    Problem with DNS resolver
    64 Posts 7 Posters 6.9k Views 6 Watching
      darcey @fireodo
      @fireodo My 2.7.2CE install is also currently on unbound-1.18.0_1
      [2.7.2-RELEASE][root@fw.local.lan]/root: pkg search unbound
      unbound-1.19.1                 Validating, recursive, and caching DNS resolver
      [2.7.2-RELEASE][root@fw.local.lan]/root: pkg info | grep unbound
      unbound-1.18.0_1               Validating, recursive, and caching DNS resolver
      When might it pull in the updated package, other than explicit upgrade via the cmdline?
      fireodoF 1 Reply Last reply Reply Quote 0
      • fireodoF Online
        fireodo @Unoptanio
        @Unoptanio said in Problem with DNS resolver:
        What version of pfsense is Unbound 1.18.0_1 from?
        I guess 2.7.1 (not shure)
        I have a script (see attachment - change .zip to .php) that looks via cronjob if there are some updates. (The script is from @Gertjan if I remember well) pkg_check.zip
        The cronjob looks loke this:
        /usr/bin/nice -n20 /usr/local/bin/php -q /root/bin/pkg_check.php | logger
        Edit: In my case the location of the script is in /root/bin (directory I have created) - put the script in your case where you wish ...
        Tanti auguri :-)
        pfsense 2.8.1 CE
        UnoptanioU 2 Replies Last reply Reply Quote 1
        • UnoptanioU Offline
          Unoptanio @fireodo
          @fireodo
          So is it a bug in 2.7.2 that doesn't update unbound DNS?
          pfSensePlus24.11 2U BareMetal Asrock Industrial IMB-X1314MicroATX
          CPU: i7-13700@5.2GHz, RAM:32GB ECC, n°2 Samsung 870EVO SATA 2.5” SSD 1TB (ZFS) Raid1
          n°3 Intel i225-LM 2500/1000/100Mbps, n°1 NIC Intel i350-T4V2 10/100/1000 Mbps 4*GLAN, n°1 Intel X520-DA2
          • fireodoF Online
            fireodo @Unoptanio
            No thats not a bug - if some changes where needed in unbound that occure AFTER release of 2.7.2 thats the only way to handle it - as far as I know!
            PS.: Is unbound still restarting?
            pfsense 2.8.1 CE
              Unoptanio @fireodo
              @fireodo
              during my lunch break in about two hours I will reboot the system
              • fireodoF Online
                fireodo @Unoptanio
                pfsense 2.8.1 CE
                UnoptanioU 1 Reply Last reply Reply Quote 0
                • fireodoF Online
                  fireodo @darcey
                  @darcey said in Problem with DNS resolver:
                  See my answer with the script inside - this kind of upgrade you have to do manually.
                  pfsense 2.8.1 CE
                    darcey @fireodo
                    @fireodo Thanks, I'd completely forgotten about this. It seems on my system, unbound and curl have updates available.
                    Still I think I am going to leave it as is as things are running very smoothly for me of late.
                    • fireodoF Online
                      fireodo @darcey
                      Never change a running system ... old wisdom 😀
                      (curl has a security issue so I recommend to upgrade)
                      pfsense 2.8.1 CE
                        Unoptanio @fireodo
                        @fireodo
                        After restart system
                        GertjanG fireodoF 2 Replies Last reply Reply Quote 0
                          Gertjan @Unoptanio
                          @Unoptanio
                          That's unbound in permanent restart mode !
                          You can stop that now, as the test succeeded.
                          To stop the testing :
                          Uncheck :
                          Save, and Apply.
                          ( I'm trying a new solution to a 10+ year old question )
                          UnoptanioU 1 Reply Last reply Reply Quote 1
                          • fireodoF Online
                            fireodo @Unoptanio
                            Do you have the register dhcp-leases in dns resolver (as gertjan indicates) on?
                            pfsense 2.8.1 CE
                              Unoptanio @Gertjan
                              @Gertjan
                              Done now at 2.18pm
                              Now I try to disable DHCP Registration
                                Run pkg upgrade to check if there are any updated system packages available.
                                We build newer versions of packages if they are available with fixes for specific issues that users may be hitting. They are then available to upgrade to but these are not expected or required upgrades.
                                In the instance that upgrades are required for security issues we would usually either issues an announcement or a point release of pfSense depending on the severity.
                                I would not expect the Unbound version to be the issue here. But it also doesn't hurt to update it and it's an easy test. 😉
                                  Unoptanio @stephenw10
                                  @stephenw10 said in Problem with DNS resolver:
                                  pkg upgrade
                                  [2.7.2-RELEASE][admin@xxxxx]/root: pkg upgrade
                                  Fetching meta.conf:   0%
                                  Fetching packagesite.pkg:   0%
                                  Checking for upgrades (3 candidates): 100%      3 B   0.0kB/s    00:01
                                  Processing candidates (3 candidates): 100%      3 B   0.0kB/s    00:01
                                  The following 1 package(s) will be affected (of 0 checked):
                                  Installed packages to be UPGRADED:
                                          curl: 8.4.0 -> 8.6.0 [pfSense]
                                  Number of packages to be upgraded: 1
                                  1 MiB to be downloaded.
                                  Proceed with this action? [y/N]:
                                    Yup, you can upgrade curl. But not upgrading it should not be an issue.
                                      disabled DHCP Registration
                                      Rebooted the system and the problem recurred. unbound DNS Does not resolve
                                        And it's still just continually restarting?
                                        Is there anything in the main system log that's looping? Something else could be restarting Unbound.
                                          I stopped the service and restarted it and it worked right away.
                                          But in the service list it always showed it running green even when it's not working
                                            And in the main system log?
