Netgate Device ID changing on power loss
You should disable the on-board audio, though I doubt it's connected to this issue:
hdacc0: <ATI R6xx HDA CODEC> at cad 0 on hdac0 hdaa0: <ATI R6xx Audio Function Group> at nid 1 on hdacc0 pcm0: <ATI R6xx (HDMI)> at nid 3 on hdaa0 pcm1: <ATI R6xx (HDMI)> at nid 5 on hdaa0 pcm2: <ATI R6xx (HDMI)> at nid 7 on hdaa0 pcm3: <ATI R6xx (HDMI)> at nid 9 on hdaa0Ok the actual driver attachment looks to have happened after the bootlog completes but it should be in the main system log.
Yes, you could disable the usbus or root device completely but it would be better to disable just the Ethernet device if you can.
Try running:
usbconfig -d ugen0.3 dump_all_config_descIt looks like it has more than one config index, in which case we can force the other one which may make it fail to load.
@stephenw10 said in Netgate Device ID changing on power loss:
I'll look into disabling the audio, agreed, makes no sense having that on.
Here's the output of the command in your second comment:
/root: usbconfig -d ugen0.3 dump_all_con fig_desc ugen0.3: <American Megatrends Inc. Virtual Ethernet> at usbus0, cfg=0 md=HOST sp d=HIGH (480Mbps) pwr=ON (0mA) Configuration index 0 bLength = 0x0009 bDescriptorType = 0x0002 wTotalLength = 0x0050 bNumInterfaces = 0x0002 bConfigurationValue = 0x0001 iConfiguration = 0x0000 <no string> bmAttributes = 0x00c0 bMaxPower = 0x0000 Interface 0 bLength = 0x0009 bDescriptorType = 0x0004 bInterfaceNumber = 0x0000 bAlternateSetting = 0x0000 bNumEndpoints = 0x0001 bInterfaceClass = 0x0002 <Communication device> bInterfaceSubClass = 0x0002 bInterfaceProtocol = 0x00ff iInterface = 0x0004 <RNDIS Notification Interface> Additional Descriptor bLength = 0x05 bDescriptorType = 0x24 bDescriptorSubType = 0x00 RAW dump: 0x00 | 0x05, 0x24, 0x00, 0x10, 0x01 Additional Descriptor bLength = 0x05 bDescriptorType = 0x24 bDescriptorSubType = 0x01 RAW dump: 0x00 | 0x05, 0x24, 0x01, 0x00, 0x01 Additional Descriptor bLength = 0x04 bDescriptorType = 0x24 bDescriptorSubType = 0x02 RAW dump: 0x00 | 0x04, 0x24, 0x02, 0x00 Additional Descriptor bLength = 0x05 bDescriptorType = 0x24 bDescriptorSubType = 0x06 RAW dump: 0x00 | 0x05, 0x24, 0x06, 0x00, 0x01 Additional Descriptor bLength = 0x0d bDescriptorType = 0x24 bDescriptorSubType = 0x0f RAW dump: 0x00 | 0x0d, 0x24, 0x0f, 0x05, 0x00, 0x00, 0x00, 0x00, 0x08 | 0xea, 0x05, 0x00, 0x00, 0x00 Endpoint 0 bLength = 0x0007 bDescriptorType = 0x0005 bEndpointAddress = 0x0081 <IN> bmAttributes = 0x0003 <INTERRUPT> wMaxPacketSize = 0x0400 bInterval = 0x0001 bRefresh = 0x0000 bSynchAddress = 0x0000 Interface 1 bLength = 0x0009 bDescriptorType = 0x0004 bInterfaceNumber = 0x0001 bAlternateSetting = 0x0000 bNumEndpoints = 0x0002 bInterfaceClass = 0x000a <CDC-data> bInterfaceSubClass = 0x0000 bInterfaceProtocol = 0x0000 iInterface = 0x0006 <RNDIS Data Interface> Endpoint 0 bLength = 0x0007 bDescriptorType = 0x0005 bEndpointAddress = 0x0002 <OUT> bmAttributes = 0x0002 <BULK> wMaxPacketSize = 0x0200 bInterval = 0x0000 bRefresh = 0x0000 bSynchAddress = 0x0000 Endpoint 1 bLength = 0x0007 bDescriptorType = 0x0005 bEndpointAddress = 0x0083 <IN> bmAttributes = 0x0002 <BULK> wMaxPacketSize = 0x0200 bInterval = 0x0000 bRefresh = 0x0000 bSynchAddress = 0x0000 Configuration index 1 bLength = 0x0009 bDescriptorType = 0x0002 wTotalLength = 0x0050 bNumInterfaces = 0x0002 bConfigurationValue = 0x0002 iConfiguration = 0x0000 <no string> bmAttributes = 0x00c0 bMaxPower = 0x0000 Interface 0 bLength = 0x0009 bDescriptorType = 0x0004 bInterfaceNumber = 0x0000 bAlternateSetting = 0x0000 bNumEndpoints = 0x0001 bInterfaceClass = 0x0002 <Communication device> bInterfaceSubClass = 0x0006 bInterfaceProtocol = 0x0000 iInterface = 0x0007 <CDC Notification Interface> Additional Descriptor bLength = 0x05 bDescriptorType = 0x24 bDescriptorSubType = 0x00 RAW dump: 0x00 | 0x05, 0x24, 0x00, 0x10, 0x01 Additional Descriptor bLength = 0x05 bDescriptorType = 0x24 bDescriptorSubType = 0x01 RAW dump: 0x00 | 0x05, 0x24, 0x01, 0x00, 0x01 Additional Descriptor bLength = 0x04 bDescriptorType = 0x24 bDescriptorSubType = 0x02 RAW dump: 0x00 | 0x04, 0x24, 0x02, 0x00 Additional Descriptor bLength = 0x05 bDescriptorType = 0x24 bDescriptorSubType = 0x06 RAW dump: 0x00 | 0x05, 0x24, 0x06, 0x00, 0x01 Additional Descriptor bLength = 0x0d bDescriptorType = 0x24 bDescriptorSubType = 0x0f RAW dump: 0x00 | 0x0d, 0x24, 0x0f, 0x08, 0x00, 0x00, 0x00, 0x00, 0x08 | 0xea, 0x05, 0x00, 0x00, 0x00 Endpoint 0 bLength = 0x0007 bDescriptorType = 0x0005 bEndpointAddress = 0x0081 <IN> bmAttributes = 0x0003 <INTERRUPT> wMaxPacketSize = 0x0400 bInterval = 0x0001 bRefresh = 0x0000 bSynchAddress = 0x0000 Interface 1 bLength = 0x0009 bDescriptorType = 0x0004 bInterfaceNumber = 0x0001 bAlternateSetting = 0x0000 bNumEndpoints = 0x0002 bInterfaceClass = 0x000a <CDC-data> bInterfaceSubClass = 0x0000 bInterfaceProtocol = 0x0000 iInterface = 0x0009 <CDC Data Interface> Endpoint 0 bLength = 0x0007 bDescriptorType = 0x0005 bEndpointAddress = 0x0002 <OUT> bmAttributes = 0x0002 <BULK> wMaxPacketSize = 0x0200 bInterval = 0x0000 bRefresh = 0x0000 bSynchAddress = 0x0000 Endpoint 1 bLength = 0x0007 bDescriptorType = 0x0005 bEndpointAddress = 0x0083 <IN> bmAttributes = 0x0002 <BULK> wMaxPacketSize = 0x0200 bInterval = 0x0000 bRefresh = 0x0000 bSynchAddress = 0x0000 -
Hmm, both indexs include CDC data which will likely be the ue0 device. The logs just after boot should confirm that showing cdce though.
It feels like it should be possible to add a USB quirk to just stop that loading but I don't see an option for that:
https://man.freebsd.org/cgi/man.cgi?query=usb_quirkOtherwise disabling cdce0 or the USB bus or controller should be possible.
I have an older ASRock Rack motherboard, and I also had my share of struggles with their BMC port sharing. On this motherboard, from what I found in my research, this virtual AMD port appears when instead of using a dedicated BMC port, you share this port for other purposes, or when you only have one cable connected to a certain port.
As far as I understand and remember, the settings for this behavior are not in the BIOS but in the BMC’s web interface. In the Configuration section, there should be several options for network, link configuration, and choosing between shared or dedicated. One of these options should disable this virtual interface, but I’m not entirely sure. The motherboard manual might provide more detailed descriptions of the BMC settings, but on my board, these settings are quite confusing, and the manual doesn’t cover all of them.
Overall, I had a similar idea—to have access to both the BIOS and everything else. But as usual, since their BMC relies on Java, which can’t be updated, it’s impossible to use their applets because the board is no longer supported. In the end, I connected a PiKVM to this board.
For anyone considering purchasing an ASRock Rack, I highly advise against it if you plan to use the board longer than its support period (typically 2-3 years), as the BMC might "turn into a pumpkin" after that.
