Strange Routing Issue
I'll try the filer reload thing
ThanksThe alerts are an error that kept coming up after I restored a backup - with some mismatched interface assignments - etc
Do you have any suggestions on how to get rid of the error?
Can I get rid of the issue at an ssh level ??If I recall right it is a rule on an interface or network that doesn't even exist and is not shown in the GUI
The tailscale interface should not be assigned.
While you guys are following this thread
Off topic
But an alternative for me to keep working on my new setup — can you guide me on how I could connect the WAN port on my second pfsense device to my existing LAN so that I at least have better internet but get to stay in my “new” and separate network
When I connect the wan (set on dhcp) port to a switch connected to my first pfsense lan I am not able to get internet
Is there something special that needs to be done to access internet from the second network and pfsense device? -
Could be a subnet conflict if they both have the same LAN subnet. That will be an issue when you try to tunnel traffic between them also if so. Change the LAN subnet on the new device to something unused.
Otherwise nothing special should be required there. The default WAN setup as DHCP should work fine behind another pfSense install.
