    DNS problem with 0.95.8
    27 Posts 3 Posters 10.1k Views
      sullrich
      Okay, run this from a shell:
      /etc/rc.conf_mount_rw
      fetch -o /etc/inc/system.inc "http://cvs.pfsense.com/cgi-bin/cvsweb.cgi/~checkout~/pfSense/etc/inc/system.inc?rev=1.79.2.12;content-type=text%2Fplain;only_with_tag=RELENG_1"
        thinair
        I get this:
        fetch: http://cvs.pfsense.com/cgi-bin/cvsweb.cgi/~checkout~/pfSense/etc/inc/system.inc?rev=1.79.2.12;content-type=text%2Fplain;only_with_tag=RELENG_1: No address record
        In fact I've always gotten that no address record message with every fetch entered here.
        Anyway, still didn't work.  I appreciate the effort you're putting into this though.  I guess it is a PPPoE thing?
        Nelson Papel
          sullrich
          Wait for the next update then.
            sullrich
            Please try:
            http://www.pfsense.com/~sullrich/?M=D
              thinair
              Unrelated, but when uploading a new image to the firewall I don't get a seperate window stating the speed and completion.  Just the progress bar at the bottom of the browse (IE) is progressing.
              Ok, DNS works, at 'ISP DNS servers' it shows two indentical IP addresses though.
              Nelson Papel
                sullrich
                Progress bar has been removed.  It's not compatible with LightHTTPD.
                Duplicate DNS server issue just fixed and will be included with next release.
                • E Offline
                  Emab
                  @sullrich:
                  Perfect!
                  Doing this, now the DNS is ok!!
                  Great Job!
                  Thank you!
