    LAN NIC - Errors IN - Low Volume Any Concern
    16 Posts 2 Posters 2.3k Views 2 Watching
      ngr2001
      I have a very small volume of "Errors In" on the LAN NIC. Both the WAN and LAN are at 1Gb speeds. Should I be concerned or is this cosmetic ?
        I would not be, not at that rate. Especially if they don't increase continually.
        That could be just from a relink at some point.
          ngr2001 @stephenw10
          What do you mean by a relink ?
          Something on my lan side ?
            Like a cable was replugged or whatever it connected to was rebooted. You can get some errors when happens.
            So if you see a bunch of errors initially and then nothing additional that's different to seeing, say, a few errors per hour ongoing.
            But either way I would not consider 348 errors out of 15M a particularly worrying amount. Even if I would prefer to see zero there.
              ngr2001 @stephenw10
              It seems like its slowly but steadily increasing for sure. I work from home and all my other devices are asleep. I don't normally look at these stats but I recently disabled the onboard X540 Intel NIC in favor of a new PCIe X550-T2 Nic. So naturally I've been looking over logs and settings and have been seeing this.
              Would a packet capture help here, anything else I could be looking for as a sign.
              I currently have both the WAN and LAN at 1Gb.
                Hmm, what is it connected to? Does that show errors out?
                The other thing to check is the sysctl stats for the interface. The ix driver quite recently started reporting all error types in the netstat output there so some errors that were always present suddenly appeared to the user! There are a few places in the output of sysctl dev.ix.3
                For example:
                dev.ix.3.mac_stats.rx_missed_packets: 0
                dev.ix.3.mac_stats.rec_len_errs: 0
                dev.ix.3.mac_stats.remote_faults: 0
                dev.ix.3.mac_stats.local_faults: 2
                dev.ix.3.mac_stats.short_discards: 0
                dev.ix.3.mac_stats.byte_errs: 0
                dev.ix.3.mac_stats.ill_errs: 0
                dev.ix.3.mac_stats.crc_errs: 0
                dev.ix.3.mac_stats.rx_errs: 0
                Your NIC may not be ix3 obviously.
                  ngr2001 @stephenw10
                  Its connected to a Brocade ICX-7250 switch on port 48 at 1Gb. That port is only reporting 2 Errors since last reboot which was a long time ago.
                  Also, I rebooted PF since last post, my error count in GUI looks tied to this number,
                  dev.ix.1.mac_stats.rx_errs: 129
                  sysctl dev.ix.1
                  dev.ix.1.dmac: 0
                  dev.ix.1.fw_version: Option ROM V19-b5-p15 eTrack 0x80001509 PHY FW V523
                  dev.ix.1.enable_aim: 0
                  dev.ix.1.advertise_speed: 7
                  dev.ix.1.fc: 3
                  dev.ix.1.mac_stats.tx_frames_1024_1522: 10864334
                  dev.ix.1.mac_stats.tx_frames_512_1023: 347030
                  dev.ix.1.mac_stats.tx_frames_256_511: 193161
                  dev.ix.1.mac_stats.tx_frames_128_255: 181640
                  dev.ix.1.mac_stats.tx_frames_65_127: 769638
                  dev.ix.1.mac_stats.tx_frames_64: 45087
                  dev.ix.1.mac_stats.management_pkts_txd: 0
                  dev.ix.1.mac_stats.mcast_pkts_txd: 1103
                  dev.ix.1.mac_stats.bcast_pkts_txd: 59
                  dev.ix.1.mac_stats.good_pkts_txd: 12400890
                  dev.ix.1.mac_stats.total_pkts_txd: 12400890
                  dev.ix.1.mac_stats.good_octets_txd: 16169878821
                  dev.ix.1.mac_stats.checksum_errs: 2
                  dev.ix.1.mac_stats.management_pkts_drpd: 0
                  dev.ix.1.mac_stats.management_pkts_rcvd: 115970
                  dev.ix.1.mac_stats.recv_jabberd: 0
                  dev.ix.1.mac_stats.recv_oversized: 0
                  dev.ix.1.mac_stats.recv_fragmented: 0
                  dev.ix.1.mac_stats.recv_undersized: 0
                  dev.ix.1.mac_stats.rx_frames_1024_1522: 1735379
                  dev.ix.1.mac_stats.rx_frames_512_1023: 179449
                  dev.ix.1.mac_stats.rx_frames_256_511: 61323
                  dev.ix.1.mac_stats.rx_frames_128_255: 170015
                  dev.ix.1.mac_stats.rx_frames_65_127: 3313453
                  dev.ix.1.mac_stats.rx_frames_64: 65551
                  dev.ix.1.mac_stats.bcast_pkts_rcvd: 4956
                  dev.ix.1.mac_stats.mcast_pkts_rcvd: 111014
                  dev.ix.1.mac_stats.good_pkts_rcvd: 5525170
                  dev.ix.1.mac_stats.total_pkts_rcvd: 5527181
                  dev.ix.1.mac_stats.good_octets_rcvd: 2926516254
                  dev.ix.1.mac_stats.total_octets_rcvd: 2926663479
                  dev.ix.1.mac_stats.xoff_recvd: 0
                  dev.ix.1.mac_stats.xoff_txd: 0
                  dev.ix.1.mac_stats.xon_recvd: 0
                  dev.ix.1.mac_stats.xon_txd: 0
                  dev.ix.1.mac_stats.rx_missed_packets: 0
                  dev.ix.1.mac_stats.rec_len_errs: 129
                  dev.ix.1.mac_stats.remote_faults: 0
                  dev.ix.1.mac_stats.local_faults: 1
                  dev.ix.1.mac_stats.short_discards: 0
                  dev.ix.1.mac_stats.byte_errs: 0
                  dev.ix.1.mac_stats.ill_errs: 0
                  dev.ix.1.mac_stats.crc_errs: 0
                  dev.ix.1.queue7.rx_discarded: 0
                  dev.ix.1.queue7.rx_copies: 0
                  dev.ix.1.queue7.rx_bytes: 37477124
                  dev.ix.1.queue7.rx_packets: 324418
                  dev.ix.1.queue7.rxd_tail: 833
                  dev.ix.1.queue7.rxd_head: 834
                  dev.ix.1.queue7.irqs: 1190253
                  dev.ix.1.queue7.interrupt_rate: 31250
                  dev.ix.1.queue7.tx_packets: 1478205
                  dev.ix.1.queue7.tso_tx: 0
                  dev.ix.1.queue7.txd_tail: 2012
                  dev.ix.1.queue7.txd_head: 2012
                  dev.ix.1.queue6.rx_discarded: 0
                  dev.ix.1.queue6.rx_copies: 0
                  dev.ix.1.queue6.rx_bytes: 566921708
                  dev.ix.1.queue6.rx_packets: 640000
                  dev.ix.1.queue6.rxd_tail: 1023
                  dev.ix.1.queue6.rxd_head: 1024
                  dev.ix.1.queue6.irqs: 1007186
                  dev.ix.1.queue6.interrupt_rate: 31250
                  dev.ix.1.queue6.tx_packets: 971599
                  dev.ix.1.queue6.tso_tx: 0
                  dev.ix.1.queue6.txd_tail: 1840
                  dev.ix.1.queue6.txd_head: 1840
                  dev.ix.1.queue5.rx_discarded: 0
                  dev.ix.1.queue5.rx_copies: 0
                  dev.ix.1.queue5.rx_bytes: 199376846
                  dev.ix.1.queue5.rx_packets: 330272
                  dev.ix.1.queue5.rxd_tail: 543
                  dev.ix.1.queue5.rxd_head: 544
                  dev.ix.1.queue5.irqs: 855052
                  dev.ix.1.queue5.interrupt_rate: 31250
                  dev.ix.1.queue5.tx_packets: 734899
                  dev.ix.1.queue5.tso_tx: 0
                  dev.ix.1.queue5.txd_tail: 1489
                  dev.ix.1.queue5.txd_head: 1489
                  dev.ix.1.queue4.rx_discarded: 0
                  dev.ix.1.queue4.rx_copies: 0
                  dev.ix.1.queue4.rx_bytes: 234339891
                  dev.ix.1.queue4.rx_packets: 756201
                  dev.ix.1.queue4.rxd_tail: 488
                  dev.ix.1.queue4.rxd_head: 489
                  dev.ix.1.queue4.irqs: 1332345
                  dev.ix.1.queue4.interrupt_rate: 31250
                  dev.ix.1.queue4.tx_packets: 1101650
                  dev.ix.1.queue4.tso_tx: 0
                  dev.ix.1.queue4.txd_tail: 1280
                  dev.ix.1.queue4.txd_head: 1280
                  dev.ix.1.queue3.rx_discarded: 0
                  dev.ix.1.queue3.rx_copies: 0
                  dev.ix.1.queue3.rx_bytes: 614802605
                  dev.ix.1.queue3.rx_packets: 673141
                  dev.ix.1.queue3.rxd_tail: 1396
                  dev.ix.1.queue3.rxd_head: 1397
                  dev.ix.1.queue3.irqs: 986840
                  dev.ix.1.queue3.interrupt_rate: 31250
                  dev.ix.1.queue3.tx_packets: 749380
                  dev.ix.1.queue3.tso_tx: 0
                  dev.ix.1.queue3.txd_tail: 135
                  dev.ix.1.queue3.txd_head: 135
                  dev.ix.1.queue2.rx_discarded: 0
                  dev.ix.1.queue2.rx_copies: 0
                  dev.ix.1.queue2.rx_bytes: 395043603
                  dev.ix.1.queue2.rx_packets: 748841
                  dev.ix.1.queue2.rxd_tail: 1320
                  dev.ix.1.queue2.rxd_head: 1321
                  dev.ix.1.queue2.irqs: 1528743
                  dev.ix.1.queue2.interrupt_rate: 31250
                  dev.ix.1.queue2.tx_packets: 1509099
                  dev.ix.1.queue2.tso_tx: 0
                  dev.ix.1.queue2.txd_tail: 734
                  dev.ix.1.queue2.txd_head: 734
                  dev.ix.1.queue1.rx_discarded: 0
                  dev.ix.1.queue1.rx_copies: 0
                  dev.ix.1.queue1.rx_bytes: 369176533
                  dev.ix.1.queue1.rx_packets: 401454
                  dev.ix.1.queue1.rxd_tail: 45
                  dev.ix.1.queue1.rxd_head: 46
                  dev.ix.1.queue1.irqs: 912677
                  dev.ix.1.queue1.interrupt_rate: 31250
                  dev.ix.1.queue1.tx_packets: 704081
                  dev.ix.1.queue1.tso_tx: 0
                  dev.ix.1.queue1.txd_tail: 1701
                  dev.ix.1.queue1.txd_head: 1701
                  dev.ix.1.queue0.rx_discarded: 0
                  dev.ix.1.queue0.rx_copies: 0
                  dev.ix.1.queue0.rx_bytes: 477562058
                  dev.ix.1.queue0.rx_packets: 1550098
                  dev.ix.1.queue0.rxd_tail: 1809
                  dev.ix.1.queue0.rxd_head: 1810
                  dev.ix.1.queue0.irqs: 3188399
                  dev.ix.1.queue0.interrupt_rate: 31250
                  dev.ix.1.queue0.tx_packets: 5152046
                  dev.ix.1.queue0.tso_tx: 0
                  dev.ix.1.queue0.txd_tail: 313
                  dev.ix.1.queue0.txd_head: 313
                  dev.ix.1.link_irq: 2
                  dev.ix.1.watchdog_events: 0
                  dev.ix.1.dropped: 0
                  dev.ix.1.iflib.rxq7.rxq_fl0.buf_size: 2048
                  dev.ix.1.iflib.rxq7.rxq_fl0.credits: 2047
                  dev.ix.1.iflib.rxq7.rxq_fl0.cidx: 834
                  dev.ix.1.iflib.rxq7.rxq_fl0.pidx: 833
                  dev.ix.1.iflib.rxq7.cpu: 14
                  dev.ix.1.iflib.rxq6.rxq_fl0.buf_size: 2048
                  dev.ix.1.iflib.rxq6.rxq_fl0.credits: 2047
                  dev.ix.1.iflib.rxq6.rxq_fl0.cidx: 1024
                  dev.ix.1.iflib.rxq6.rxq_fl0.pidx: 1023
                  dev.ix.1.iflib.rxq6.cpu: 12
                  dev.ix.1.iflib.rxq5.rxq_fl0.buf_size: 2048
                  dev.ix.1.iflib.rxq5.rxq_fl0.credits: 2047
                  dev.ix.1.iflib.rxq5.rxq_fl0.cidx: 578
                  dev.ix.1.iflib.rxq5.rxq_fl0.pidx: 577
                  dev.ix.1.iflib.rxq5.cpu: 10
                  dev.ix.1.iflib.rxq4.rxq_fl0.buf_size: 2048
                  dev.ix.1.iflib.rxq4.rxq_fl0.credits: 2047
                  dev.ix.1.iflib.rxq4.rxq_fl0.cidx: 489
                  dev.ix.1.iflib.rxq4.rxq_fl0.pidx: 488
                  dev.ix.1.iflib.rxq4.cpu: 8
                  dev.ix.1.iflib.rxq3.rxq_fl0.buf_size: 2048
                  dev.ix.1.iflib.rxq3.rxq_fl0.credits: 2047
                  dev.ix.1.iflib.rxq3.rxq_fl0.cidx: 1397
                  dev.ix.1.iflib.rxq3.rxq_fl0.pidx: 1396
                  dev.ix.1.iflib.rxq3.cpu: 6
                  dev.ix.1.iflib.rxq2.rxq_fl0.buf_size: 2048
                  dev.ix.1.iflib.rxq2.rxq_fl0.credits: 2047
                  dev.ix.1.iflib.rxq2.rxq_fl0.cidx: 1321
                  dev.ix.1.iflib.rxq2.rxq_fl0.pidx: 1320
                  dev.ix.1.iflib.rxq2.cpu: 4
                  dev.ix.1.iflib.rxq1.rxq_fl0.buf_size: 2048
                  dev.ix.1.iflib.rxq1.rxq_fl0.credits: 2047
                  dev.ix.1.iflib.rxq1.rxq_fl0.cidx: 46
                  dev.ix.1.iflib.rxq1.rxq_fl0.pidx: 45
                  dev.ix.1.iflib.rxq1.cpu: 2
                  dev.ix.1.iflib.rxq0.rxq_fl0.buf_size: 2048
                  dev.ix.1.iflib.rxq0.rxq_fl0.credits: 2047
                  dev.ix.1.iflib.rxq0.rxq_fl0.cidx: 1810
                  dev.ix.1.iflib.rxq0.rxq_fl0.pidx: 1809
                  dev.ix.1.iflib.rxq0.cpu: 0
                  dev.ix.1.iflib.txq7.r_abdications: 0
                  dev.ix.1.iflib.txq7.r_restarts: 0
                  dev.ix.1.iflib.txq7.r_stalls: 0
                  dev.ix.1.iflib.txq7.r_starts: 1478444
                  dev.ix.1.iflib.txq7.r_drops: 0
                  dev.ix.1.iflib.txq7.r_enqueues: 1482194
                  dev.ix.1.iflib.txq7.ring_state: pidx_head: 1490 pidx_tail: 1490 cidx: 1490 state: IDLE
                  dev.ix.1.iflib.txq7.txq_cleaned: 2906041
                  dev.ix.1.iflib.txq7.txq_processed: 2906073
                  dev.ix.1.iflib.txq7.txq_in_use: 35
                  dev.ix.1.iflib.txq7.txq_cidx_processed: 2009
                  dev.ix.1.iflib.txq7.txq_cidx: 1977
                  dev.ix.1.iflib.txq7.txq_pidx: 2012
                  dev.ix.1.iflib.txq7.no_tx_dma_setup: 0
                  dev.ix.1.iflib.txq7.txd_encap_efbig: 0
                  dev.ix.1.iflib.txq7.tx_map_failed: 0
                  dev.ix.1.iflib.txq7.no_desc_avail: 0
                  dev.ix.1.iflib.txq7.mbuf_defrag_failed: 0
                  dev.ix.1.iflib.txq7.m_pullups: 1361758
                  dev.ix.1.iflib.txq7.mbuf_defrag: 0
                  dev.ix.1.iflib.txq7.cpu: 14
                  dev.ix.1.iflib.txq6.r_abdications: 0
                  dev.ix.1.iflib.txq6.r_restarts: 0
                  dev.ix.1.iflib.txq6.r_stalls: 0
                  dev.ix.1.iflib.txq6.r_starts: 966995
                  dev.ix.1.iflib.txq6.r_drops: 0
                  dev.ix.1.iflib.txq6.r_enqueues: 973109
                  dev.ix.1.iflib.txq6.ring_state: pidx_head: 0309 pidx_tail: 0309 cidx: 0309 state: IDLE
                  dev.ix.1.iflib.txq6.txq_cleaned: 1842958
                  dev.ix.1.iflib.txq6.txq_processed: 1842990
                  dev.ix.1.iflib.txq6.txq_in_use: 34
                  dev.ix.1.iflib.txq6.txq_cidx_processed: 1838
                  dev.ix.1.iflib.txq6.txq_cidx: 1806
                  dev.ix.1.iflib.txq6.txq_pidx: 1840
                  dev.ix.1.iflib.txq6.no_tx_dma_setup: 0
                  dev.ix.1.iflib.txq6.txd_encap_efbig: 0
                  dev.ix.1.iflib.txq6.tx_map_failed: 0
                  dev.ix.1.iflib.txq6.no_desc_avail: 0
                  dev.ix.1.iflib.txq6.mbuf_defrag_failed: 0
                  dev.ix.1.iflib.txq6.m_pullups: 782869
                  dev.ix.1.iflib.txq6.mbuf_defrag: 0
                  dev.ix.1.iflib.txq6.cpu: 12
                  dev.ix.1.iflib.txq5.r_abdications: 0
                  dev.ix.1.iflib.txq5.r_restarts: 0
                  dev.ix.1.iflib.txq5.r_stalls: 0
                  dev.ix.1.iflib.txq5.r_starts: 728984
                  dev.ix.1.iflib.txq5.r_drops: 0
                  dev.ix.1.iflib.txq5.r_enqueues: 736304
                  dev.ix.1.iflib.txq5.ring_state: pidx_head: 1073 pidx_tail: 1073 cidx: 1073 state: IDLE
                  dev.ix.1.iflib.txq5.txq_cleaned: 1328871
                  dev.ix.1.iflib.txq5.txq_processed: 1328903
                  dev.ix.1.iflib.txq5.txq_in_use: 42
                  dev.ix.1.iflib.txq5.txq_cidx_processed: 1804
                  dev.ix.1.iflib.txq5.txq_cidx: 1772
                  dev.ix.1.iflib.txq5.txq_pidx: 1814
                  dev.ix.1.iflib.txq5.no_tx_dma_setup: 0
                  dev.ix.1.iflib.txq5.txd_encap_efbig: 0
                  dev.ix.1.iflib.txq5.tx_map_failed: 0
                  dev.ix.1.iflib.txq5.no_desc_avail: 0
                  dev.ix.1.iflib.txq5.mbuf_defrag_failed: 0
                  dev.ix.1.iflib.txq5.m_pullups: 538142
                  dev.ix.1.iflib.txq5.mbuf_defrag: 0
                  dev.ix.1.iflib.txq5.cpu: 10
                  dev.ix.1.iflib.txq4.r_abdications: 0
                  dev.ix.1.iflib.txq4.r_restarts: 0
                  dev.ix.1.iflib.txq4.r_stalls: 0
                  dev.ix.1.iflib.txq4.r_starts: 1101686
                  dev.ix.1.iflib.txq4.r_drops: 0
                  dev.ix.1.iflib.txq4.r_enqueues: 1104924
                  dev.ix.1.iflib.txq4.ring_state: pidx_head: 1052 pidx_tail: 1052 cidx: 1052 state: IDLE
                  dev.ix.1.iflib.txq4.txq_cleaned: 2198748
                  dev.ix.1.iflib.txq4.txq_processed: 2198780
                  dev.ix.1.iflib.txq4.txq_in_use: 36
                  dev.ix.1.iflib.txq4.txq_cidx_processed: 1276
                  dev.ix.1.iflib.txq4.txq_cidx: 1244
                  dev.ix.1.iflib.txq4.txq_pidx: 1280
                  dev.ix.1.iflib.txq4.no_tx_dma_setup: 0
                  dev.ix.1.iflib.txq4.txd_encap_efbig: 0
                  dev.ix.1.iflib.txq4.tx_map_failed: 0
                  dev.ix.1.iflib.txq4.no_desc_avail: 0
                  dev.ix.1.iflib.txq4.mbuf_defrag_failed: 0
                  dev.ix.1.iflib.txq4.m_pullups: 1053016
                  dev.ix.1.iflib.txq4.mbuf_defrag: 0
                  dev.ix.1.iflib.txq4.cpu: 8
                  dev.ix.1.iflib.txq3.r_abdications: 0
                  dev.ix.1.iflib.txq3.r_restarts: 0
                  dev.ix.1.iflib.txq3.r_stalls: 0
                  dev.ix.1.iflib.txq3.r_starts: 749507
                  dev.ix.1.iflib.txq3.r_drops: 0
                  dev.ix.1.iflib.txq3.r_enqueues: 750005
                  dev.ix.1.iflib.txq3.ring_state: pidx_head: 0437 pidx_tail: 0437 cidx: 0437 state: IDLE
                  dev.ix.1.iflib.txq3.txq_cleaned: 1362019
                  dev.ix.1.iflib.txq3.txq_processed: 1362051
                  dev.ix.1.iflib.txq3.txq_in_use: 36
                  dev.ix.1.iflib.txq3.txq_cidx_processed: 131
                  dev.ix.1.iflib.txq3.txq_cidx: 99
                  dev.ix.1.iflib.txq3.txq_pidx: 135
                  dev.ix.1.iflib.txq3.no_tx_dma_setup: 0
                  dev.ix.1.iflib.txq3.txd_encap_efbig: 0
                  dev.ix.1.iflib.txq3.tx_map_failed: 0
                  dev.ix.1.iflib.txq3.no_desc_avail: 0
                  dev.ix.1.iflib.txq3.mbuf_defrag_failed: 0
                  dev.ix.1.iflib.txq3.m_pullups: 48082
                  dev.ix.1.iflib.txq3.mbuf_defrag: 0
                  dev.ix.1.iflib.txq3.cpu: 6
                  dev.ix.1.iflib.txq2.r_abdications: 0
                  dev.ix.1.iflib.txq2.r_restarts: 0
                  dev.ix.1.iflib.txq2.r_stalls: 0
                  dev.ix.1.iflib.txq2.r_starts: 1509257
                  dev.ix.1.iflib.txq2.r_drops: 0
                  dev.ix.1.iflib.txq2.r_enqueues: 1512467
                  dev.ix.1.iflib.txq2.ring_state: pidx_head: 1043 pidx_tail: 1043 cidx: 1043 state: IDLE
                  dev.ix.1.iflib.txq2.txq_cleaned: 2970296
                  dev.ix.1.iflib.txq2.txq_processed: 2970328
                  dev.ix.1.iflib.txq2.txq_in_use: 38
                  dev.ix.1.iflib.txq2.txq_cidx_processed: 728
                  dev.ix.1.iflib.txq2.txq_cidx: 696
                  dev.ix.1.iflib.txq2.txq_pidx: 734
                  dev.ix.1.iflib.txq2.no_tx_dma_setup: 0
                  dev.ix.1.iflib.txq2.txd_encap_efbig: 0
                  dev.ix.1.iflib.txq2.tx_map_failed: 0
                  dev.ix.1.iflib.txq2.no_desc_avail: 0
                  dev.ix.1.iflib.txq2.mbuf_defrag_failed: 0
                  dev.ix.1.iflib.txq2.m_pullups: 1023062
                  dev.ix.1.iflib.txq2.mbuf_defrag: 0
                  dev.ix.1.iflib.txq2.cpu: 4
                  dev.ix.1.iflib.txq1.r_abdications: 0
                  dev.ix.1.iflib.txq1.r_restarts: 0
                  dev.ix.1.iflib.txq1.r_stalls: 0
                  dev.ix.1.iflib.txq1.r_starts: 703997
                  dev.ix.1.iflib.txq1.r_drops: 0
                  dev.ix.1.iflib.txq1.r_enqueues: 706097
                  dev.ix.1.iflib.txq1.ring_state: pidx_head: 1585 pidx_tail: 1585 cidx: 1585 state: IDLE
                  dev.ix.1.iflib.txq1.txq_cleaned: 1402497
                  dev.ix.1.iflib.txq1.txq_processed: 1402529
                  dev.ix.1.iflib.txq1.txq_in_use: 36
                  dev.ix.1.iflib.txq1.txq_cidx_processed: 1697
                  dev.ix.1.iflib.txq1.txq_cidx: 1665
                  dev.ix.1.iflib.txq1.txq_pidx: 1701
                  dev.ix.1.iflib.txq1.no_tx_dma_setup: 0
                  dev.ix.1.iflib.txq1.txd_encap_efbig: 0
                  dev.ix.1.iflib.txq1.tx_map_failed: 0
                  dev.ix.1.iflib.txq1.no_desc_avail: 0
                  dev.ix.1.iflib.txq1.mbuf_defrag_failed: 0
                  dev.ix.1.iflib.txq1.m_pullups: 658521
                  dev.ix.1.iflib.txq1.mbuf_defrag: 0
                  dev.ix.1.iflib.txq1.cpu: 2
                  dev.ix.1.iflib.txq0.r_abdications: 0
                  dev.ix.1.iflib.txq0.r_restarts: 0
                  dev.ix.1.iflib.txq0.r_stalls: 0
                  dev.ix.1.iflib.txq0.r_starts: 5151774
                  dev.ix.1.iflib.txq0.r_drops: 0
                  dev.ix.1.iflib.txq0.r_enqueues: 5154784
                  dev.ix.1.iflib.txq0.ring_state: pidx_head: 2016 pidx_tail: 2016 cidx: 2016 state: IDLE
                  dev.ix.1.iflib.txq0.txq_cleaned: 10191127
                  dev.ix.1.iflib.txq0.txq_processed: 10191159
                  dev.ix.1.iflib.txq0.txq_in_use: 34
                  dev.ix.1.iflib.txq0.txq_cidx_processed: 311
                  dev.ix.1.iflib.txq0.txq_cidx: 279
                  dev.ix.1.iflib.txq0.txq_pidx: 313
                  dev.ix.1.iflib.txq0.no_tx_dma_setup: 0
                  dev.ix.1.iflib.txq0.txd_encap_efbig: 0
                  dev.ix.1.iflib.txq0.tx_map_failed: 0
                  dev.ix.1.iflib.txq0.no_desc_avail: 0
                  dev.ix.1.iflib.txq0.mbuf_defrag_failed: 0
                  dev.ix.1.iflib.txq0.m_pullups: 5002785
                  dev.ix.1.iflib.txq0.mbuf_defrag: 0
                  dev.ix.1.iflib.txq0.cpu: 0
                  dev.ix.1.iflib.override_nrxds: 0
                  dev.ix.1.iflib.override_ntxds: 0
                  dev.ix.1.iflib.allocated_msix_vectors: 9
                  dev.ix.1.iflib.use_extra_msix_vectors: 0
                  dev.ix.1.iflib.use_logical_cores: 0
                  dev.ix.1.iflib.separate_txrx: 0
                  dev.ix.1.iflib.core_offset: 0
                  dev.ix.1.iflib.tx_abdicate: 0
                  dev.ix.1.iflib.rx_budget: 0
                  dev.ix.1.iflib.disable_msix: 0
                  dev.ix.1.iflib.override_qs_enable: 0
                  dev.ix.1.iflib.override_nrxqs: 0
                  dev.ix.1.iflib.override_ntxqs: 0
                  dev.ix.1.iflib.driver_version: 4.0.1-k
                  dev.ix.1.%domain: 0
                  dev.ix.1.%parent: pci4
                  dev.ix.1.%pnpinfo: vendor=0x8086 device=0x1563 subvendor=0x8086 subdevice=0x001d class=0x020000
                  dev.ix.1.%location: slot=0 function=1 dbsf=pci0:3:0:1 handle=\_SB_.PCI0.BR3A.H001
                  dev.ix.1.%driver: ix
                  dev.ix.1.%desc: Intel(R) X550-T2
                    Yes and they all seem to be Receive Length Errors. No Out errors shown in the switch either, which might be expected.
                    I would at least try swapping and switch port if you haven't tried that yet.
                    I would also try re-assigning that interface if you can. See if the errors follow it or stay on the NIC.
                      ngr2001 @stephenw10
                      To clarify, you mean move the PF LAN connection to a different port on my switch, see if I still get errors, easy enough ?
                      Part 2, are you suggesting I swap my WAN connection from ix0 and move it to ix1 and vice versa, to see if I still get the same errors or if they follow, i.e perhaps just 1 of the 2 nics on the X550-T2 is bad / faulty ? Or even easier I guess I could re-enable the onboard nics and move the LAN connection over to one of them, granted my NDI does not freak out and pfsense+ goes down, not sure how that would behave.
                        Yes and yes! Swapping the physical port in use at either end is a good test if only to confirm there isn't a fault present.
                          ngr2001 @stephenw10
                          So I moved the LAN connection to 3 different ports on the switch, no change, still getting the slowly incrementing "Errors In". I also tried 1Gb and 10Gb ports, no difference.
                          I re-enabled the Onboard NIC in BIOS and oddly PFSense froze / halted on boot. Not sure what the deal is but seems like it does not like when i have both the onboard X540 and PCIe X550 enabled at the same time. I dont really want to unrack and rip out my X550 for this test, so not sure where else to go from here.
                            Hmm, odd. Where does it appear to freeze?
                            N 2 Replies Last reply Reply Quote 0
                              ngr2001 @stephenw10
                              Ill have to get a picture for you when I have a change to reboot.
                                ngr2001 @stephenw10
                                FYI,
                                I've since swapped LAN NICS, got the onboard working again. I also swapped switches and swapped the patch cable. So everything is different, yet I still get a slow trickle of LAN Errors IN.
                                This count is after 6 Days of uptime.
                                Old setup was X550 with Cisco 3850
                                Current setup is X540 with Cisco 3650
                                Same issue observed with both nics and when the switch was a brocade ICX-7250
                                Same issue observed regardless of NIC speed and connection type, RJ45 vs SPF+
                                Should I be concerned ? I'd love to know why this is happening.
                                  I wouldn't be too concerned if you're not seeing any other issues.
                                  Still the same error type shown in the sysctls?
                                    ngr2001 @stephenw10
                                    Correct same type, matches up.
