Problems With WAN Loss Cobnection
And definitely not that speedtest cronjob? That would be my first suspect.
@stephenw10 said in Problems With WAN Loss Cobnection:
¿Y definitivamente no ese cronjob de prueba de velocidad? Ese sería mi primer sospechoso.
That one wasn’t present on all systems—some had it, but others didn’t—so I don’t think that was the root cause. Still, I’ve cleaned up the cron jobs to leave only the essential ones, and for now, everything seems stable.
I’m bringing an update: everything is running better now, with one exception. When Snort updates, something similar happens—the system becomes heavily loaded and somewhat unresponsive. I’ve noticed that two Snort processes remain running, and if it updates again, a third one appears. This causes the system to become overloaded, even though there should only be one Snort process running, since it's configured only on the LAN in Inline IPS mode.
I just ran the test right now.
Here are the logs shown in System:
Jun 29 18:34:00 php-cgi 91062 servicewatchdog_cron.php: Service Watchdog detected service telegraf stopped. Restarting telegraf (Telegraf daemon) Jun 29 18:33:26 php_pfb 79326 [pfBlockerNG] filterlog daemon started Jun 29 18:33:25 tail_pfb 79015 [pfBlockerNG] Firewall Filter Service started Jun 29 18:33:25 lighttpd_pfb 76804 [pfBlockerNG] DNSBL Webserver started Jun 29 18:33:25 lighttpd_pfb 74750 [pfBlockerNG] DNSBL Webserver stopped Jun 29 18:33:25 php_pfb 73650 [pfBlockerNG] filterlog daemon stopped Jun 29 18:33:25 tail_pfb 73212 [pfBlockerNG] Firewall Filter Service stopped Jun 29 18:33:19 php-fpm 57400 /rc.start_packages: Restarting/Starting all packages. Jun 29 18:33:18 check_reload_status 476 Reloading filter Jun 29 18:33:18 check_reload_status 476 Starting packages Jun 29 18:33:18 php-fpm 87641 /rc.newwanip: pfSense package system has detected an IP change or dynamic WAN reconnection - 192.168.2.1 -> 192.168.2.1 - Restarting packages. Jun 29 18:33:16 php-fpm 87641 /rc.newwanip: Creating rrd update script Jun 29 18:33:16 php-fpm 87641 /rc.newwanip: Resyncing OpenVPN instances for interface LAN. Jun 29 18:33:16 php-fpm 87641 /rc.newwanip: Ignoring IPsec reload since there are no tunnels on interface lan Jun 29 18:33:13 php-fpm 87641 /rc.newwanip: Gateway, NONE AVAILABLE Jun 29 18:33:12 php-fpm 87641 /rc.newwanip: Removing static route for monitor 8.8.8.8 and adding a new route through 192.168.0.1 Jun 29 18:33:00 php-cgi 37854 servicewatchdog_cron.php: Service Watchdog detected service telegraf stopped. Restarting telegraf (Telegraf daemon) Jun 29 18:32:59 php-fpm 87641 /rc.newwanip: rc.newwanip: on (IP address: 192.168.2.1) (interface: LAN[lan]) (real interface: em1). Jun 29 18:32:59 php-fpm 87641 /rc.newwanip: rc.newwanip: Info: starting on em1. Jun 29 18:32:58 check_reload_status 476 Reloading filter Jun 29 18:32:58 check_reload_status 476 rc.newwanip starting em1 Jun 29 18:32:58 php-fpm 33297 /rc.linkup: HOTPLUG: Triggering address refresh on lan (em1) Jun 29 18:32:58 php-fpm 33297 /rc.linkup: DEVD Ethernet attached event for lan Jun 29 18:32:58 php-fpm 33297 /rc.linkup: Hotplug event detected for LAN(lan) static IP address (4: 192.168.2.1) Jun 29 18:32:58 check_reload_status 476 Reloading filter Jun 29 18:32:56 php_pfb 12657 [pfBlockerNG] filterlog daemon started Jun 29 18:32:56 tail_pfb 12409 [pfBlockerNG] Firewall Filter Service started Jun 29 18:32:56 lighttpd_pfb 12380 [pfBlockerNG] DNSBL Webserver started Jun 29 18:32:56 lighttpd_pfb 9243 [pfBlockerNG] DNSBL Webserver stopped Jun 29 18:32:56 php_pfb 7656 [pfBlockerNG] filterlog daemon stopped Jun 29 18:32:56 tail_pfb 7195 [pfBlockerNG] Firewall Filter Service stopped Jun 29 18:32:52 kernel em1: link state changed to UP Jun 29 18:32:52 check_reload_status 476 Linkup starting em1 Jun 29 18:32:50 php-fpm 11935 /rc.start_packages: Restarting/Starting all packages. Jun 29 18:32:49 php-fpm 89037 /rc.linkup: DEVD Ethernet detached event for lan Jun 29 18:32:49 php-fpm 89037 /rc.linkup: Hotplug event detected for LAN(lan) static IP address (4: 192.168.2.1) Jun 29 18:32:49 check_reload_status 476 Reloading filter Jun 29 18:32:49 check_reload_status 476 Starting packages Jun 29 18:32:49 php-fpm 57400 /rc.newwanip: pfSense package system has detected an IP change or dynamic WAN reconnection - 192.168.2.1 -> 192.168.2.1 - Restarting packages. Jun 29 18:32:48 kernel em1: link state changed to DOWN Jun 29 18:32:48 check_reload_status 476 Linkup starting em1 Jun 29 18:32:48 kernel 768.603146 [ 852] iflib_netmap_config txr 2 rxr 2 txd 1024 rxd 1024 rbufsz 2048 Jun 29 18:32:47 php-fpm 57400 /rc.newwanip: Creating rrd update script Jun 29 18:32:47 php-fpm 57400 /rc.newwanip: Resyncing OpenVPN instances for interface LAN. Jun 29 18:32:47 php-fpm 57400 /rc.newwanip: Ignoring IPsec reload since there are no tunnels on interface lan Jun 29 18:32:42 php-fpm 57400 /rc.newwanip: Gateway, NONE AVAILABLE Jun 29 18:32:42 php-fpm 57400 /rc.newwanip: Removing static route for monitor 8.8.8.8 and adding a new route through 192.168.0.1 Jun 29 18:32:24 php-fpm 57400 /rc.newwanip: rc.newwanip: on (IP address: 192.168.2.1) (interface: LAN[lan]) (real interface: em1). Jun 29 18:32:24 php-fpm 57400 /rc.newwanip: rc.newwanip: Info: starting on em1. Jun 29 18:32:23 check_reload_status 476 Reloading filter Jun 29 18:32:23 check_reload_status 476 rc.newwanip starting em1 Jun 29 18:32:23 php-fpm 87641 /rc.linkup: HOTPLUG: Triggering address refresh on lan (em1) Jun 29 18:32:23 php-fpm 87641 /rc.linkup: DEVD Ethernet attached event for lan Jun 29 18:32:23 php-fpm 87641 /rc.linkup: Hotplug event detected for LAN(lan) static IP address (4: 192.168.2.1) Jun 29 18:32:22 kernel em1: link state changed to UP Jun 29 18:32:22 check_reload_status 476 Linkup starting em1 Jun 29 18:32:21 check_reload_status 476 Reloading filter Jun 29 18:32:19 php-fpm 11935 /rc.linkup: DEVD Ethernet detached event for lan Jun 29 18:32:19 php-fpm 11935 /rc.linkup: Hotplug event detected for LAN(lan) static IP address (4: 192.168.2.1) Jun 29 18:32:18 kernel em1: link state changed to DOWN Jun 29 18:32:18 check_reload_status 476 Linkup starting em1 Jun 29 18:32:18 php 37179 [Snort] The Rules update has finished. Jun 29 18:32:18 php 37179 [Snort] Snort has restarted on LAN with your new set of rules... Jun 29 18:32:18 kernel 738.705442 [ 852] iflib_netmap_config txr 2 rxr 2 txd 1024 rxd 1024 rbufsz 2048 Jun 29 18:32:00 php-cgi 78632 servicewatchdog_cron.php: Service Watchdog detected service telegraf stopped. Restarting telegraf (Telegraf daemon) Jun 29 18:31:22 php_pfb 61839 [pfBlockerNG] filterlog daemon started Jun 29 18:31:22 tail_pfb 61431 [pfBlockerNG] Firewall Filter Service started Jun 29 18:31:22 lighttpd_pfb 59064 [pfBlockerNG] DNSBL Webserver started Jun 29 18:31:22 lighttpd_pfb 57084 [pfBlockerNG] DNSBL Webserver stopped Jun 29 18:31:22 php_pfb 56006 [pfBlockerNG] filterlog daemon stopped Jun 29 18:31:22 tail_pfb 55454 [pfBlockerNG] Firewall Filter Service stopped Jun 29 18:31:13 SnortStartup 93013 Snort START for LAN(em1)... Jun 29 18:31:12 php-fpm 11935 /rc.start_packages: Restarting/Starting all packages. Jun 29 18:31:11 check_reload_status 476 Reloading filter Jun 29 18:31:11 check_reload_status 476 Starting packages Jun 29 18:31:11 php-fpm 40346 /rc.newwanip: pfSense package system has detected an IP change or dynamic WAN reconnection - 192.168.2.1 -> 192.168.2.1 - Restarting packages. Jun 29 18:31:09 php-fpm 40346 /rc.newwanip: Creating rrd update script Jun 29 18:31:09 php-fpm 40346 /rc.newwanip: Resyncing OpenVPN instances for interface LAN. Jun 29 18:31:09 php-fpm 40346 /rc.newwanip: Ignoring IPsec reload since there are no tunnels on interface lan Jun 29 18:31:04 php-fpm 40346 /rc.newwanip: Gateway, NONE AVAILABLE Jun 29 18:31:04 php-fpm 40346 /rc.newwanip: Removing static route for monitor 8.8.8.8 and adding a new route through 192.168.0.1 Jun 29 18:30:49 php-fpm 40346 /rc.newwanip: rc.newwanip: on (IP address: 192.168.2.1) (interface: LAN[lan]) (real interface: em1). Jun 29 18:30:49 php-fpm 40346 /rc.newwanip: rc.newwanip: Info: starting on em1. Jun 29 18:30:48 check_reload_status 476 Reloading filter Jun 29 18:30:48 check_reload_status 476 rc.newwanip starting em1 Jun 29 18:30:48 php-fpm 40346 /rc.linkup: HOTPLUG: Triggering address refresh on lan (em1) Jun 29 18:30:48 php-fpm 40346 /rc.linkup: DEVD Ethernet attached event for lan Jun 29 18:30:48 php-fpm 40346 /rc.linkup: Hotplug event detected for LAN(lan) static IP address (4: 192.168.2.1) Jun 29 18:30:47 kernel em1: link state changed to UP Jun 29 18:30:47 check_reload_status 476 Linkup starting em1 Jun 29 18:30:46 check_reload_status 476 Reloading filter Jun 29 18:30:45 snort 42755 AppInfo: AppId 5349 is UNKNOWN Jun 29 18:30:45 snort 42755 Invalid direct service AppId, 5349, for 0x842745c70 0x1aa0e5f24800 Jun 29 18:30:45 snort 42755 AppInfo: AppId 4903 is UNKNOWN Jun 29 18:30:45 snort 42755 AppId Jun 29 18:30:45 snort 42755 AppId Jun 29 18:30:44 snort 42755 AppId Jun 29 18:30:44 php-fpm 11935 /rc.linkup: DEVD Ethernet detached event for lan Jun 29 18:30:44 php-fpm 11935 /rc.linkup: Hotplug event detected for LAN(lan) static IP address (4: 192.168.2.1) Jun 29 18:30:44 php 37179 [Snort] Snort START for LAN(em1)... Jun 29 18:30:43 kernel em1: link state changed to DOWN Jun 29 18:30:43 check_reload_status 476 Linkup starting em1 Jun 29 18:30:43 snort 98159 *** Caught Term-Signal Jun 29 18:30:42 php 37179 [Snort] Snort STOP for LAN(em1)... Jun 29 18:30:41 php 37179 [Snort] Building new sid-msg.map file for LAN... Jun 29 18:30:41 php 37179 [Snort] Enabling any flowbit-required rules for: LAN... Jun 29 18:30:41 php 37179 [Snort] Error - unable to find reject_sid list "none" specified for LAN Jun 29 18:30:41 php 37179 [Snort] Error - unable to find drop_sid list "none" specified for LAN Jun 29 18:30:38 php 37179 [Snort] Updating rules configuration for: LAN ... Jun 29 18:30:38 php 37179 [Snort] Removed 0 obsoleted rules category files. Jun 29 18:30:38 php 37179 [Snort] Hide Deprecated Rules is enabled. Removing obsoleted rules categories. Jun 29 18:30:38 php 37179 [Snort] Feodo Tracker Botnet C2 IP rules were updated... Jun 29 18:30:38 php 37179 [Snort] Feodo Tracker Botnet C2 IP rules file update downloaded successfully. Jun 29 18:30:38 php 37179 [Snort] Emerging Threats Open rules are up to date... Jun 29 18:30:38 php 37179 [Snort] Snort GPLv2 Community Rules are up to date... Jun 29 18:30:37 php 37179 [Snort] Snort AppID Open Text Rules are up to date... Jun 29 18:30:36 php 37179 [Snort] Snort OpenAppID detectors are up to date... Jun 29 18:30:36 php 37179 [Snort] Snort Subscriber rules are up to date...Here you can see that Snort’s log shows the update completes very quickly:
Starting rules update... Time: 2025-06-29 18:30:35 Downloading Snort Subscriber rules md5 file snortrules-snapshot-29200.tar.gz.md5... Checking Snort Subscriber rules md5 file... Snort Subscriber rules are up to date. Downloading Snort OpenAppID detectors md5 file snort-openappid.tar.gz.md5... Checking Snort OpenAppID detectors md5 file... Snort OpenAppID detectors are up to date. Downloading Snort AppID Open Text Rules md5 file appid_rules.tar.gz.md5... Checking Snort AppID Open Text Rules md5 file... Snort AppID Open Text Rules are up to date. Downloading Snort GPLv2 Community Rules md5 file community-rules.tar.gz.md5... Checking Snort GPLv2 Community Rules md5 file... Snort GPLv2 Community Rules are up to date. Downloading Emerging Threats Open rules md5 file emerging.rules.tar.gz.md5... Checking Emerging Threats Open rules md5 file... Emerging Threats Open rules are up to date. Downloading Feodo Tracker Botnet C2 IP rules file... Done downloading rules file. Extracting and installing Feodo Tracker Botnet C2 IP rules... Feodo Tracker Botnet C2 IP rules were updated. Copying new config and map files... Updating rules configuration for: LAN ... Restarting Snort on LAN to activate the new set of rules... Snort has restarted on LAN with your new set of rules. The Rules update has finished. Time: 2025-06-29 18:32:18And the gateway:
Jun 29 18:43:39 dpinger 16187 send_interval 500ms loss_interval 2000ms time_period 60000ms report_interval 0ms data_len 1 alert_interval 1000ms latency_alarm 500ms loss_alarm 20% alarm_hold 10000ms dest_addr 8.8.8.8 bind_addr 192.168.0.20 identifier "WAN_DHCP " Jun 29 18:43:39 dpinger 22451 exiting on signal 15 Jun 29 18:42:11 dpinger 22451 send_interval 500ms loss_interval 2000ms time_period 60000ms report_interval 0ms data_len 1 alert_interval 1000ms latency_alarm 500ms loss_alarm 20% alarm_hold 10000ms dest_addr 8.8.8.8 bind_addr 192.168.0.20 identifier "WAN_DHCP " Jun 29 18:42:11 dpinger 32634 exiting on signal 15 Jun 29 18:41:55 dpinger 32634 send_interval 500ms loss_interval 2000ms time_period 60000ms report_interval 0ms data_len 1 alert_interval 1000ms latency_alarm 500ms loss_alarm 20% alarm_hold 10000ms dest_addr 8.8.8.8 bind_addr 192.168.0.20 identifier "WAN_DHCP " Jun 29 18:41:55 dpinger 62920 exiting on signal 15 Jun 29 18:40:30 dpinger 62920 send_interval 500ms loss_interval 2000ms time_period 60000ms report_interval 0ms data_len 1 alert_interval 1000ms latency_alarm 500ms loss_alarm 20% alarm_hold 10000ms dest_addr 8.8.8.8 bind_addr 192.168.0.20 identifier "WAN_DHCP " Jun 29 18:40:30 dpinger 61345 exiting on signal 15 Jun 29 18:33:13 dpinger 61345 send_interval 500ms loss_interval 2000ms time_period 60000ms report_interval 0ms data_len 1 alert_interval 1000ms latency_alarm 500ms loss_alarm 20% alarm_hold 10000ms dest_addr 8.8.8.8 bind_addr 192.168.0.20 identifier "WAN_DHCP " Jun 29 18:33:12 dpinger 86243 exiting on signal 15 Jun 29 18:32:42 dpinger 86243 send_interval 500ms loss_interval 2000ms time_period 60000ms report_interval 0ms data_len 1 alert_interval 1000ms latency_alarm 500ms loss_alarm 20% alarm_hold 10000ms dest_addr 8.8.8.8 bind_addr 192.168.0.20 identifier "WAN_DHCP " Jun 29 18:32:42 dpinger 26696 exiting on signal 15 Jun 29 18:31:04 dpinger 26696 send_interval 500ms loss_interval 2000ms time_period 60000ms report_interval 0ms data_len 1 alert_interval 1000ms latency_alarm 500ms loss_alarm 20% alarm_hold 10000ms dest_addr 8.8.8.8 bind_addr 192.168.0.20 identifier "WAN_DHCP " Jun 29 18:31:04 dpinger 78346 exiting on signal 15It loses connectivity and everything starts behaving erratically.
Logs from anothe:
2025-06-29 18:15:37.362731+02:00 xinetd 5473 Swapping defaults 2025-06-29 18:15:37.362131+02:00 xinetd 5473 Starting reconfiguration 2025-06-29 18:15:31.770460+02:00 kernel - arp: 08:00:27:66:1d:d1 is using my IP address 192.168.255.254 on igc1! 2025-06-29 18:15:31.497019+02:00 php-fpm 38706 /rc.newwanip: rc.newwanip: on (IP address: 172.16.0.1) (interface: LAN[lan]) (real interface: igc1). 2025-06-29 18:15:31.496546+02:00 php-fpm 38706 /rc.newwanip: rc.newwanip: Info: starting on igc1. 2025-06-29 18:15:30.422269+02:00 check_reload_status 674 Reloading filter 2025-06-29 18:15:30.416622+02:00 check_reload_status 674 rc.newwanip starting igc1 2025-06-29 18:15:30.416106+02:00 php-fpm 38706 /rc.linkup: HOTPLUG: Triggering address refresh on lan (igc1) 2025-06-29 18:15:30.415927+02:00 php-fpm 38706 /rc.linkup: DEVD Ethernet attached event for lan 2025-06-29 18:15:30.404027+02:00 php-fpm 38706 /rc.linkup: Hotplug event detected for LAN(lan) static IP address (4: 172.16.0.1) 2025-06-29 18:15:29.755530+02:00 xinetd 5473 Reconfigured: new=0 old=6 dropped=0 (services) 2025-06-29 18:15:29.755518+02:00 xinetd 5473 readjusting service 19005-udp 2025-06-29 18:15:29.755507+02:00 xinetd 5473 readjusting service 19004-udp 2025-06-29 18:15:29.755495+02:00 xinetd 5473 readjusting service 19003-tcp 2025-06-29 18:15:29.755484+02:00 xinetd 5473 readjusting service 19002-tcp 2025-06-29 18:15:29.755473+02:00 xinetd 5473 readjusting service 19001-tcp 2025-06-29 18:15:29.755460+02:00 xinetd 5473 readjusting service 19000-tcp 2025-06-29 18:15:29.755443+02:00 xinetd 5473 Swapping defaults 2025-06-29 18:15:29.754868+02:00 xinetd 5473 Starting reconfiguration 2025-06-29 18:15:29.351604+02:00 kernel - igc1: link state changed to UP 2025-06-29 18:15:29.321806+02:00 check_reload_status 674 Linkup starting igc1 2025-06-29 18:15:28.610587+02:00 check_reload_status 674 Reloading filter 2025-06-29 18:15:28.610258+02:00 check_reload_status 674 Reloading filter 2025-06-29 18:15:26.838367+02:00 php-fpm 43924 /rc.linkup: DEVD Ethernet detached event for lan 2025-06-29 18:15:26.822283+02:00 php-fpm 43924 /rc.linkup: Hotplug event detected for LAN(lan) static IP address (4: 172.16.0.1) 2025-06-29 18:15:25.912662+02:00 kernel - igc1: link state changed to DOWN 2025-06-29 18:15:25.763694+02:00 php 80125 [Snort] The Rules update has finished. 2025-06-29 18:15:25.762352+02:00 php 80125 [Snort] Snort has restarted on LAN with your new set of rules... 2025-06-29 18:15:25.731979+02:00 check_reload_status 674 Linkup starting igc1 2025-06-29 18:15:25.711985+02:00 kernel - 725.693258 [ 852] iflib_netmap_config txr 4 rxr 4 txd 1024 rxd 1024 rbufsz 2048 2025-06-29 18:15:25.711692+02:00 kernel - 725.656339 [ 852] iflib_netmap_config txr 4 rxr 4 txd 1024 rxd 1024 rbufsz 2048 .............. 2025-06-29 18:15:09.626165+02:00 snort 78173 AppInfo: AppId 4903 is UNKNOWN 2025-06-29 18:15:09.625169+02:00 snort 78173 AppId 2025-06-29 18:15:09.625141+02:00 snort 78173 AppId 2025-06-29 18:15:09.305900+02:00 php_pfb 89791 [pfBlockerNG] filterlog daemon started 2025-06-29 18:15:09.006181+02:00 snort 78173 AppId 2025-06-29 18:15:08.960122+02:00 tail_pfb 89291 [pfBlockerNG] Firewall Filter Service started 2025-06-29 18:15:08.910306+02:00 lighttpd_pfb 85817 [pfBlockerNG] DNSBL Webserver started 2025-06-29 18:15:08.900608+02:00 php_pfb 84265 [pfBlockerNG] filterlog daemon stopped 2025-06-29 18:15:08.891790+02:00 tail_pfb 83152 [pfBlockerNG] Firewall Filter Service stopped 2025-06-29 18:15:08.886751+02:00 lighttpd_pfb 82101 [pfBlockerNG] DNSBL Webserver stopped 2025-06-29 18:15:08.811564+02:00 SnortStartup 78044 Snort START for LAN(igc1)... 2025-06-29 18:15:01.391170+02:00 php-fpm 61163 /rc.start_packages: The command '/usr/local/bin/redis-cli shutdown save' returned exit code '1', the output was 'Could not connect to Redis at 127.0.0.1:6379: Connection refused' 2025-06-29 18:15:01.246646+02:00 xinetd 5473 Reconfigured: new=0 old=6 dropped=0 (services) 2025-06-29 18:15:01.246629+02:00 xinetd 5473 readjusting service 19005-udp 2025-06-29 18:15:01.246619+02:00 xinetd 5473 readjusting service 19004-udp 2025-06-29 18:15:01.246608+02:00 xinetd 5473 readjusting service 19003-tcp 2025-06-29 18:15:01.246598+02:00 xinetd 5473 readjusting service 19002-tcp 2025-06-29 18:15:01.246587+02:00 xinetd 5473 readjusting service 19001-tcp 2025-06-29 18:15:01.246573+02:00 xinetd 5473 readjusting service 19000-tcp 2025-06-29 18:15:01.246558+02:00 xinetd 5473 Swapping defaults 2025-06-29 18:15:01.246282+02:00 php-cgi 75901 servicewatchdog_cron.php: Service Watchdog detected service ntopng stopped. Restarting ntopng (ntopng Network Traffic Monitor) 2025-06-29 18:15:01.245996+02:00 xinetd 5473 Starting reconfiguration 2025-06-29 18:14:56.201498+02:00 php-fpm 61163 /rc.start_packages: [filer] XMLRPC sync completed. 2025-06-29 18:14:56.201329+02:00 php-fpm 61163 /rc.start_packages: XMLRPC reload data success with https://172.16.0.250:443/xmlrpc.php (pfsense.exec_php). 2025-06-29 18:14:56.143762+02:00 php-fpm 61163 /rc.start_packages: Beginning XMLRPC sync data to https://172.16.0.250:443/xmlrpc.php. 2025-06-29 18:14:56.143567+02:00 php-fpm 61163 /rc.start_packages: XMLRPC reload data success with https://172.16.0.250:443/xmlrpc.php (pfsense.merge_installedpackages_section). 2025-06-29 18:14:56.039883+02:00 xinetd 5473 Reconfigured: new=0 old=6 dropped=0 (services) 2025-06-29 18:14:56.039870+02:00 xinetd 5473 readjusting service 19005-udp 2025-06-29 18:14:56.039858+02:00 xinetd 5473 readjusting service 19004-udp 2025-06-29 18:14:56.039845+02:00 xinetd 5473 readjusting service 19003-tcp 2025-06-29 18:14:56.039833+02:00 xinetd 5473 readjusting service 19002-tcp 2025-06-29 18:14:56.039819+02:00 xinetd 5473 readjusting service 19001-tcp 2025-06-29 18:14:56.039803+02:00 xinetd 5473 readjusting service 19000-tcp 2025-06-29 18:14:56.039759+02:00 xinetd 5473 Swapping defaults 2025-06-29 18:14:56.038972+02:00 xinetd 5473 Starting reconfiguration 2025-06-29 18:14:56.008761+02:00 php-fpm 61163 /rc.start_packages: Beginning XMLRPC sync data to https://172.16.0.250:443/xmlrpc.php. 2025-06-29 18:14:56.008491+02:00 php-fpm 61163 /rc.start_packages: [filer] XMLRPC sync is starting. 2025-06-29 18:14:55.961051+02:00 php-fpm 61163 /rc.start_packages: Restarting/Starting all packages. 2025-06-29 18:14:55.335888+02:00 snmpd 31536 disk_OS_get_disks: adding device 'ada0' to device list 2025-06-29 18:14:54.886390+02:00 check_reload_status 674 Reloading filter 2025-06-29 18:14:54.886167+02:00 check_reload_status 674 Reloading filter 2025-06-29 18:14:54.880664+02:00 check_reload_status 674 Starting packages 2025-06-29 18:14:54.877863+02:00 php-fpm 43924 /rc.newwanip: Netgate pfSense Plus package system has detected an IP change or dynamic WAN reconnection - 172.16.0.1 -> 172.16.0.1 - Restarting packages. 2025-06-29 18:14:52.824789+02:00 php-fpm 43924 /rc.newwanip: Creating rrd update script 2025-06-29 18:14:52.813951+02:00 php-fpm 43924 /rc.newwanip: Resyncing OpenVPN instances for interface LAN. 2025-06-29 18:14:52.813759+02:00 php-fpm 43924 /rc.newwanip: Ignoring IPsec reload since there are no tunnels on interface lan 2025-06-29 18:14:51.000511+02:00 php-fpm 43924 /rc.newwanip: Gateway, NONE AVAILABLE 2025-06-29 18:14:50.992722+02:00 php-fpm 43924 /rc.newwanip: Gateway, NONE AVAILABLE 2025-06-29 18:14:50.431380+02:00 php-fpm 43924 /rc.newwanip: Removing static route for monitor 8.8.8.8 and adding a new route through 10.0.11.213 2025-06-29 18:14:48.302102+02:00 xinetd 5473 Reconfigured: new=0 old=6 dropped=0 (services) 2025-06-29 18:14:42.208377+02:00 xinetd 5473 readjusting service 19005-udp 2025-06-29 18:14:42.208365+02:00 xinetd 5473 readjusting service 19004-udp 2025-06-29 18:14:42.208355+02:00 xinetd 5473 readjusting service 19003-tcp 2025-06-29 18:14:42.208344+02:00 xinetd 5473 readjusting service 19002-tcp 2025-06-29 18:14:42.208331+02:00 xinetd 5473 readjusting service 19001-tcp 2025-06-29 18:14:42.208318+02:00 xinetd 5473 readjusting service 19000-tcp 2025-06-29 18:14:42.208296+02:00 xinetd 5473 Swapping defaults 2025-06-29 18:14:42.207693+02:00 xinetd 5473 Starting reconfiguration 2025-06-29 18:14:36.769668+02:00 kernel - arp: 08:00:27:66:1d:d1 is using my IP address 192.168.255.254 on igc1! 2025-06-29 18:14:36.416400+02:00 php-fpm 43924 /rc.newwanip: rc.newwanip: on (IP address: 172.16.0.1) (interface: LAN[lan]) (real interface: igc1). 2025-06-29 18:14:36.415680+02:00 php-fpm 43924 /rc.newwanip: rc.newwanip: Info: starting on igc1. 2025-06-29 18:14:35.338815+02:00 check_reload_status 674 Reloading filter 2025-06-29 18:14:35.333780+02:00 check_reload_status 674 rc.newwanip starting igc1 2025-06-29 18:14:35.333293+02:00 php-fpm 43924 /rc.linkup: HOTPLUG: Triggering address refresh on lan (igc1) 2025-06-29 18:14:35.333114+02:00 php-fpm 43924 /rc.linkup: DEVD Ethernet attached event for lan 2025-06-29 18:14:35.319985+02:00 php-fpm 43924 /rc.linkup: Hotplug event detected for LAN(lan) static IP address (4: 172.16.0.1) 2025-06-29 18:14:34.964935+02:00 xinetd 5473 Reconfigured: new=0 old=6 dropped=0 (services) 2025-06-29 18:14:34.964923+02:00 xinetd 5473 readjusting service 19005-udp 2025-06-29 18:14:34.964912+02:00 xinetd 5473 readjusting service 19004-udp 2025-06-29 18:14:34.964901+02:00 xinetd 5473 readjusting service 19003-tcp 2025-06-29 18:14:34.964891+02:00 xinetd 5473 readjusting service 19002-tcp 2025-06-29 18:14:34.964880+02:00 xinetd 5473 readjusting service 19001-tcp 2025-06-29 18:14:34.964867+02:00 xinetd 5473 readjusting service 19000-tcp 2025-06-29 18:14:34.964849+02:00 xinetd 5473 Swapping defaults 2025-06-29 18:14:34.964295+02:00 xinetd 5473 Starting reconfiguration 2025-06-29 18:14:34.357670+02:00 kernel - igc1: link state changed to UP 2025-06-29 18:14:34.233345+02:00 check_reload_status 674 Linkup starting igc1 2025-06-29 18:14:33.851814+02:00 check_reload_status 674 Reloading filter 2025-06-29 18:14:33.820590+02:00 check_reload_status 674 Reloading filter 2025-06-29 18:14:33.619210+02:00 snort 48132 AppInfo: AppId 2314 is UNKNOWN 2025-06-29 18:14:33.619161+02:00 snort 48132 Invalid direct service AppId, 2314, for 0x841db4d60 0x2cf3fffcd880 ........ 2025-06-29 18:14:33.589595+02:00 snort 48132 AppInfo: AppId 4140 is UNKNOWN 2025-06-29 18:14:33.589520+02:00 snort 48132 AppInfo: AppId 4140 is UNKNOWN 2025-06-29 18:14:33.588731+02:00 snort 48132 AppId 2025-06-29 18:14:33.588575+02:00 snort 48132 AppId 2025-06-29 18:14:32.941276+02:00 snort 48132 AppId 2025-06-29 18:14:32.733089+02:00 php 80125 [Snort] Snort START for LAN(igc1)... 2025-06-29 18:14:31.926833+02:00 php-fpm 38706 /rc.linkup: DEVD Ethernet detached event for lan 2025-06-29 18:14:31.906676+02:00 php-fpm 38706 /rc.linkup: Hotplug event detected for LAN(lan) static IP address (4: 172.16.0.1) 2025-06-29 18:14:30.713792+02:00 kernel - igc1: link state changed to DOWN 2025-06-29 18:14:30.672230+02:00 check_reload_status 674 Linkup starting igc1 2025-06-29 18:14:30.641688+02:00 snort 6713 *** Caught Term-Signal 2025-06-29 18:14:30.634302+02:00 php 80125 [Snort] Snort STOP for LAN(igc1)...Update:
This only happens when Inline IPS mode is enabled.
If you disable Blocking Mode or switch to Legacy Mode, the update runs fine—the interfaces restart correctly and everything works as expected.
However, when Blocking Mode is set to Inline IPS, that’s when the system hangs and behaves erratically. -
When it runs in in-line mode it bounces the link which restarts all services. It looks like it does that several times and those restart processes cause significant load. On top of that you have the watchdog enabled and that is restarting services too. That's probably unecessary and those were restarting anyway.
@stephenw10 i only have for telegraf and ipsec:
What I’ve noticed is that if I stop the service manually, it restarts automatically in less than 20 seconds. So the problem seems to be that during the update, it starts a new instance of the service, and then ends up spawning a second one.
Jun 30 09:22:28 SnortStartup 65366 Snort START for LAN(em1)... Jun 30 09:22:28 php-fpm 435 /rc.start_packages: Restarting/Starting all packages. Jun 30 09:22:27 check_reload_status 479 Reloading filter Jun 30 09:22:27 check_reload_status 479 Starting packages Jun 30 09:22:27 php-fpm 8814 /rc.newwanip: pfSense package system has detected an IP change or dynamic WAN reconnection - 192.168.2.1 -> 192.168.2.1 - Restarting packages. Jun 30 09:22:25 php-fpm 8814 /rc.newwanip: Creating rrd update script Jun 30 09:22:25 php-fpm 8814 /rc.newwanip: Resyncing OpenVPN instances for interface LAN. Jun 30 09:22:25 php-fpm 8814 /rc.newwanip: Ignoring IPsec reload since there are no tunnels on interface lan Jun 30 09:22:22 php-fpm 8814 /rc.newwanip: Gateway, NONE AVAILABLE Jun 30 09:22:21 php-fpm 8814 /rc.newwanip: Removing static route for monitor 8.8.8.8 and adding a new route through 192.168.0.1 Jun 30 09:22:09 php-fpm 8814 /rc.newwanip: rc.newwanip: on (IP address: 192.168.2.1) (interface: LAN[lan]) (real interface: em1). Jun 30 09:22:09 php-fpm 8814 /rc.newwanip: rc.newwanip: Info: starting on em1. Jun 30 09:22:08 check_reload_status 479 Reloading filter Jun 30 09:22:08 check_reload_status 479 rc.newwanip starting em1 Jun 30 09:22:08 php-fpm 8814 /rc.linkup: HOTPLUG: Triggering address refresh on lan (em1) Jun 30 09:22:08 php-fpm 8814 /rc.linkup: DEVD Ethernet attached event for lan Jun 30 09:22:08 php-fpm 8814 /rc.linkup: Hotplug event detected for LAN(lan) static IP address (4: 192.168.2.1) Jun 30 09:22:07 kernel em1: link state changed to UP Jun 30 09:22:07 check_reload_status 479 Linkup starting em1 Jun 30 09:22:07 check_reload_status 479 Reloading filter Jun 30 09:22:05 php-fpm 81789 /rc.linkup: DEVD Ethernet detached event for lan Jun 30 09:22:05 php-fpm 81789 /rc.linkup: Hotplug event detected for LAN(lan) static IP address (4: 192.168.2.1) Jun 30 09:22:04 kernel em1: link state changed to DOWN Jun 30 09:22:04 check_reload_status 479 Linkup starting em1 Jun 30 09:22:04 snort 96451 *** Caught Term-Signal Jun 30 09:22:03 SnortStartup 34465 Snort STOP for LAN(em1)... -
@dcuadrados said in Problems With WAN Loss Cobnection:
IPSEC is an 'interface' bound process for sure.
So, when an interface gets restarted, process gets restarted.
The watchdog detects that IPSEC is restating (= stopped first), so it restart IPSEC, which will restart IPSEC so it restarts IPSEC so it restart .....You see the problem?
That's the job of watchdog.
But, even that reaction is totally wrong.
If you, as an admin, stops a process like IPSEC, then that's for a - your - reason, for example maintenance.
You don't want it to restart all by itself.
You stopped it.
So ... you start it - when needed.and live will be easier.
@Gertjan said in Problems With WAN Loss Cobnection:
IPSEC es sin duda un proceso vinculado a una 'interfaz'.
Entonces, cuando se reinicia una interfaz, se reinicia el proceso.
El organismo de control detecta que IPSEC se está reiniciando (= se detuvo primero), por lo que reinicia IPSEC, que reiniciará IPSEC para que reinicie IPSEC para que se reinicie .....¿Ves el problema?
I’m testing this by completely removing Watchdog, and Snort still restarts on its own—even without an IPsec tunnel, on a freshly installed firewall. When you stop Snort, it automatically starts again.
So during the update process, since Snort is already running after being restarted automatically, the update then tries to start it again—and voilà, you end up with two processes for a single interface and a highly unstable firewall.
Also : what's connected to your LAN :
Even if this :@dcuadrados said in Problems With WAN Loss Cobnection:
Jun 29 18:32:58 php-fpm 33297 /rc.linkup: Hotplug event detected for LAN(lan) static IP address (4: 192.168.2.1)isn't wrong per se, but you, as an pfSense admin, you really don't want your pfSense interfaces to get disconnected.
Ok, sometimes, it can happen, or has to happen.
Make it a one per month experience and you'll be way better. -
no está mal per se, pero usted, como administrador de pfSense, realmente no quiere que sus interfaces de pfSense se desconecten.
Ok, a veces, puede suceder, o tiene que suceder.
Haz que sea una experiencia de uno por mes y estarás mucho mejor.I currently have the update set to every 28 days and I'm running some tests, but I don’t understand why Snort restarts by itself. As you rightly said—as the administrator, if you stop a service, it’s for a reason. It shouldn't start again automatically. That behavior makes no sense at all.
For now, I’ve scheduled it to update every 28 days. The issue is that every time it updates, it always creates a second “interface” and ends up spawning two processes.
Not just snort, many process (dhcp, unbound, dpinger, the GUI, etc etc etc) get restarted when interfaces disconnected > reconnect.
So, as said above :isn't wrong per se, but you, as an pfSense admin, you really don't want your pfSense interfaces to get disconnected.
as that restarts everything.
@Gertjan I think it’s fine for Snort to restart if needed, but an update shouldn’t generate two processes. The issue isn’t just having two processes—it’s the overall instability it causes in the entire system.
Very true.
That's why I monitor it, the same way they do so at the hospital.The best experience will come from a pfSense where you didn't add any 'extra' functionality. A native pfSense can keep on humming without anything noticeable for days, if not weeks.
See my stats, every time it reboorts, it was me typing 'reboot', or updating the system. Sudden freezes or lost WAN. Not that I recall - nothing in 2025.Ask yourself : do you need snort ?
As all, 99,9 % or more, is TLS encrypted, how can snort 'see' the data and scan for rule matches ?
The only thing that snort still can see is the packet header : source and destination IP, source and destination port, and a couple of flags .... that's, imho, not worth it. -
@Gertjan When someone is right, you have to give them credit. I’d give you a Like if I could!
When using Inline IPS Mode, the netmap kernel code will "cycle" the underlying physical FreeBSD interface. That causes the pfSense code to think the cable was unplugged and then plugged back in (see the HOTPLUG linkup messages). HOTPLUG detection results in pfSense automatically restarting the packages in case any of them might need to be aware of a potentially new IP address.
For what it's worth, I've not observed the restart problem with Snort that you describe in my testing on virtual machines. If I stop Snort, it says stopped in the GUI. Now, if something makes pfSense itself decide to restart all packages, it's certainly possible for Snort to get restarted by pfSense unless it is disabled on the interface.
This HOTPLUG event is relatively new in FreeBSD with netmap. Back when I first added Inline IPS Mode to Snort I don't recall that happening. It started happening a few years later as the FreeBSD version evolved. Perhaps it has something to do with the migration of the
iflibwrapper in FreeBSD ???But as @Gertjan said: "Ask yourself : do you need snort ? As all, 99,9 % or more, is TLS encrypted, how can snort 'see' the data and scan for rule matches ? The only thing that snort still can see is the packet header : source and destination IP, source and destination port, and a couple of flags"
I maintain the Snort package and created the Suricata package, and I don't run either of them on my home network firewall. No benefit unless you perform MITM SSL interception. Don't want to deal with that hassle for sure. IDS/IPS was a valuable tool back in the day when perimeter network traffic was largely cleartext and easily scanned. That tool is not very effective today when the vast majority of perimeter network traffic is encrypted. It can still sort of work in large enterprise environments where you can tightly control all the devices (including mobile ones) and put the necessary trusted intermediate CA certs on them to allow MITM SSL interception and you have an integrated system from one vendor such as Palo Alto or Cisco, etc. You also must pay them a small fortune in annual licensing fees, though.
@bmeeks Since I can't give you a Like (
), I'll do it this way instead!
I’m just one reputation point away from being able to give Likes. -
