    Squid problem with "Allow users on interface" check box
    1 Posts 1 Posters 2.1k Views
      dmiller
      version 1.01
      squid version 2.5.14_2-p7
      This code (or something related) in squid.inc is not working right for the "Allow users on interface" check box:
      // Allow the remaining ACLs if no authentication is set
              if ($auth_method == 'none') {
                      $allowed = array('localnet', 'allowed_subnets');
                      $allowed = array_filter($allowed, 'squid_is_valid_acl');
                      foreach ($allowed as $acl)
                              $conf .= "http_access allow $acl\n";
      allowed_subnets works just fine…...
      Checked or uncheck, you always get the "http_access allow localnet" in the squid.conf
      The "acl localnet src  10.177.0.0/255.255.0.0" is added and deleted properly with the check box.
      If you have an http_access rule with no acl, squid gets cranky.
      Why not just leave the box checked? Because I want to control access
      with the whitelist and CIDR ranges with allowed (local) subnets.
      Update: I just figured out, if you uncheck the box and click the save button twice,
      "http_access allow localnet" is removed from squid.conf.
      This is still a problem because most users will uncheck the box and only click save once, and that breaks squid.
