    HELP - FreeSwitch again, now from a clean slate
    33 Posts 4 Posters 29.6k Views
      cybrsrfr
      FusionPBX on pfSense
      1. Install FreeSWITCH easiest way is to install the FreeSWITCH pfSense package.
      2. Install the vHosts pacakge. (vHosts - virtual hosts)
      3. Setup fusionpbx.local in the dns forwarder package to point to the LAN IP of pfSense.
      4. Setup 'fusionpbx' website in the vHosts package with port 8001 or the port of your choice that is not used.
      5. After adding fusionpbx restart the vhosts web service. Then make sure you can view the phpinfo example page.
      6. From the console via ssh run the following or from Diagnostics -> Command
      cd /usr/local/vhosts/;fetch http://fusionpbx.com/downloads/fusionpbx-1.0.tar.gz
      cd /usr/local/vhosts/;tar xvf fusionpbx-1.0.tar.gz
      7. Open the web browser and you should see the install page. By default SQLite will be selected. The defaults should be fine.
      8. From the install page press save.
      9. Login to the FusionPBX with superadmin or admin with a password of FusionPBX.
      10. For configurations help please see.
      http://www.fusionpbx.com
      http://wiki.fusionpbx.com
      http://fusionpbx.com/support.php
      http://doc.pfsense.org/index.php/FreeSWITCH
      http://wiki.freeswitch.org
      • F Offline
        fribert
        Not a lot of new features in the fusionpbx compared to the pfsense package, but it looks a bit better.
        Is the fusionpbx going to be made a package as well (nudge nudge  :P)
        • chpalmerC Offline
          chpalmer
          Thanks Mark!
          Appreciate all the help….    :)
            cybrsrfr
            There is a lot of new tools too give you greater access to FreeSWITCH, and make it easier to use.
            • Public is now called 'Inbound Routes'
            • Template manager allows you to change the look and feel.
            • Menu manager allows you to change
            • XML Editor is for advanced users that want access to FreeSWITCH on a deeper level.
            • PHP Editor again for advanced users that know PHP
            • Script Editor allowing advanced users ability to add or modify scripts.
            • Dialplan and Inbound routes has a tool for 'add' that makes adding new entries much easier and faster.
            • Users can log into view their voicemail's
            • Users can be assigned to one or more extensions.
            • Database backend that can use SQLite, PostgreSQL, or MySQL. On pfSense it requires SQLite.
            And some new features. Keep in mind this took months to make multi-platform.
            • Additional features in Hunt groups
            • Additional features in the Auto Attendant
            • Conference interface to make it easier to add voice conference rooms with or without a pin number
            • Softphone that is if you have a have a sound card installed on the system
            • Ability to run multi-tenant with multiple instances of FreeSWITCH
            • Contact list
            Features that I'm currently working on.
            Call Broadcast make a recording and send it to a group of contacts.
            Call Forward transfer calls destined for an extension out to a cell phone.
            Call Queues possible before but this interface will make it easier.
            Automatic Phone provisioning
              TreeTopFlyer
              FusionPBX install on pfSense worked like a charm Mark.  Mucho gracias mi amigo.
              • F Offline
                fribert
                Ok, got fusionpbx up and running.
                Is there an way to import the current config, or is it entering all over again?
                • F Offline
                  fribert
                  Grrrr, a warning on the fusionpbx install, it smashes up your existing config, damnation, thank god for frequent backups.
                  So this is a warning if you want to use this and have a working config!
                  An import of the existing would be appropriate.
                    cybrsrfr
                    It should be obvious that making a backup before doing such a thing is always a good idea to make a backup. However, the install should make a backup of your config and call into a directory called config.orig.
                    There isn't an import yet.  No one has offered to help with the import either monetarily or with developer help. I do get complaints that it isn't there. Complaints don't provide me any motivation. You have no idea what I've sacrificed over the past year and a half to build this and make it available for you and others.
                    I may still build the import but it isn't my first priority. A future FusionPBX pfSense package is higher priority and features to get or stay ahead of competition, and provide tools that make FusionPBX fit more peoples needs are all a higher priority.
                      cybrsrfr
                      Improved the vhosts package several minor improvements. The major change is that it now works on pfSense 2.0 with FreeBSD 8.0. vhosts on pfsense 2.0 will now make it much easier to run FusionPBX on pfSense 2.0.
                      • chpalmerC Offline
                        chpalmer
                        @mcrane:
                        Thank You!    :)
                        • F Offline
                          fribert
                          Hi mcrane
                          Don't take my grrr, as a complaint, but a warning on the install would be nice  ;D
                          And the excuse with 'you should alway backup' just doesn't do! That's simply a cop out for failing to do the warning.
                          • chpalmerC Offline
                            chpalmer
                            came off wrong. Struck comment
                            • F Offline
                              fribert
                              He he he, or version 2 or…
                              Oh well, I'm going to ponder on the idea of reentering everything :-)
