    Solution for dhcp6c problems after hardware change
    2 Posts 2 Posters 482 Views 2 Watching
      jhg
      Posting this in case it helps somebody having the same problem
      Context:
      • ISP is Comcast Portland OR, which fully supports IPv6
      • Upgraded pfSense hardware from an old Zotac CI323 box to a Beelink EQ12 (for the 2.5Gbe Intel adapters)
      • Installed pfSense CE 2.7.2 (same version as on the Zotac box)
      • Restored configuration
      Results:
      • IPv6 connectivity started behaving erratically.
      • The dhcp6c transaction looked normal, including an address for the WAN adapter plus a delegated prefix.
      • pfSense DHCP6 server gave out addresses with the delegated prefix, and hosts on the LAN could communicate with each other and the firewall over IPv6
      • I could send/receive IPv6 traffic from the firewall console but packets originating on the LAN (i.e. with address in the delegated prefix) exited the WAN adapter but disappeared into the ether.
      Solution:
      The leftover /var/db/dhcp6c_duid, was the culprit, but I don't know enough about pfSense's dhcp6c client to understand why. I was alerted to its existence from a debug log message from the dhcp6c client. In any event, I deleted the file, rebooted the modem and then pfSense, and everything started working.
      As always, YMMV.
      pfSense CE on Beelink EQ14 (N150 CPU, dual 2.5Gbe Intel NICs)
      Hitron CODA56 - Comcast 2.5Gb cable
      • JKnottJ Offline
        JKnott @jhg
        @jhg
        Curious. I replaced the computer I originally ran pfSense on a few years ago. Other than changing the interface assignments, it just worked. I'm still using that new computer today. I'm on Rogers and they use a lot of the same hardware as Comcast. The first computer I ran pfSense on was a refurb HP compact computer and when it died I replaced it with the mini PC described in my sig.
        UniFi AC-Lite access point
