    Using PFSense to load balance 2 servers on internal network, no WAN, need help
    2 Posts 2 Posters 3.1k Views
      dakegg
      Hi, I have been searching for load balancing help w/ PFSense for awhile now, and even bought the book from Amazon, but I am either missing something really obvious or just can't seem to get it to work, but I would like to setup PFSense as a VMware VM to do load balancing of 2 servers on my internal network for a web application that won't work with Windows NLB.
      I assume that I would need to place the "WAN" interface on 1 internal subnet (10.0.0.1) and the "LAN" interface on a second internal subnet (10.1.0.1) and then create a VIP in the WAN IP space (10.0.0.2) that references 2 server IPs on the LAN IP space (10.1.0.2 and 10.1.0.3) but I can't seem to get that configuration to work.
      Is my assumption way off base, and this isn't possible w/ PFSense, or am I just missing a critical step in the configuration process?  Thanks in advance!
        rkelleyrtp
        Not sure I understand why you need pfSense to do this.  Sounds like you just need a server running haproxy on your LAN with a VIP.  Why do you need pfSense?  Do you really need to route from one network (LAN) to another (WAN)?
