    Multi-PPPoE problem?
    9 Posts 3 Posters 4.0k Views
      mgaudette
      I have a NanoBSD system with two PPPoE links.  Those are unreliably working.  What I've noticed is that only one comes up at any time, while the other either stays inactive, or doesn't get an IP address, or doesn't get a Gateway address.
      Is there any known flaws with Multi-PPPoE setups? Is there any version known to be working with such a setup?
      I have tried an april version and the May 26th version.
      • jimpJ Offline
        I haven't tried it (only have one PPPoE line) but I have used it as an OPT WAN and had it work.
        Can you post all of the MPD logs from when both are connecting? They should be in the main system log.
        Do not Chat/PM for help!
          mgaudette
          I'll be glad to, but I am not sure what you are looking for.  What exactly should I be sending you, and would that be found in system logs?
          On another note, I get the following info from the PPPoE provider: (IPs changed, but the essence remains)
          (taken from the Status-Interface page) - For the one PPPoE interface that is up.
          IP: 72.27.32.204
          Subnet mask 255.255.255.255 (that wasnt changed)
          Gateway 66.236.201.11
          Does it make any sense? The gateway lies way outside the subnet mask, and I did get some errors when trying to put that gateway in manually, but it's still there.
            mgaudette
            Some snapshot of the log, seems relevant (again, ip and PPoE username obfuscated):
            Jun 4 11:50:04 opt1: [opt1L1] LCP: state change Closed –> Initial
            Jun 4 11:50:04 opt1: [opt1L1] LCP: Down event
            Jun 4 11:50:04 opt1: [opt1L1] Link: DOWN event
            Jun 4 11:50:04 opt1: [opt1L1] LCP: LayerFinish
            Jun 4 11:50:04 opt1: [opt1L1] LCP: state change Closing –> Closed
            Jun 4 11:50:04 opt1: [opt1L1] LCP: rec'd Terminate Ack #69 (Closing)
            Jun 4 11:50:04 opt1: [opt1L1] LCP: LayerDown
            Jun 4 11:50:04 opt1: [opt1L1] LCP: SendTerminateReq #69
            Jun 4 11:50:04 opt1: [opt1] IPCP: state change Closed –> Initial
            Jun 4 11:50:04 opt1: [opt1] IPCP: Down event
            Jun 4 11:50:04 opt1: [opt1] IPCP: state change Stopped –> Closed
            Jun 4 11:50:04 opt1: [opt1] IPCP: Close event
            Jun 4 11:50:04 opt1: [opt1] Bundle: Status update: up 0 links, total bandwidth 9600 bps
            Jun 4 11:50:04 opt1: [opt1L1] Link: Leave bundle "opt1"
            Jun 4 11:50:04 opt1: [opt1L1] LCP: state change Opened –> Closing
            Jun 4 11:50:04 opt1: [opt1L1] LCP: Close event
            Jun 4 11:50:04 opt1: [opt1L1] Link: CLOSE event
            Jun 4 11:50:04 opt1: [opt1] Bundle: closing link "opt1L1"…
            Jun 4 11:50:04 opt1: [opt1] Bundle: No NCPs left. Closing links…
            Jun 4 11:50:04 opt1: [opt1] IPCP: LayerFinish
            Jun 4 11:50:04 opt1: [opt1] IPCP: state change Stopping –> Stopped
            Jun 4 11:50:04 opt1: [opt1] IPCP: rec'd Terminate Ack #3 (Stopping)
            Jun 4 11:50:04 opt1: [opt1] IPCP: LayerDown
            Jun 4 11:50:04 opt1: [opt1] IPCP: SendTerminateReq #3
            Jun 4 11:50:04 opt1: [opt1] IPCP: state change Opened –> Stopping
            Jun 4 11:50:04 opt1: [opt1] IPCP: parameter negotiation failed
            Jun 4 11:50:04 opt1: [opt1] IFACE: IfaceChangeAddr() error, closing IPCP
            Jun 4 11:50:04 opt1: [opt1] 70.21.56.12 -> 67.23.12.5
            Jun 4 11:50:04 opt1: [opt1] IPCP: LayerUp
            Jun 4 11:50:04 opt1: [opt1] IPCP: state change Ack-Rcvd –> Opened
            Jun 4 11:50:04 opt1: [opt1] IPADDR 67.23.12.5
            Jun 4 11:50:04 opt1: [opt1] IPCP: SendConfigAck #184
            Jun 4 11:50:04 opt1: [opt1] 67.23.12.5 is OK
            Jun 4 11:50:04 opt1: [opt1] IPCP: rec'd Configure Request #184 (Ack-Rcvd)
            Jun 4 11:50:03 opt1: [opt1] IPCP: state change Req-Sent –> Ack-Rcvd
            Jun 4 11:50:03 opt1: [opt1] SECDNS 207.164.234.193
            Jun 4 11:50:03 opt1: [opt1] PRIDNS 207.164.234.129
            Jun 4 11:50:03 opt1: [opt1] IPADDR 70.21.56.12
            Jun 4 11:50:03 opt1: [opt1] IPCP: rec'd Configure Ack #2 (Req-Sent)
            Jun 4 11:50:03 opt1: [opt1] IPCP: SendConfigReq #2
            Jun 4 11:50:03 opt1: [opt1] 70.21.56.12 is OK
            Jun 4 11:50:03 opt1: [opt1] IPCP: rec'd Configure Nak #1 (Req-Sent)
            Jun 4 11:50:03 opt1: [opt1] SECDNS 0.0.0.0
            Jun 4 11:50:03 opt1: [opt1] PRIDNS 0.0.0.0
            Jun 4 11:50:03 opt1: [opt1] IPADDR 0.0.0.0
            Jun 4 11:50:03 opt1: [opt1] IPCP: SendConfigReq #1
            Jun 4 11:50:03 opt1: [opt1] IPCP: state change Starting –> Req-Sent
            Jun 4 11:50:03 opt1: [opt1] IPCP: Up event
            Jun 4 11:50:03 opt1: [opt1] IPCP: LayerStart
            Jun 4 11:50:03 opt1: [opt1] IPCP: state change Initial –> Starting
            Jun 4 11:50:03 opt1: [opt1] IPCP: Open event
            Jun 4 11:50:03 opt1: [opt1] Bundle: Status update: up 1 link, total bandwidth 64000 bps
            Jun 4 11:50:03 opt1: [opt1L1] Link: Join bundle "opt1"
            Jun 4 11:50:03 opt1: [opt1L1] Link: Matched action 'bundle "opt1" ""'
            Jun 4 11:50:03 opt1: [opt1L1] LCP: authorization successful
            Jun 4 11:50:03 opt1: [opt1L1] PAP: rec'd ACK #2 len: 5
            Jun 4 11:50:03 opt1: [opt1L1] PAP: sending REQUEST #2 len: 33
            Jun 4 11:50:03 opt1: [opt1L1] PAP: using authname "hiddenusername@bellnet.ca"
            Jun 4 11:50:01 opt1: [opt1L1] LCP: LayerUp
            Jun 4 11:50:01 opt1: [opt1L1] PAP: sending REQUEST #1 len: 33
            Jun 4 11:50:01 opt1: [opt1L1] PAP: using authname "hiddenusername@bellnet.ca"
            Jun 4 11:50:01 opt1: [opt1L1] LCP: auth: peer wants PAP, I want nothing
            Jun 4 11:50:01 opt1: [opt1L1] LCP: state change Ack-Sent –> Opened
            Jun 4 11:50:01 opt1: [opt1L1] MAGICNUM 79ba9924
            Jun 4 11:50:01 opt1: [opt1L1] MRU 1492
            Jun 4 11:50:01 opt1: [opt1L1] LCP: rec'd Configure Ack #68 (Ack-Sent)
            Jun 4 11:50:01 opt1: [opt1L1] LCP: state change Req-Sent –> Ack-Sent
            Jun 4 11:50:01 opt1: [opt1L1] MAGICNUM 47217eb3
            Jun 4 11:50:01 opt1: [opt1L1] AUTHPROTO PAP
            Jun 4 11:50:01 opt1: [opt1L1] LCP: SendConfigAck #221
            Jun 4 11:50:01 opt1: [opt1L1] LCP: rec'd Configure Request #221 (Req-Sent)
            Jun 4 11:50:01 opt1: [opt1L1] LCP: SendConfigReq #68
            Jun 4 11:50:01 opt1: [opt1L1] LCP: state change Starting –> Req-Sent
            Jun 4 11:50:01 opt1: [opt1L1] LCP: Up event
            Jun 4 11:50:01 opt1: [opt1L1] Link: UP event
            Jun 4 11:50:01 opt1: [opt1L1] PPPoE: connection successful
            Jun 4 11:50:01 opt1: PPPoE: rec'd ACNAME "bas5453-montrealak"
            Jun 4 11:50:00 opt1: [opt1L1] PPPoE: Connecting to ''
            Jun 4 11:50:00 opt1: [opt1L1] Link: reconnection attempt 21
            Jun 4 11:49:57 opt1: [opt1L1] Link: reconnection attempt 21 in 3 seconds
            • jimpJ Offline
              That's normal with PPPoE, you can have a gateway outside of the subnet. For example my (working) PPPoE WAN looks like this:
              IP address   72.x.x.192
              Gateway 10.34.29.1
              Someone who knows MPD internals better will have to check those log entries out and see if that "IfaceChangeAddr() error" in the logs indicates anything bad.
                mgaudette
                On on June 4th version.
                Actually I realized yesterday that I was having more than just Multi-PPPoE issues.  Here is what I saw on even a single PPPoE:
                1. The PPPoE connection timeout (9 seconds might) have been too low, because it did takes many many times for it to actually work (~20?), while on a Tomato based linksys routeur it worked reliably (but it took man seconds to come up, maybe 30 althought I have no logs to know what actually happened during those 30 secs.)
                2. Both links, it turns out, have the same gateway.  Would that prevent both from working at the same time?
                • jimpJ Offline
                  Not sure about 1), but 2) would definitely be a problem.
                    clarknova
                    Have you ruled out mlppp as an option? Your provider would have to support it.
                    db
                      mgaudette
                      @jimp:
                      Thanks.  I figured about 2), but I am hopeful to get at least one PPPoE connection working. What can I do to help troubleshoot this?
