    Port foward reflection problem
    27 Posts 6 Posters 10.0k Views
      puithove
      @ermal:
      Can you detail what issues?
      Sure - the same issues as I mentioned previously.  I have a port forward setup for HTTPS to forward web access to an internal web server.  When I access the pfSense box's ip as https://xx.xx.xx.xx from a machine outside my private network, this works just fine.  When accessing it via the same URL from a machine on my internal private network, it is unable to connect.  Specifically, the error message from Firefox is "The connection was interrupted" which happens immediately - no timeout period.  If I remove the forward rule and try this connection again, Firefox waits a long time and then reports, "the connection has timed out".  This tells me that some part of the port forward reflection is working, but not successfully.
      This worked fine externally and internally under 1.2.3 but has failed from the internal side since I upgraded to the 2.0 beta a couple weeks ago.
      Since this was an upgrade and there are some mentioned issues with upgrading, would it be worthwhile to rebuild from scratch?  Would resetting to factory defaults be sufficient?
        Runefox
        I can confirm that the same thing happens to me as well with the current snapshots (grabbed 20100125-2045 last night); I've tested with HTTP, FTP and SSH. The inetd.conf file is actually populated this time; A small snippet of inetd.conf:
        19001   stream  tcp     nowait/0        nobody  /usr/bin/nc     nc -w 2000 192.168.1.253 21
        19001   stream  tcp     nowait/0        nobody  /usr/bin/nc     nc -w 2000 192.168.1.253 8075
        19001   stream  tcp     nowait/0        nobody  /usr/bin/nc     nc -w 2000 192.168.1.253 28852
        19001   dgram   udp     nowait/0        nobody  /usr/bin/nc     nc -u -w 2000 192.168.1.253 28852
        19001   stream  tcp     nowait/0        nobody  /usr/bin/nc     nc -w 2000 192.168.1.253 20560
        19001   dgram   udp     nowait/0        nobody  /usr/bin/nc     nc -u -w 2000 192.168.1.253 20560
        19001   stream  tcp     nowait/0        nobody  /usr/bin/nc     nc -w 2000 192.168.1.253 3784
        19001   dgram   udp     nowait/0        nobody  /usr/bin/nc     nc -u -w 2000 192.168.1.253 3784
        19001   stream  tcp     nowait/0        nobody  /usr/bin/nc     nc -w 2000 192.168.1.253 7708
        19001   dgram   udp     nowait/0        nobody  /usr/bin/nc     nc -u -w 2000 192.168.1.253 7708
        19001   dgram   udp     nowait/0        nobody  /usr/bin/nc     nc -u -w 2000 192.168.1.253 7717
        19001   stream  tcp     nowait/0        nobody  /usr/bin/nc     nc -w 2000 192.168.1.253 7707
        19001   dgram   udp     nowait/0        nobody  /usr/bin/nc     nc -u -w 2000 192.168.1.253 7707
        19001   stream  tcp     nowait/0        nobody  /usr/bin/nc     nc -w 2000 192.168.1.90 6881
        19130   stream  tcp     nowait/0        nobody  /usr/bin/nc     nc -w 2000 192.168.1.90 7850
        19130   dgram   udp     nowait/0        nobody  /usr/bin/nc     nc -u -w 2000 192.168.1.90 7850
        19130   stream  tcp     nowait/0        nobody  /usr/bin/nc     nc -w 2000 192.168.1.253 22
        19130   stream  tcp     nowait/0        nobody  /usr/bin/nc     nc -w 2000 192.168.1.253 80
        19130   stream  tcp     nowait/0        nobody  /usr/bin/nc     nc -w 2000 192.168.1.253 65000
        19130   dgram   udp     nowait/0        nobody  /usr/bin/nc     nc -u -w 2000 192.168.1.253 65000
        19131   stream  tcp     nowait/0        nobody  /usr/bin/nc     nc -w 2000 192.168.1.253 65001
        19131   dgram   udp     nowait/0        nobody  /usr/bin/nc     nc -u -w 2000 192.168.1.253 65001
        19132   stream  tcp     nowait/0        nobody  /usr/bin/nc     nc -w 2000 192.168.1.253 65002
        19132   dgram   udp     nowait/0        nobody  /usr/bin/nc     nc -u -w 2000 192.168.1.253 65002
        19133   stream  tcp     nowait/0        nobody  /usr/bin/nc     nc -w 2000 192.168.1.253 65003
        19133   dgram   udp     nowait/0        nobody  /usr/bin/nc     nc -u -w 2000 192.168.1.253 65003
        19134   stream  tcp     nowait/0        nobody  /usr/bin/nc     nc -w 2000 192.168.1.253 65004
        19134   dgram   udp     nowait/0        nobody  /usr/bin/nc     nc -u -w 2000 192.168.1.253 65004
        I'm not too familiar with how inetd.conf is supposed to be generated - Isn't the first column supposed to be unique per-entry (or per-port)? It seems like there's a good deal of overlap at the beginning of this portion (19001, 19130). Is that normal? Looking at the log, it seems like port ranges are the only things that increment the first column; Single port forward rules don't seem to increment.
        • jimpJ Offline
          Commits for one of the below tickets may have introduced a bug in the course of trying to fix other bugs.
          http://redmine.pfsense.org/issues/show/193
          http://redmine.pfsense.org/issues/show/99
          Not sure which of those would be more appropriate to reopen in this case, probably #99. Copy that inetd.conf info into the ticket, along with as much info about your NAT port forward entries as possible.
          Do not Chat/PM for help!
          • E Offline
            eri--
            Try latest snap.
              Runefox
              Looks like the latest snaps aren't building properly at the moment (last good build was on the 25th, build.log shows signal 15's); I'll hold off on adding any information until I can get my hands on a fresh snapshot.
              • jimpJ Offline
                It should be safe to try a gitsync instead:
                http://doc.pfsense.org/index.php/Updating_pfSense_code_between_snapshots
                  puithove
                  FWIW - I got impatient waiting for a new auto-update snapshot to be available so I attempted the gitsync.  That kinda hosed my pfsense box ;-)
                  So, I decided to start fresh with a new install from livecd using build 2010-02-19 04:18
                  On a fresh install using that build, the NAT reflection now works properly.
                  Thank you pfSense dudes!
                  -Phil
