    help to solve ipsec problem
    7 Posts 3 Posters 574 Views 3 Watching
      Giorgio Dutto
      hie86cc41b-edf1-4dd7-aab3-cac021624a10-immagine.png to all and thanks in advance....
      this is my situation:
      a: pfsense ipsec
      b: drytek
      log pfsense:
        michmoor LAYER 8 Rebel Alliance @Giorgio Dutto
        @Giorgio-Dutto
        what is sticking out to me is this
        This is a site2site IPsec VPN?
        Can you provide the config for each site?
        Wireless: Unifi, Aruba IAP
        JNCIP,CCNP Enterprise
          Giorgio Dutto @michmoor
          @michmoor
          pfsense
          draytek
            @Giorgio-Dutto
            A few things stick out.
            1. The drytek is sitting behind a NAT device. So in pfsense when you select Peer Identifier make sure you put in the real Source IP of the gateway. For example 192.168.1.2 (whatever it is pre-nat)
            2. pfSense is using pfs group14 for phase2. Although i see the drytek configuration selected to use PFS which key value is it using? Does it default to group14?
            3. Phase2 lifetimes appear to be mismatched. pfsense is set to 86400s while the drytek is set for 600s
            In the pfsense GUI, do you see p1 established? P2 is the one that is failing? Not sure where in the process things break down.
              @michmoor
              Great!!!
              it was exactly the "Peer Identifier"
              now the only thing I can't do is see all the subnets of the remote site....
              I added the second subnet but I don't see it.
              • V Offline
                viragomann @Giorgio Dutto
                @Giorgio-Dutto
                Note that a /24 network address ends with ".0". As well the network settings in the phase 2 of both sites have to match.
                So you need to correct this on the Drytek.
                  Giorgio Dutto @viragomann
                  @viragomann
                  Ops!
                  Thanks will correct
