    2.0-BETA3 built on Wed Jun 30 14:44:22 EDT 2010 FreeBSD 8.1-RC1 problem
    3 Posts 3 Posters 1.5k Views
      tang2359630
      my pfsense server  has the warnings
      2.0-BETA3
      FreeBSD 8.1-RC1
      Warning: fopen(/tmp/config.lock): failed to open stream: Device not configured in /etc/inc/util.inc on line 124 Warning: flock() expects parameter 1 to be resource, null given in /etc/inc/util.inc on line 135 Warning: fclose(): supplied argument is not a valid stream resource in /etc/inc/util.inc on line 136 Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /etc/inc/util.inc:124) in /etc/inc/auth.inc on line 1138 Warning: Cannot modify header information - headers already sent by (output started at /etc/inc/util.inc:124) in /usr/local/www/guiconfig.inc on line 41 Warning: Cannot modify header information - headers already sent by (output started at /etc/inc/util.inc:124) in /usr/local/www/guiconfig.inc on line 42 Warning: Cannot modify header information - headers already sent by (output started at /etc/inc/util.inc:124) in /usr/local/www/guiconfig.inc on line 43 Warning: Cannot modify header information - headers already sent by (output started at /etc/inc/util.inc:124) in /usr/local/www/guiconfig.inc on line 44 Warning: Cannot modify header information - headers already sent by (output started at /etc/inc/util.inc:124) in /usr/local/www/guiconfig.inc on line 45 Warning: fopen(/tmp/pfSense_version): failed to open stream: Device not configured in /etc/inc/pfsense-utils.inc on line 1451
      what should I solving the problem? anyone will help me
        Kevin
        Update to the latest snapshot first. Will probably need to reinstall/reflash.  I do not think the updates were working back then.
        Lots of issues have been fixed since June.
        • U Offline
          ujangs
          Pfsense 2.0 Beta 4 built on Fri Sep 24 14:30:24 EDT 2010 - stable
