    OpenVPN Issues setting static ip for clients
    25 Posts 2 Posters 9.8k Views
    • echel0nE Offline
      echel0n
      Actually this seems to ONLY happen when the client tries to connect using the ip address of WAN2 but if they use the ip address of WAN1 it's fine.
      So is this a bug ?
      • jimpJ Offline
        Not sure on that one. Are you using a single OpenVPN instance on both WANs or two different ones?
        Do not Chat/PM for help!
        • echel0nE Offline
          echel0n
          One OpenVPN instance on both WAN's yes.
          • jimpJ Offline
            If you are using UDP, that won't work without some NAT trickery (run it on LAN, port forward OpenVPN from both WANs to LAN IP)
            It should work with TCP, but I've never tried it. It's possible that OpenVPN's internal status format shows differently for that, but I'd need to see its raw output to know for sure. If you have someone on both WAN and WAN2, try this:
            From a shell:
            #telnet localhost <openvpn port="" #="">And once that connects, put in:
            status 2
            And then copy/paste that output here.</openvpn>
            • echel0nE Offline
              echel0n
              Ok I switched from UDP to TCP and all seems to be working perfectly now.
              Sorry I did the switch before I read this post so I was unable to get the status like you wanted.
