    LAN adapter watchdog timeout when running heavy load on pfSense
    18 Posts 9 Posters 34.7k Views
      gschoch
      Hi
      given that pfSense is a real great product we decided to switch all our firewalls from IPCop and MonoWall to pfSense. The installation went smooth!
      Version: 1.0.1
      Environment:
      VIA EPIA-EK1000G Mini ITX with to LAN Cards (vr0 and vr1) integrated
      one additional Linksys LNE100TX (dc0)
      Problem:
      when running a larger traffic (e.g. Filetransfer) across the firewall (LAN<->WAN = about 40Mbps) than we get suddently
      #kernel vr0: watchdog timeout
      The problem can occur after 5 Seconds or 20 Minutes
      Tests 1:
      I changed vr0 (LAN) against the dc0 card
      Result: #kernel dc0: watchdog timeout
      Test 2:
      I assumed that the LAN environment could lead to an error. I tested several times the load test.
      Result: #kernel vr1: watchdog timeout
      That means that the WAN side disappeared
      Test 3:
      using only 2 external LAN-Cards (with an Adapter to the Mini ITX Board = Total 4 LAN Boards)
      Result: #kernel em0: watchdog timeout
      Additional hints:
      • we do have this Problem since using pfSense = we started a few monthes ago with RC 1
      • we had this problem as well with the older version of the VIA Mini ITX Board (800MHz)
      would be great if anybody had a hint for me!
      regards
      Günther
        gschoch
        Hi again
        at least a little hint what I should test, replace, update?
        Does nobody had ever such problems?
        regards
        Günther
          hoba
          I haven't noticed this yet, not even with a wrap when heavily overloading it. What cpu load do you see when doing that loadtest? Is the webgui/ssh still responsive during the test? Also do problems appear when these messages show up or does everything still work like expected besides the log entries?
            rsw686
            Found a post on this http://forum.ev1servers.net/showthread.php?t=55633
            It suggests the following.
            a) turn ACPI support OFF
            b) turn PNP OS support OFF [in bios]
            if possible
            c) change the NIC to some other brand like 3com or Intel.
              gschoch
              the system does fail and has to be rebooted. If the WAN network cards fails than it's still possible to access the Firewall via Web-GUI or SSH. The console does work in all cases
              if possible
              thank you for the link. At the end of this thread I found
              Disabling ACPI did not help.
              Dedicating IRQ for the NIC did not help.
              Changing the hardware (nic/mb) did help, havent seen the error for a week now. So 'watchdog timeouts' is mostly hardware related problem.
              I think I will give a try to the last solution
              regards
              Günther
                abcdefg1675
                @gschoch:
                Problem:
                Im having problems similar to this. K6-500, 415MB ram. Regardless of what NICs I try (compaq dual-port server NIC, or generic cheapos), Pfsense locks up when I get close to 10-15Mbps, and occasionally at lower speeds with heavy use such as uTorrent. I suspect it may be a problem with the actual computer running pfsense (bad ram, bad cpu??). I ran Pfsense under VMware, on a 1.8Ghz "3000+" amd computer. Performance as far as throughput goes was no better than the K6-500, but I havent been able to reproduce any of the crashing I was experiancing.
                gschoch, do you have any way of monitoring temperatures (CPU, memory etc) in the routers? Ive had issues before with other PC's that wernt getting good ventilation, and hanging/crashing when getting well over 60-70+C.
                  gschoch
                  …, do you have any way of monitoring temperatures (CPU, memory etc) in the routers?
                  thank you for the answer. Yes we monitored and have about 6 pfSense boxes (but the same age or cooling or memory). All of them do have in common that they are based on VIA Mini ITX boards. All other components are different. But in all cases we do end up with this timeout errors. We will test now another set of NICs and if this does not help the Mini ITX boards have to be switched to another product.
                  regards
                  Günther
                    gschoch
                    Hi
                    just for others with the same problem:
                    we switched to a D-Link DFE-580TX Networkadapter with 4 Ports and since then we had nomore any watchdog timeout
                    regards
                    Günther
                    • U Offline
                      unreal1024
                      This is problem FreeBSD v. 6.1
                      Im using two card 3Com 3C905CX-TX-M, disable ACPI, disable sound blaster, change network cards, disable PNP OS, disable COM, LPT, change VGA card.
                      No change anything.
                      Im using pfSense v. 1.0.1:
                      (filtered…)
                      Dec 8 05:24:45 kernel: xl1: watchdog timeout
                      Dec 7 19:26:13 kernel: xl1: watchdog timeout
                      Dec 7 16:03:00 kernel: xl1: watchdog timeout
                      Dec 7 11:15:14 kernel: xl1: watchdog timeout
                      Dec 7 09:18:26 kernel: xl1: watchdog timeout
                      Dec 7 03:43:00 kernel: xl1: watchdog timeout
                      Dec 7 03:40:29 kernel: xl1: watchdog timeout
                      Dec 7 03:35:51 kernel: xl1: watchdog timeout
                      Dec 6 20:34:35 kernel: xl1: watchdog timeout
                      Dec 6 18:29:09 kernel: xl1: watchdog timeout
                      Dec 6 17:15:44 kernel: xl1: watchdog timeout
                      Dec 6 16:27:28 kernel: xl0: watchdog timeout
                      Dec 6 13:36:52 kernel: xl1: watchdog timeout
                      Dec 5 17:29:39 kernel: xl1: watchdog timeout
                      Dec 5 15:12:16 kernel: xl1: watchdog timeout
                      Dec 5 12:34:30 kernel: xl1: watchdog timeout
                      Dec 5 10:43:28 kernel: xl1: watchdog timeout
                      Dec 5 10:39:41 kernel: xl1: watchdog timeout
                        SatireWolf
                        for reference, broadcom based integrated chips tend to watchdog timeout under VERY heavy loads but they reset and go on with life. I've seen this happen on AMD Opteron and Intel Xeon platforms with multiple broadcom chips. I just use Intel NICS for everything critical and I don't have issues.
                        As for 3com's the 3c905b's were perhaps the best 10/100 NIC's ever built in my opinion. But when they did the die shrink and built the 3c905c's they were terrible. I even have problems with those in Windows boxes and Linux boxes!
                        My recommendation would be to stay away from newer 3com cards, period. There's a reason Intel has outsold, and blown them out of the water in the NIC market. Besides, Intel continuously contributes code for their NIC drivers. So they just 'work' T.M.
                          sullrich
                          Upgrade to http://www.pfsense.com/~sullrich/1.0.1-SNAPSHOT-12-06-2006/ and see if the problems persist.
                            DWAyotte
                            I had the same problem earlier today.
                            Dec 9 14:57:03 kernel: sk0: link state changed to UP
                            Dec 9 14:33:46 kernel: arplookup 231.57.128.57 failed: host is not on local network
                            Dec 9 14:08:17 php: : Hotplug event detected for sk0 but ignoring since interface is not set for DHCP
                            Dec 9 14:08:17 check_reload_status: rc.linkup starting
                            Dec 9 14:08:14 kernel: sk0: link state changed to DOWN
                            Dec 9 14:08:14 kernel: sk0: watchdog timeout
                            Dec 9 13:59:43 kernel: arp: 172.17.17.254 is on sk0 but got reply from 00:0b:db:65:8a:91 on em0
                            Dec 9 12:58:09 kernel: arp: 172.17.17.241 is on sk0 but got reply from 00:11:43:11:92:8b on em0
                            Dec 9 12:38:17 last message repeated 4 times
                            Dec 9 12:37:53 kernel: arp: 172.17.17.252 is on sk0 but got reply from 00:13:20:00:cb:cf on em0
                            Dec 9 12:36:57 last message repeated 9 times
                            Dec 9 12:36:37 kernel: arp: 172.17.17.241 is on sk0 but got reply from 00:11:43:11:92:8b on em0
                            Dec 9 12:21:55 kernel: em0: watchdog timeout – resetting
                            Dec 9 12:21:33 last message repeated 9 times
                            Dec 9 12:19:44 kernel: arp: 172.17.17.241 is on sk0 but got reply from 00:11:43:11:92:8b on em0
                            Dec 9 12:02:09 last message repeated 4 times
                            Dec 9 12:02:01 kernel: arp: 172.17.17.241 is on sk0 but got reply from 00:11:43:11:92:8b on em0
                            Dec 9 11:46:48 last message repeated 5 times
                            Dec 9 11:46:23 kernel: arp: 172.17.17.252 is on sk0 but got reply from 00:13:20:00:cb:cf on em0
                            Dec 9 11:45:39 kernel: arp: 172.17.17.247 is on sk0 but got reply from 00:06:5b:f3:2a:4b on em0
                            Intel Pro/1000 MT and 3COM 3C2000-T NIC's
                            I have just updated my box with your snaphsot link and also went into BIOS and disabled all unnecessary hardware.  I hope this fixes it.
                            • U Offline
                              unreal1024
                              I am upgrade pfSense 1.0.1 to 1.0.1-SNAPSHOT-12-08-2006, new install 1.0.1-SNAPSHOT-12-08-2006, but have same problem.
                              …filtered...
                              Dec 10 17:48:43 kernel: xl1: watchdog timeout
                              Dec 10 17:19:51 kernel: xl0: watchdog timeout
                              Dec 10 17:01:23 kernel: xl1: watchdog timeout
                              Dec 10 16:36:45 kernel: xl1: watchdog timeout
                              Dec 10 15:13:29 kernel: xl1: watchdog timeout
                              Dec 10 12:28:23 kernel: xl1: watchdog timeout
                              Dec 10 12:18:24 kernel: xl1: watchdog timeout
                              • U Offline
                                unreal1024
                                If you start receiving these messages regularly, read below:
                                FreeBSD network device drivers (dc, xl, sk etc.) utilize watchdog timers to keep some statistics about the device driver and to tackle deadlock situations that may arise because of hardware issues. This timer is set to some specific value by the device driver, and decremented by one once a second. If the timer expires and the network adapter
                                did not finish its job, the watchdog routine for this adapter is run.
                                Time watchdog timer routine simply prints a diagnostics message that is visible through /var/log/messages and restarts the network adapter.
                                Briefly, you can try the following to get rid of the problem:
                                Many PCI network adapters require a PCI slot that supports Bus Mastering. Some old motherboards
                                have this feature on only on their first PCI slot (pci0). So, plug your network adapter to the first
                                pci slot on your mainboard and see if that helps.
                                • U Offline
                                  unreal1024
                                  Hi, support this networl card D-Link DFE-580TX Traffic shaper?
                                    jeroen234
                                    don't steal a topic
                                    post it in the trafic shaper section of the forum
                                    if you had searched there you had found this post that will tell you witch interfaces suport alt q
                                    http://forum.pfsense.org/index.php/topic,1686.msg9789.html#msg9789
                                    • U Offline
                                      unreal1024
                                      Hi, exists patch for FreeBSD v. 6.1 for watchdog timeouts (Bus mastering PCI)?
                                      • U Offline
                                        unreal1024
                                        Hi, i am change 3Com card 3C905X to Planet with Realtek chipset (ENW-9503A) and disable acpi in to pfSense v. 1.0.1 (hint.acpi.0.disabled=1) and works perfectly!!!!!
