    Help!!!
    13 Posts 5 Posters 1.4k Views 6 Watching
      Antibiotic
      Suddenly occurred:
      pfSense-upgrade -d -c
      pfSense-repoc-static: failed to fetch the repo data
      failed to read the repo data.
      failed to update the repository settings!!!
      Any ideas?
      pfSense plus 26.03 on Topton mini PC
      CPU: Intel N100
      NIC: Intel i-226v 4 pcs
      RAM : 16 GB DDR5
      Disk: 128 GB NVMe
      Brgds, Archi
        michmoor LAYER 8 Rebel Alliance @Antibiotic
        @Antibiotic
        pkg upgrade -fy pfSense-upgrade pfSense-base
        pfSense-upgrade -dy
        Wireless: Unifi, Aruba IAP
        JNCIP,CCNP Enterprise
          Antibiotic @michmoor
          @michmoor
          @michmoor said in Help!!!:
          Number of packages to be reinstalled: 2
          [1/2] Reinstalling pfSense-base-2.7.2...
          [1/2] Extracting pfSense-base-2.7.2: 100% 3 B 0.0kB/s 00:05
          ===> Keeping a copy of current version mtree
          ===> Removing schg flag from base files
          ===> Extracting new base tarball
          ===> Removing static obsoleted files
          [2/2] Reinstalling pfSense-upgrade-1.2.1...
          [2/2] Extracting pfSense-upgrade-1.2.1: 100% 6 B 0.0kB/s 00:01
          pfSense-upgrade -dy
          CPU: Intel N100
          RAM : 16 GB DDR5
          Disk: 128 GB NVMe
          Brgds, Archi
            Antibiotic @Antibiotic
            @Antibiotic The problem still exist, please help!
            CPU: Intel N100
            RAM : 16 GB DDR5
            Disk: 128 GB NVMe
            Brgds, Archi
              slu @Antibiotic
              @Antibiotic
              Since you don't write how did you run into this situation its better and faster to reinstall 2.7.2 and reimport your backup.
              And this topic title is not very useful to get help...
              pfSense Gold subscription
                Antibiotic @slu
                @slu Just try to update and got this! pfSense running pfBlockerNG , suricata inline mode and crowdsec.
                CPU: Intel N100
                RAM : 16 GB DDR5
                Disk: 128 GB NVMe
                Brgds, Archi
                S GertjanG 2 Replies Last reply Reply Quote 0
                  slu @Antibiotic
                  @Antibiotic said in Help!!!:
                  From which version?
                  How did you start the upgrade?
                  Did you search in the forum?
                    Antibiotic @slu
                    @slu ce 2.7.2 version, tryung update from web gui and terminal, the same
                    Tried pfsense troubleshooting section for update problem , nothing help/
                    CPU: Intel N100
                    RAM : 16 GB DDR5
                    Disk: 128 GB NVMe
                    Brgds, Archi
                      Gertjan @Antibiotic
                      I see this one mentioned a lot : On the command line, SSH or console, option 8 :
                      certctl rehash
                      Then you can test this : disable them all. Apply the KIS solution, and work you way up untill it 'breaks' again.
                      Because : when you install a new, clean pfSense with only one (1) changed setting : the admin password (and no previous config import !!), you know that pfSense can update itself, everything works great. This stopped working because the admin (you) added new configurations.
                      I wouldn't be surprised if a pfBlockerng IP or DNSBL feed 'forbids' you to connect to the Netgate upgrade servers. This has happened.
                      Or Suricata disallows the 'update request traffic' because it uses a rule that made it look suspect.
                      Another favorite one is : the admin found a new way the totally f*ck *p the DNS, so pfSense itself can't resolve anymore for itself : update checks, abc uploaded etc become impossible.
                      This is what I would do :
                      If that didn't work out, and without the need of re installing :
                      1. From the GUII, export your config.
                      2. From the console to SSH : reset to default values.
                      3. DO NOT import your config.
                      4. DO NOT enter change modify don't even look at DNS settings : pfSense works great 'out of the box' already.
                      5. If needed, assign interfaces, make LAN work and stop there - do just the bare minimum.
                      Now, upgrading / updating whatever does work.
                      1. Now : import your config back in.
                      2. See that the same issue comes back .....
                        So :
                      3. Have a talk with the admin : he introduced a setting that breaks stuff.
                      4. Go back again to "all default".
                      From now on : add a setting back, step by step, and do extensive testing. take your time.
                      As soon as the issue came back, undo the last setting change, and your good. Done.
                        Antibiotic @Gertjan
                        @Gertjan But after config back up and reset to default, do I need to install all packages back before to apply back up config? I mean suricata crowdsec and pfblockeNG. What about openVPN settings, they will restore?
                        CPU: Intel N100
                        RAM : 16 GB DDR5
                        Disk: 128 GB NVMe
                        Brgds, Archi
                          There was a problem with the CE pkg repos yesterday you may have hit initially. That's fixed now.
                          No, pkgs are re-installed when you restore the config. Crowdsec will not though because that's not a pfSense package.
                            Antibiotic @stephenw10
                            @stephenw10 Oh, me suspect that was a problem not on my side. Now too late, did fresh reinstall. Could pfSense team to make announcement on forum next time this happened? to avoid missing of time for searching a cause of problem!
                            CPU: Intel N100
                            RAM : 16 GB DDR5
                            Disk: 128 GB NVMe
                            Brgds, Archi
                              By the time we realised it was a problem it was already fixed. If it had been something that required a longer outage we would have posted something.
