      192.168.9.0    255.255.255.0         On-link     192.168.9.100    276
                                    192.168.9.100  255.255.255.255         On-link     192.168.9.100    276
                                    192.168.9.255  255.255.255.255         On-link     192.168.9.100    276
                                     192.168.10.0    255.255.255.0         On-link      192.168.10.9    556
                                     192.168.10.9  255.255.255.255         On-link      192.168.10.9    556
                                   192.168.10.255  255.255.255.255         On-link      192.168.10.9    556
                                        224.0.0.0        240.0.0.0         On-link         127.0.0.1    331
                                        224.0.0.0        240.0.0.0         On-link     192.168.9.100    276
                                        224.0.0.0        240.0.0.0         On-link      192.168.10.9    556
                                        224.0.0.0        240.0.0.0         On-link       172.29.64.1   5256
                                  255.255.255.255  255.255.255.255         On-link         127.0.0.1    331
                                  255.255.255.255  255.255.255.255         On-link     192.168.9.100    276
                                  255.255.255.255  255.255.255.255         On-link      192.168.10.9    556
                                  255.255.255.255  255.255.255.255         On-link       172.29.64.1   5256
                                Persistent Routes:
                                  None
                                How about the 30 seconds it takes to do a packet capture? To validate traffic is actually going to pfsense and not some vpn tunnel you have that failed to mention..
                                  If you can ping pfsense 192.168.60.1 from your 50.x device but not some other 60.x this SCREAMS!!!! firewall on the 60.x device..
                                  Again simple packet captures that take all of 30 seconds will finally prove to you its your device and not pfsense..
                                    Yup that^. Almost certainly a local firewall on the device you're trying to ping blocking it.
                                      sutha @johnpoz
                                      @johnpoz This is my ipconfig/all setting:
                                        sutha @stephenw10
                                        @stephenw10 This is my windows firewall setting, I don't have any other firewall setting between pfsense and my sysstem.
                                          sutha @johnpoz
                                          @johnpoz All I can see in the packet capture, when Isent a ping to 192.168.50.1 or 192.168.60.1.
                                          I get a reply from the destination, but when I ping a local pc: 192.168.50.100 or 192.168.60.50.
                                          I get no reply from other side.
                                          stephenw10S johnpozJ 2 Replies Last reply Reply Quote 0
                                            Need to see the complete output from 'ipconfig /all', all interfaces.
