UPS shutdown
so… the error was some "spaces" in the UPS name...
just use [a-z],[A-Z],[0-9]
sometime later there will be some update by
 @rsw686;D now it works !!! ;D
I put the necessary checks in place so this shouldn't happen to anybody else. :) I also improved the status page. To get the latest reinstall the package via the webgui.
jepp… looks nice now :-)
alpha status should be changed to beta soon, I think ;-) -
Has anyone else tried to get NUT going on a Nokia IP330? I have the package installed but it will not recognize any cable I throw at it. I have an APC Back-UPS Pro 650, which connects fine to my pc via the 2 different cables I have.
How many serial ports on your IP330. The bottom one is always the console port. If that is all you have you will have to add a second serial port above it. All IP330s have the hole in the metal, just the sticker on the front is different. Find or buy one of the below serial port adapters. On the board there is a jumper to move from the modem to the serial port. Then you just plug the ribbon cable in and screw it in the front of the IP330.
Here is a pic from a website I found showing the jumper. I did this mod on mine as it originally had the modem exposed. I have not tested out NUT on it, but will try it in the next day or so and let you know.
http://criggie.dyndns.org/tech/ip330/images/jumper1.jpg
My IP330 is shown below. The pic is before I rearranged the rack. I painted it black as the sticker on the front was peeling off and it matches everything else I have. As you can see the modem is on the far right.
thanks for your response, I didnt even notice the cutout was already there, but will def. try this.
Hmm I just hooked up a ups to my ip330 on com2, and I couldn't get it to work. I have an embedded install on there so that might be part of the issue. When I try and start the driver control I get the error
Can't uu_lock ttyd1: creat error: No such file or directory
I'll have to look into this some more and see if I can get it to work. The IP330 is my main box and I don't really plan on switching to the full install to test this. Let me know if you find out anything different.
EDIT:
I'm making progress, I had to mkdir /var/spool/lock and set the permissions as this was missing on the embedded installs. There might be something missing from the embedded install to get this to work. I would be interested in seeing how it works out for you since you have a full install.
I noticed that the NUT service will NOT start after a firmware upgrade…
after hitting "change" button in NUT settings it runs again...
perhaps that should be fixed... ;)
I don't have the slightest clue why that is happening. Any errors in the logs? Do any packages start? Feel free to submit a fix.
As far as getting my APC UPS to work with the ip330 I have only gotten it to work in simple signaling mode, meaning I'm using APC Back-UPS as the UPS type. Either my serial ribbon cable going to the board is bad or the IP330 has some issue with serial communication.
I installed the NUT package on a fresh hard drive based SNAPSHOT-02-14-2007 and get a similar error (for ttyd0) on a box that worked fine under win32 (com1) for an APC BackUPS Pro with the 95B cable in full signal mode. I tried all the various permutations from the webgui with no go. Went to the shell and hand ran the various nut binaries to see what I could figure out. At first I thought it had to do with settings in /etc/ttys for the various ttydX, especially ttyd0 due to the console definitions. But after eliminating that and a few other things, I'm still at a loss.
I'll try hand editing the ups.conf and try setting it to simple signaling like you did to see what happens.
Does the /var/spool/lock directory exist? If you create that directory and run chown uucp:dialer /var/spool/lock does it work? If so I will put a check to make sure that directory exists and if not create it. All the full installs I've seen have already had it, but something might have changed.
From your post you have the console running on ttyd0. The only thing I can think of is that there is some conflict when the console is being directed to a serial port and using other serial ports.
Does this package work with a USB type interface…..I can't seem to get it to work. I have a APC Back-UPS 1500 XS/RS.
I commited a fix that will ensure that /var/spool/lock is present and create the directory if it is not. Please reinstall the package and try again. If it still does not work run
/usr/local/libexec/nut/upsdrvctl start
from the console and let me know the error message. Also do you have the console redirected to the serial port or no?
Supposedly it does, but I have no USB UPS's to test with. On the settings page select APC Back-UPS LS USB. Configure the port as auto. If you still can't get it to work run
The LS and RS use the same driver. I will add the RS to the drop down list.
I get this in my logs…......Feb 19 12:10:27 last message repeated 7 times
Feb 19 12:09:52 upsmon[20333]: Poll UPS [apc1500@localhost] failed - Driver not connected
Feb 19 12:09:47 upsmon[20333]: UPS apc1500@localhost is unavailable
Feb 19 12:09:47 upsmon[20333]: Poll UPS [apc1500@localhost] failed - Driver not connected
Feb 19 12:09:42 upsmon[20333]: Poll UPS [apc1500@localhost] failed - Driver not connected
Feb 19 12:09:41 upsd[20329]: Can't connect to UPS [apc1500] (apc1500): Permission denied
Feb 19 12:09:37 last message repeated 6 times
Feb 19 12:09:37 last message repeated 5 times
Feb 19 12:09:12 last message repeated 24 times
Feb 19 12:09:07 upsmon[20333]: Poll UPS [apc1500@localhost] failed - Driver not connectedAnd this is what this says….....$ /usr/local/libexec/nut/upsdrvctl start
Network UPS Tools: 0.28 USB communication driver 0.28 - core 0.30 (2.0.5)Network UPS Tools - UPS driver controller 2.0.5
I might be able to get access to a USB UPS to test here this week. In the meantime I added some checks and echo statements to the rc file.
If you could reinstall the package, verify the settings and click change on the nut settings page. Then execute this script on the console and copy/paste the results here. This will identify exactly where the problem occurs and I can check the permissions since USB permissions are different the serial port permissions.
/usr/local/etc/rc.d/nut.sh start
$ /usr/local/etc/rc.d/nut.sh start
stopping upsmon
stopping upsd
stopping newhidups
forcing newhidups termination
starting newhidups
starting upsd
starting upsmon -
Here's my log info also…..........
Feb 19 15:21:51 last message repeated 25 times
Feb 19 15:21:21 last message repeated 24 times
Feb 19 15:19:46 last message repeated 7 times
Feb 19 15:19:21 last message repeated 7 times
Feb 19 15:19:11 upsmon[6811]: Poll UPS [APC1500@localhost] failed - Driver not connected
Feb 19 15:19:09 upsd[6808]: Client on 127.0.0.1 logged out
Feb 19 15:19:09 upsd[6808]: Connection from 127.0.0.1
Feb 19 15:19:06 last message repeated 4 times
Feb 19 15:18:46 upsmon[6811]: Poll UPS [APC1500@localhost] failed - Driver not connected
Feb 19 15:18:41 upsmon[6811]: UPS APC1500@localhost is unavailable
Feb 19 15:18:41 upsmon[6811]: Poll UPS [APC1500@localhost] failed - Driver not connected
Feb 19 15:18:36 upsmon[6811]: Communications with UPS APC1500@localhost lost
Feb 19 15:18:36 upsmon[6811]: Poll UPS [APC1500@localhost] failed - Driver not connected
Feb 19 15:18:36 upsd[6808]: Client monuser@127.0.0.1 logged into UPS [APC1500]
Feb 19 15:18:36 upsd[6808]: Connection from 127.0.0.1
Feb 19 15:18:36 upsd[6808]: Startup successful
Feb 19 15:18:36 upsmon[6810]: Startup successful
Feb 19 15:18:36 upsd[6807]: Can't connect to UPS [APC1500] (APC1500): Permission denied
Feb 19 15:18:33 last message repeated 2 times
Feb 19 15:18:36 newhidups[6806]: Startup successful
Feb 19 15:18:35 newhidups[6569]: Signal 15: exiting
Feb 19 15:18:34 upsd[6571]: Signal 15: exiting
Feb 19 15:18:34 upsd[6571]: Client monuser@127.0.0.1 logged out
Feb 19 15:18:34 upsmon[6575]: Signal 15: exiting
Feb 19 15:18:23 last message repeated 6 times
Feb 19 15:17:53 upsmon[6575]: Poll UPS [APC1500@localhost] failed - Driver not connected
Feb 19 15:17:48 upsmon[6575]: UPS APC1500@localhost is unavailable
Feb 19 15:17:48 upsmon[6575]: Poll UPS [APC1500@localhost] failed - Driver not connected
Feb 19 15:17:43 upsd[6571]: Client on 127.0.0.1 logged out
Feb 19 15:17:43 upsd[6571]: Connection from 127.0.0.1 -
Very helpful. I think I've gotten it fixed, wait a few minutes for the commit to go through and reinstall the package. Verify the settings and click change. It should start successfully and show the status page. You might have to refresh the status page if it is showing wait.
