    IoT Devices Not Using DNS from DCHP
    48 Posts 6 Posters 6.8k Views 5 Watching
    • johnpozJ Online
      johnpoz LAYER 8 Global Moderator @TangoOversway
      @TangoOversway ok this your pfsense IP 172.16.7.1?
      This the DNS offfered. 172.16.7.1
      Its odd not seeing the rest of the dhcp, your only seeing one side of it. Ah, if you limited your sniff to specific IP you wouldn't see the broadcast side of it from..
      Why are you using a /22 for your network? do you have some 1000 devices on your network?
      .local is mdns.. Yes and you can see that mdns traffic is to the multicast IP 224.0.0.251, the only thing that can answer that is the host for what its looking for.
      Pfsense is not going to be involved in that traffic at all - unless you had setup avahi because you need that traffic to be seen on another L2 network..
      Mdns is for resolution of stuff on the same L2 network, ie local stuff - hence the .local :) it not going to resolve say www.google.com via mdns. For resolving stuff not on the local L2 network it would need an actual dns to ask.
      Not seeing your 253.x address in that capture.
      What your wan IP is would have nothing to do with devices on your networks from talking to each other.. Your isp using cgnat and pfsense having that on its wan IP would only prevent unsolicited inbound traffic to pfsense that you would want to forward to something behind pfsense. I don't see how that could come into play with openhasp that is for sure.. Why would you need some IP on the internet to start a conversation with you? Just out of the blue?
      TangoOverswayT 1 Reply Last reply Reply Quote 0
      • TangoOverswayT Offline
        TangoOversway @johnpoz
        @johnpoz
        @johnpoz said in IoT Devices Not Using DNS from DCHP:
        I can do another capture. Should I just capture on port 5353 from any address?
        It's really hard for me to remember things by IP address, but it's a LOT easier if I break things down in blocks. Using /22 lets me use ranges for types of devices. IoT has one range (except for the 2 Home Assistant instances on Raspberry Pis). Also, I have 2 buildings, too far apart to be on the same wifi, but they are one LAN, joined by 500' of underground fiber. It also helps me keep track of things by setting up separate blocks for the house and barn. When I realized I would have trouble setting up blocks like this in a 256 address space, I went ahead and made it /22 so I'd have something I'd never outgrow.
        So if I write the name "brandyhall.local," mDNS will find it, even if it's really "brandyhall.arda.ea?"
        Not using avahi at all.
        That's what I thought, but also figured that if I didn't mention it, then, down the road, it might become an issue.
        I didn't think it would, but figured that if the ESP is asking for a DNS, it might somehow be sending something out past my LAN. I figured it was unlikely, but that's beyond what I know, so I thought I should ask so I can be sure it's not an issue and can ignore it.
        • johnpozJ Online
          @TangoOversway said in IoT Devices Not Using DNS from DCHP:
          if your client does mdns when you say ping that vs using normal dns - and the brandyhall device is answering mdns.. And they are both on the same network. mdns is multicast - it goes out to every device on that network and asks hey are you this? Or do you provide this service, etc. Its up to the device to answer.. If it saw that query and if its answering mdns.
          mdns not really meant for when users interact - more for applications. But sure if your client is setup to use it.. Linux you could install the avahi browser.
          https://linux.die.net/man/1/avahi-browse
          Windows if bonjour is running, etc. Might have to install it and make sure its configured - I believe LLMNR which another discovery/local name resolution protocol.
          I go out of my way on my network to disable all that crap.. Its horribly inefficient and just puts utter noise on the network, I make sure none of my linux instances do it, and windows I have it disabled and also their own crap of LLMNR unchecked on every interface. The only things that use it are phones to find the printer.. Because apple in their infinite wisdom doesn't actually allow you just tell your phone what fqdn or IP address your printer is at - and you have to "discover" where it is at via spraying the network with multicast and hope your printer sees it and and answers - hey I am at this IP..
          If your having issues with trying to setup your openhasp - I would forget about pfsense having anything to do with it.. Get with the makers of the software you using if devices on the same L2 can not find each other, pfsense nothing to do with devices on the same L2 talking whatever protocols they want between each other.
          Now if you have your devices across some bridge in pfsense - maybe with that long fiber run that you have on the same network?
          As to what your doing trying to put certain devices on specific IPs in a IP range? Personally seems pointless to me, it does nothing.. What does it matter if an IP is 172.16.0.x or 172.16.1.x if your using a 172.16.0/22 ? If I wanted that I would put some devices in 172.16.0/24 and other devices in 172.16.1/24 so they are actually on different networks and I could control who and what can talk to each other in some fashion..
          you could also do that in with single /24 -- devices X type are .10-30, devices of Y are are .40-50 or devices of Z are .60-80 say.. But again what does it matter they are on the same network anyway and you have no control on what they do amongst themselves.
          devices on the same L2 network using some discovery protocol like mdns to find something on that same network has ZERO to do with pfsense.. Doesn't matter what actual NS pfsense would hand them if they are going to use mdns to find something they are looking for on the same local network.
          This how your phone can find your local resource of your printer on your local network using mdns - because google dns sure isn't going to know anything about some local name your using for your printer.. And your not going to put some rfc1918 IP address up in public dns, etc. all of these local discovery protocols allow grandma to use shit without having to have a clue ;)
          edit - here is one of my alexa's looking for shit.
          it just freaking noise if you ask me - and why is it doing it now.. I didn't ask it to find shit it could control, sengled is for sure associated with lightbulbs or smartplugs, etc. home automation stuff.. So not like discovery can not be useful - but its noisy as shit! I have some of these.. But again pointing out - pfsense is not involved nor does it have any involvement with devices on the same network talking to each other.. If you have device A and B on the same network and they are having issues finding each other via mdns - that has zero to do with pfsense.. Nor would it matter what actual NS you handed these devices be it google or quad or pfsense IP.. If the device(s) are using mdns to discover each other - doesn't matter if you hand them a NS to use for dns or not.
          edit: where are these devices trying to discovery each other - is one in the barn? across that fiber link - how do you have that setup, is it a bridge you setup in pfsense? between your ethernet cabling and your fiber? If so possible the multicast is being filtered? If wireless is involved - you could have AP or Client isolation on - or something doing something with multicast optimization where the AP tries to turn it into unicast vs multicast.. Multicast on wifi is a bandwidth killer, so depending on your AP it could have some method of trying to reduce that overhead, etc. That could be messing with your discovery via mdns.
          TangoOverswayT 1 Reply Last reply Reply Quote 1
            @johnpoz
            Network design/info - including fiber and any other address spaces:
            Actually, the fiber run to the barn is the short fiber run! We're in a rural area and the only option for good internet service is Starlink. With all the trees around, the nearest place I could put the dish for that is a 1,000' run from the house to the "Outpost," my joke name for the post out in the field with the Starlink dish and router on it. I have the dish hooked up to the Starlink router (in a temperature controlled box). It uses the 192.168.1.xxx address space. It has its own DHCP for it's LAN interface.
            My Netgate box with pfSense is in the house. I use the LAN and WAN interfaces only. WAN connects to the Starlink router through that 1,000' of fiber and the pfSense WAN is in the Starlink's LAN and gets its address from the Starlink's DHCP server. So I have a 2nd address space controlled by the Starlink router, but all that's on it is my pfSense WAN interface.
            Both fiber runs are invisible to the systems on the network. For example, the pfSense WAN interface has a CAT5 ethernet cable connected to an ethernet/fiber converter, then there's the long fiber run, then the ethernet/fiber converter in the box with the Starlink router, then another CAT5 to the router. The converters don't even have IP addresses, they are completely transparent on a networking level. The only DHCP servers I have (unless some LInux system is doing something it shouldn't) are the ones on my Netgate box and the Starlink one. So as far as any fiber goes, it acts just like it's a long ethernet cable (except it's not prone to lightning strikes - which damaged some of my equipment before I used fiber).
            Address space on my LAN
            The address blocking is for me. The TL;DR version is that I have reading and perception issues and that, every now and then, I run into something that asks for an IP address and either won't work with a machine name, or won't allow me to enter a name instead of an address. While I can check the DHCP leases for those situations, to find a system, this makes it a lot less confusing for me.
            pfSense and the bogon DNS issue
            I get that it's not pfSense that's causing the issue. I'm not sure how to continue tracking it down and finding out what's going on. I have discussed this with the openHASP people and they are sure it's something on my LAN. My understanding is that I can't capture packets being sent from one address to another (non-broadcast) - is that correct? So maybe the next step to find out what's going on is to do a capture for broadcasts on port 5353?
            I figure if it's somehow getting a bogon address for a DNS server, it has to be asking for a server AND something has to be responding. Maybe even the Starlink router? From what I've read, though, it seems like mDNS doesn't even ask for an actual server address. Somehow it's trying to get and being given a DNS server address. I don't get what's going on there.
            • johnpozJ Online
              Which is why I always assign static to devices that are going to be on my network on a perm or semiperm basis.. If I had a device, I let it get dhcp, then setup a reservation for that mac and now that device will always be that specific IP give it. While converting over a large network to this model can be a pain.. But I do it whenever I add a new device or replace a device.. Like light bulbs..
              Another option that is now maybe becoming viable is use of dhcp registration with kea.. Before this could be painful because anything to do with a lease would cause a restart of unbound - which could be problematic depending on number of devices, length of your lease.. Why I use reservation registration because that only happens when unbound starts, or you add a new record, etc.
              example - here is a few of my lightbulbs..
              The DX are all in the light above my dining room table.. The names are not in order - over the years I have changed some of them.. Had some issues power blowing them out.. Took me a while to figure that out ;) was the stupid dimmer switch on the wall providing power to the ficture.. Once I replaced that with just normal switch no more issues with bulbs ceasing to function. New ones I added I started with D1x vs just like D3.. So I knew which ones I had replaced..
              I also isolate devices to their own segments - I have a segment for iot devices, like alexas and lightbulbs, thermostat, etc.. I have different one for my rokus, etc. Clients like phones and tablets are on their own segment, etc. etc.
              As to capturing traffic that is not broadcast - no pfsense not going to "see" any traffic between devices to be able to capture it - your only going to see traffic sent to pfsense interface (ie to route out) or directly asking it something like dns, ntp, etc. If wireless is involved you might be able to sniff on your actual AP.. Some of the unifi AP supports this.. mine do..
              Other option is to if you have switch that supports port span/mirroring - where you could create a span port to send all traffic seen son port x or x and y to port z.. And you have your sniff on port Z..
              If your goal is troubleshooting mdns - while you can see a query on pfsense because it is sent to multicast address, you can't really tell if device saw the query or sent an answer because the answer would/could be directed to who asked - not a multicast response where everyone could see.
              Not sure what your asking these guys - but again pfsense is not involved in devices on the same network - it just has no way to do such a thing - unless the traffic was flowing over pfsense in a bridge.. It just has nothing to do with clients A and B talking to each other - be it via broadcast or multicast or unicast, etc.. pfsense just not involved in the conversation at all.
              Could it be something else like a switch doing some sort of ACL blocking multicast or IPs or Macs - sure.. But if that was the case you would of had to configure it, and should know about. Now wifi on the other hand might be doing something, that you might not be aware of, AP/Client isolation is a common issue with devices not being able to talk to each other or discovery protocols working. They could also have some function that seems useful that could be doing it, if your not aware of how that function works..
              Those can cause all sorts of problems if you need multicast to work, etc. You could look to your APs if your devices are wireless or one of them are, etc.
              Other option for sniffing would be on the actual devices in question.. Then you can validate that device A sees the query from B, and B sends the answer, etc. And then A sees that response, etc.
                @johnpoz
                Ah! So you're doing pretty much what I'm doing. In my case, I allow room for expansion. So if I'm doing "human use" computers in the 172.16.7.xxx range and, say, need the first 10 addresses that I know I'll use, I'll likely reserve 30 addresses for that, since computers tend to multiply like rabbits in the spring! So that's part of the reason I have such a large address space. There's also the way I subdivide it, like using 172.16.4.xxx for IoT only - and that's a large block I set aside, since so many new IoT products keep coming out.
                I'm not so sure that it's mDNS that's the issue - but I do not get why something that is using mDNS is getting a DNS server address. Seems to me that unless mDNS is asking for a server, the system should not be getting one.
                While I think what one of the openHASP developers has said, that the issue could very likely be something on my LAN, I do question why that device is even open to being told, "Use this DNS," unless it's asking for one.
                My switches are unmanaged and I have never set them up to do anything special. I'm not even sure I can configure them. I seriously doubt Home Assistant is doing something like that without me setting it up (as you pointed out - I would have had to set it up). I do have some Linux servers, mainly for things like media/streaming service and a few NAS systems. I don't see how any of those could be sending out any DNS server info.
                Okay, that's a good point. If I could capture packets being sent from the ESP to the WAN, I could at least rule out any communication with something not on my LAN. But I think that would have already shown up in the capture I already did - wouldn't it?
                I've been working my way through everything that I have on my LAN as I've been reading your post - not all in the order you wrote everything out. I think I can rule out my Linux servers. They're Debian and I don't see Debian including a service that would do this as a default service it would leave on. I don't see either NAS doing it, or my switches. I had not thought about wifi. I use 2 TP-Link Deco M9 units in my house (and 2 more in the barn, but this ESP is in my house) and I have never really felt they were solid. Mobile devices can be within 8' of them and report a weak signal. I've also had problems with their behavior when coming back up after a power outage. There were other incidents along the way that have bothered me. But the control interface is dead simple - too simple, really, since there are settings I have wanted to change, but can't. I don't trust device like that, and if I had known how limited the control app was, I wouldn't have bought the system. I'm going to look through that and see if I can find something on it that might misbehave.
                johnpozJ P 2 Replies Last reply Reply Quote 0
                • johnpozJ Online
                  Where are you seeing that - what you posted is how mdns works - its asking everyone if via the multicast address. 224.0.0.251 is everyone that would answer mdns.
                  Why would your esp being sending traffic to the "wan" if it wants to talk to your devices on the local network? What does the esp device need the wan for to do openhasp?
                  The esp device is just going to talk to the MQTT broker.. Via the IP you put in..
                  http://www.steves-internet-guide.com/mqtt-works/
                  Are your esp devices on the pfsense wan or lan? Where is your broker? They should both be on the lan of pfsense.
                    @johnpoz
                    Okay - I'm asking to rule out things. The things you've just helped me rule out may seem obvious to you, but I was asking about them just to be sure they're not a problem.
                    My IoT and ESP devices are on my LAN, on the "innermost circle," where the pfSense system is the DHCP and DNS. My broker is in the same LAN.
                    The only thing on the WAN side of pfSense is the Starlink router, and, of course, on the WAN side of that is the whole internet.
                    • johnpozJ Online
                      @TangoOversway what is not working exactly?
                      You stated in your OP, that " is not getting the info from my pfSense DHCP server to use the pfSense DNS"
                      Think you have gone down some rabbit hole because you don't understand how this works.. Your esp devices talking to your broker has zero need for dns to be honest.. You set the broker IP on the device. It talks to the broker.. You setup the client in the broker.. To know what info to get from it or send to it..
                      Or they discover each other? But normal dns, ie pfsense is not part of the equation.. That dns would be for when whatever is a dhcp client on your network needs to actually resolve a fqdn like google.com or something on your network host.yourlocaldomain.tld - none of which should be required for you to use your esp with your broker - that talk MQTT.
                        @johnpoz
                        That's about it. I've learned a LOT about this on this thread!
                        But even if the ESP is using mDNS and broadcasting, somehow it's still asking for a DNS server and something is giving it the bogon as a DNS server - right?
                        So, yes, the broker and the ESP find each other, IF I give the ESP the broker's IP address. I can't use the broker's name. (Or if I added ".local" on the broker's name, would that help, even if it's not my local domain?)
                        • johnpozJ Online
                          Show us this - like you did with your other packet capture.. Pfsense would never give out that IP, unless you specifically configured it.. Its not a valid IP.. Maybe you have a typo on your dhcp config where you can give out dns?
                          You could put fqdn or ip if the device where your putting it can resolve that name.. Again mdns is not normally something you put in as a fqdn - no I would not suggest putting brokername.local.. but if your esp device is using pfsense as its dns, you could put in broker.yourdomain.tld.. Where yourdomain.tld would be the domain pfsense is set for.. Default is home.arpa currently I believe but you would have to check your setup.
                          Then if you have setup pfsense to resolve the fqdn your going to put in.. broker.home.arpa for example, either via dhcp registration or dhcp reservation registration or with a host override.
                          Why would anyone want to use mdns when they have dns there to use.. I mean what is better asking 1 IP (your nameserver) directly via unicast hey give me the ip of something.domain.tld vs spewing noise on your whole network asking hey is your name something - let me know what your IP is..
                          unicast is like handing someone a note to ask them hey do you know billys phone number. Vs yelling in a crowded room - hey Billy whats your phone number.. You don't even know if billy is in the room. Now everyone knows your asking for billys phone number.. But they will not give it to you even if they know it..
                          Vs yelling asking for people phone numbers - isn't easier to go ask the doorman (dns) hey whats billys phone number. Since everyone should of let the doorman know hey if anyone is asking here is my phone number.
                            @johnpoz
                            I'm not clear how to show that with packet capture. Just capture all packets going to and from this device and pfSense? And if it's a typo, wouldn't I be having this issue with other systems using that bogon as a DNS server?
                            My best guess, in this case, is because the project is for IoT devices and it's unknown what kind of LAN a device will go on, so they're using mDNS as a default. But that's only a guess. I'm not clear on the reasoning. Personally, I'm not a fan of multicasting for reasons similar to what you've mentioned: It means extra traffic on the LAN and often it's not needed. I did use it in ONE case in a Java program I was writing. The jar file was on Samba share on an embedded system and my clients had a very simple Java class on their desktops. They'd run that class on their desktops, it would do a multicast to find the embedded system. That was a one-time thing each time the program was run - find the system, then shut up. Once the system was found, the jar file could be used for the rest of the program. That made it easy for me to do updates on the jar file (since I could communicate with the embedded system) and they didn't have to do any configuration or setup other than put the one Java file on their desktop.
                            • johnpozJ Online
                              Ding Ding Ding - you get a the cookie! Now your thinking!! Unless you setup a reservation specific for that clients mac address to hand him specific details - yup if pfsense was handing out that bogon IP to clients to use as their dns.. Then everyone using your dhcp server would get that IP for their dns.
                              As to showing - well for starters where did you get the idea that was happening in the first place - where did you see it?
                              As to using mdns - yup lots things use mdns, your phone more than likely is using mdns to find your printer.. But mdns again does not go to 253.x.x. mdns is ALWAYS to 224.0.0.251 which is a multicast address
                              But still again - what is not working with your esp and your broker?? Or your still down some rabbit hole about this 253.x address that you can't even show where you came up with that idea.. If your client was doing a query for that - then yeah you could could easy sniff for it.. either on the client itself, or since its for sure not on the devices via the IP it has - it would have to send it to its default router (pfsense) in some hope to get there.
                                @johnpoz
                                When I try to just use the system name for MQTT on the ESP32, it won't find it with mDNS. Never. That's what got me going on the whole thing - why isn't it doing that? I've had one or two other systems with similar issues: They either don't allow me to enter a system name or don't work with one and need an address instead of a system name. The short version is trying to keep track of, look up, or remember numbers is a pain. Sometimes I have to use paper with a hole in it and read one quad at a time because of reading issues. So being able to use a name instead of an address makes things a lot easier for me. (Which is pretty close to why DNS was invented in the first place, isn't it? To make it easier to remember how to get to a specific system on the net?)
                                I didn't see anything in packets. But what I did see is that when the ESP was using mDNS, it would always end up with the bogon as its DNS server. I would think that's why it would not be able to find my system on the LAN - because, for some reason, even though it's supposedly using mDNS, it still gets a DNS server.
                                That leads to the issue I've brought up several times: Doesn't the ESP have to be asking for a DNS server to get one, even if it's a bad one (the bogon address)? The only thing on my LAN that should be handing out a DNS server address is my DHCP server, which should be using my pfSense firewall/DHCP server/DNS server.
                                I'm trying to figure out how this device ends up with a bogon DNS server instead of getting the DNS info through mDNS or from my DHCP server. It seems to me, if mDNS isn't working to get the broker system from the system name, AND that it's getting a bogon DNS server, something on the ESP is wrong.
                                Here's my logic: If it's using mDNS, it should be getting the needed information to contact my broker from the system name AND it shouldn't be using a normal DNS server. BUT - it's using a DNS server, even if it's a bogon, so it's somehow bypassing mDNS, even when it's enabled. With mDNS on, it's doing something it should NOT do.
                                Added to that, when I disable mDNS, it still gets that bogon DNS server somewhere around 10% of the time. It's not behaving reliably when it gets the right DNS server 90% of the time, and a bogon 10% of the time.
                                  Patch @TangoOversway
                                  What switches are you actually using? Are they able to be managed to create VLANs?
                                  Doing so enables you to track and control the interactions you are trying and failing to do without VLANs.
                                  I strongly recommend you configure VLANs to segregate and control your network.
                                  • johnpozJ Online
                                    Where did you see this?? In its resolv.conf? Where exactly are you seeing this 253 address?
                                    Your esp doesn't even need dns to talk to the broker - be it normal dns or mdns.. Tell it what the broker Ip IS.. Does it now work? Or not?
                                    We are going down some rabbit hole that you keep saying its using this 253.x address for dns - but have yet to show us where your seeing this dns being used?
                                    If you show us where your seeing this - maybe we can figure out where its coming from.. But as you correctly pointed out if pfsense was handing it out via dhcp - then every dhcp client would get it, and your dns wouldn't work.
                                    Unless you setup specific dhcp reservation for a specific client that is different than your normal dhcp settings.
                                      @johnpoz
                                      The ESP system itself reports this:
                                      That's what I've been saying - that somehow the ESP system is getting this bogon as a DNS server.
                                      Yes, but, again, IP addresses (as opposed to names) are quite confusing to me and sometimes I have to use paper with a cutout for the numbers so I can read them one at a time to be sure I have the right address. I am also doing work on my network and have changed the broker from one machine to another and will probably be doing so 2-3 more times as I make other changes - so if I could use just the name, it would make this process a lot easier.
                                      Also, since this ESP32 is getting this bogon as a DNS server (according to the ESP32 itself), where is that coming from?
                                      • johnpozJ Online
                                        @TangoOversway that is from a wifi connection.. You sure your wifi is not handing that out? Or it could be set on device itself.. Just because you use dhcp to get an IP doesn't mean you can't set a dns locally.
                                        Have already gone over this - if pfsense was handing out that for dns in its dhcp server then every single client on your network would be getting it. Every one..
                                        Unless you have setup a reservation for that device - and changed the settings.
                                        On your pfsense do you have a dhcp reservation set for that mac?
                                        Here look - here is my normal dhcp scope for my 192.168.3.0/24 network... I hand out all clients on this network dns of 192.168.3.10, by default it would hand out pfsense IP on that interface.
                                        But in a reservation for a specific client, my pihole in this case I hand out a different dns server.. Pfsense IP 192.168.3.253
                                        Do you have any such reservations (static mappings) setup for your esp box?
                                        Lets see your dhcp server settings on pfsense, and if you show any static mappings at the bottom of the page
                                        Also we already went over how to validate with a packet capture on pfsense - what IP it offers to the dhcp client.
                                        You should see pfsense see the discover from the esp the offer and ack, etc.
                                          @johnpoz Okay - just realized that even though I've assigned it an address. I have not, specifically, told it what to use for the DNS and gateway. It's getting the proper gateway. I think I forgot I have to specifically set the DNS in each DHCP entry. (I thought it was automatic.)
                                          I'll test that out when I get back to that computer this afternoon.
                                          • johnpozJ Online
                                            @TangoOversway if you leave the dns blank - it will provide the IP address of pfsense interface.
                                            See when I delete - it shows the default which is pfsense IP on that interface
                                            See how its a gray color.
